Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248326
03/10/09 11:20 PM
03/10/09 11:20 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
For push comes to shove, these are the items I'm in need of...
I'm in need of the parking brake strut and anti-rattle spring. Along with that, I'd like to get 2 or 4 of the adjusters complete (includes the two main components and the hardened thin washer. I also need the two thick lower springs that hold the lower shoes together (star wheel lock spring. Finally, 4 wheel cylinder push rods.
Troy..been there done that...parking brake strut can be obtained from mopar member "DoctorDiff". Anti rattle spring from local NAPA (that's where I got mine). Heavy duty star wheel adjusters and star wheel lock spring also from NAPA. Wheel clinder push rods are tricky. Only place I have seen them is Year One for $15/each...ouch! See picture below of my set up (not the best picture but you get the jist)...I think it's similar to what you are talking about. I have part # for items from NAPA if you want them...PM me if you need them. BTW car looks great
Re: 11" front & rear brake assembly pics [Re: LYNCHROAD69.5] #248327
03/11/09 06:31 AM
03/11/09 06:31 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Perfect Wayne... Thanks.. I'll send you a PM..
Cheers.
Troy
Troy
Houston Mopar Connection Club
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248328
03/11/09 09:48 AM
03/11/09 09:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good info. I have 11' rears with no adjusters but have been thinking of adding them as I have better things to do than adjust my brakes every couple of months.
That's a thought as well.. I already have all the components for modify all 4 corners to self-adjusters.... Anyone think of any negative things about modifying the non to adjustable?
Will you be removing your wheels and drums at car shows ??? If it's going to be a trailer queen and you believe they didn't have them then leave them out .
Re: 11" front & rear brake assembly pics [Re: LYNCHROAD69.5] #248329
03/11/09 09:51 AM
03/11/09 09:51 AM
Massachusetts
Massachusetts
Troy, picture of boxes with part # is below:
Re: 11" front & rear brake assembly pics [Re: LYNCHROAD69.5] #248330
03/11/09 11:06 AM
03/11/09 11:06 AM
Houston, Tx
Houston, Tx
Thanks Wayne... I checked NAPA's website and all "show" to be good numbers...
I'm taking it that there are two anti-rattle springs per kit, one adjusting screw per box and one adjusting screw spring per box.
Troy
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248331
03/11/09 11:17 AM
03/11/09 11:17 AM
Massachusetts
Massachusetts
That's right except for the screw spring....the box I had contained 4 in it sealed in a bag. BTW I checked my email and doctordiff has the parking brake levers and can get the struts if necessary. His email is shown on the user list..good luck.
Re: 11" front & rear brake assembly pics [Re: LYNCHROAD69.5] #248332
03/11/09 11:26 AM
03/11/09 11:26 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I just checked on NAPA's site and they show a self adjuster 'repair kit' that has everything including new cables for about $16 per wheel ( #80685 & #80686 rears) . Looks like I'll be taking the Vert for a drive today on a parts run!
