11" front & rear brake assembly pics #248306
03/09/09 10:14 AM
03/09/09 10:14 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Does anyone have pictures they could post of a actual '68/'69 B-body brake assemblies with 11x3 front & 11x2.5 rears with the drums off? I'm in need of some components and wanna make sure I don't duplicate what I need. Aren't the brake bar/strut only used in the rear in conjuction with the emergency/parking brake lever or is there a strut/bar in the front as well? It's been way too long since I took this apart and I think there were some parts missing actually. I have a service manual, but prefer as well actual pictures of cars today. I believe my HD drum brakes had adjustable capability at all four corners? I just picked up the adjuster kits for all corners this weekend and the complete hardware kits. I believe I need the struts, two of the diamond-shaped shoe guide plates. For sure I need the rear left and right parking/emergency brake lever.
Thanks..
Troy
Troy
Houston Mopar Connection Club
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248307
03/09/09 12:41 PM
03/09/09 12:41 PM
Houston, Texas
John69RR Offline
super street
John69RR  Offline
super street
Houston, Texas
Troy, I do not have a picture of the rear brakes but I believe you are correct about the strut for the parking brake. I thought HD brakes did NOT have self adjusters. Anyhow, here is a pic of the front brakes on nmy 69RR.
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248308
03/09/09 12:49 PM
03/09/09 12:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes the strut bar assembly is only used on the rear for the parking brake .
Re: 11" front & rear brake assembly pics [Re: John69RR] #248309
03/09/09 01:45 PM
03/09/09 01:45 PM
Houston, Tx
Houston, Tx
John,
I'm starting to think that myself about the adjuster,, at least for the front. So, on your R.R, you didn't have self-adjusters on the rear either? I found two of the short thick springs just like the ones on the bottom that hold the lower shoes together and add resistance to the adjuster. Didn't want to, but I guess I can tear into my '69 C500 and see the setup, should be the same....
Troy
Re: 11" front & rear brake assembly pics [Re: JohnRR] #248310
03/09/09 01:46 PM
03/09/09 01:46 PM
Houston, Tx
Houston, Tx
If that's the case, then I have one side then..
Thanks.......
Troy
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248311
03/09/09 03:00 PM
03/09/09 03:00 PM
Houston, Texas
John69RR Offline
super street
John69RR  Offline
super street
Houston, Texas
John,
That's correct. No self adjusters on front or rear. I do not have a scanner, but on page 5-6 of the 69 Dodge manual are pictures of the front and rear HD and police brakes. No self adjusters, strut only on rear for parking brake.
Re: 11" front & rear brake assembly pics [Re: John69RR] #248312
03/09/09 03:16 PM
03/09/09 03:16 PM
Houston, Tx
Houston, Tx
John,
You referring to the 69 Service Manual? I was looking at my '68 Service Manua and apparently, they only show the 10" with the adjusters within the brakes section. I'll take a look at my '69 Service Manual............
Troy
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248313
03/09/09 03:42 PM
03/09/09 03:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Troy your car should have the self adjusters on the rear , but I guess you could run without them if you want to adjust the rear every so often .
Re: 11" front & rear brake assembly pics [Re: John69RR] #248314
03/09/09 03:43 PM
03/09/09 03:43 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
The 11" brakes are part of the Police Package and do not have self adjusters. Only the rears have the strut which is a functioning part of the emergency/parking brake system.
Re: 11" front & rear brake assembly pics [Re: 68CoronetRT] #248315
03/09/09 03:54 PM
03/09/09 03:54 PM
Houston, Tx
Houston, Tx
Dang, then the 11" adjuster kits I got was for nothing.. Oh well.... The hardware kit will work though... Another reason I should have asked first and/or looked at my '69 Charger 500's drums............ My C500 with Dana should be the same as the '68 Hemi R/T...
Troy
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248316
03/09/09 04:31 PM
03/09/09 04:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would look at the other car , I have yet to crack open an 11" rear drum setup and not find the self adjusters in there ??? But these are not 1 owner , low mileage cars .
Re: 11" front & rear brake assembly pics [Re: JohnRR] #248317
03/09/09 04:47 PM
03/09/09 04:47 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Good info. I have 11' rears with no adjusters but have been thinking of adding them as I have better things to do than adjust my brakes every couple of months.
Re: 11" front & rear brake assembly pics [Re: Classof70Chally] #248318
03/09/09 05:06 PM
03/09/09 05:06 PM
Houston, Tx
Houston, Tx
That's a thought as well.. I already have all the components for modify all 4 corners to self-adjusters.... Anyone think of any negative things about modifying the non to adjustable?
Troy
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248319
03/09/09 06:45 PM
03/09/09 06:45 PM
Houston, Texas
John69RR Offline
super street
John69RR  Offline
super street
Houston, Texas
Unless you are going for 100% concours correct, go for it. It's one less maintenance issue to address.
Re: 11" front & rear brake assembly pics [Re: John69RR] #248320
03/09/09 09:17 PM
03/09/09 09:17 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Which is why you find them on many of the cars even though they weren't that way from the factory.
Re: 11" front & rear brake assembly pics [Re: 68CoronetRT] #248321
03/09/09 09:30 PM
03/09/09 09:30 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If you are going to put a lot of miles on the car , I would add the self adjusters.
If not leave em correct. They will need adjustment about every 5k miles..
Back in the drum brake days the Hot ticket to improve 1/4 mile times was to back off the shoes to reduce drag and HP loss.
Some of the old drag tests will include a word or two about backing off the self adjusters...
Re: 11" front & rear brake assembly pics [Re: sthemi] #248322
03/10/09 07:56 AM
03/10/09 07:56 AM
Houston, Tx
Houston, Tx
For push comes to shove, these are the items I'm in need of...
I'm in need of the parking brake strut and anti-rattle spring. Along with that, I'd like to get 2 or 4 of the adjusters complete (includes the two main components and the hardened thin washer. I also need the two thick lower springs that hold the lower shoes together (star wheel lock spring. Finally, 4 wheel cylinder push rods.
Troy
Re: 11" front & rear brake assembly pics [Re: hemi68charger] #248323
03/10/09 11:39 AM
03/10/09 11:39 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
The strut bar, retainer washers and star adjusters can all be sandblasted and refinished. I wire brushed my adjuster threads to get a nice shine to them. The springs are available in kits from Rock Auto and others.
Try a few of the major suppliers like RT specialties, Herb's, Jack's, etc. and you will find everything you need.
By the way, I bought my new 11" front pads at AutoZone for about $30 (special order) and they were the riveted pads and an exact match.
Re: 11" front & rear brake assembly pics [Re: 68CoronetRT] #248324
03/10/09 09:44 PM
03/10/09 09:44 PM
MO
cdp Offline
cdp  Offline
MO
I just did my front brakes and converted to self adjusting. This is for my A12. The adjusters are available new for about $12 I think, but you need to make sure which ones to get. They are different between non and adjusting.
Re: 11" front & rear brake assembly pics [Re: cdp] #248325
03/10/09 09:55 PM
03/10/09 09:55 PM
MO
cdp Offline
cdp  Offline
MO
Mopar kits are #4636773 for 11" brakes. Struts are 4761762 rt, 4746173 lt.
May ?? still be available from dealer. Source is from a 1994 Mopar Action.
