Re: Paint job on a budget!? CONTINUED..page 44........
#24818
06/26/06 08:57 PM
06/26/06 08:57 PM
when you want that "glistening" look then you spraying a little too much...and doing that it wont dry underneath. but i do have some "glistening" few spots on my paint (couldnt help it)hope it drys well. 69charger, want to sell me your tremclad clear coat? also are you sure that tremcldad clear coat or any oil based clear coat sandable? how does it stand agaist the heat from the engine bay? what ever happen to the pple that used clear coats? nobody trie dth automotive clear either?
Re: Paint job on a budget!? CONTINUED..page 44........ *DELETED*
#24819
06/27/06 12:28 AM
06/27/06 12:28 AM
#24820
06/27/06 08:51 AM
06/27/06 08:51 AM
#24821
06/27/06 09:30 AM
06/27/06 09:30 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Let's not get this thread closed up, there are still things to be learned and questions to be answered. ![](/ubbthreads/images/graemlins/engel016.gif) In other news, I tried some penetrol on my hood and it came out really orange peely.. must not have used enough. Back to mineral spirits. I'm taking some days off later this week and I'm going to see how close to done I can get this car. Until then there's really not much to look at.
#24822
06/27/06 10:24 AM
06/27/06 10:24 AM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
i did play with the clear coat, but found that it shined just about the same as just straight buffed paint....BUT.....the guy from tremclad that sent me a case for free told me that you must thin the clear coat with laquir thinner and NOT mineral spirits or you kill the shine. so knowing this now the next time i paint a car using this method i'll defineatly try the clear coat out so NO you can't have it....nana ![](/ubbthreads/images/graemlins/whistling.gif)
you can sand any clear coat, some are eaiser then others, but for now i'm happy with my paint and i continue to drive my cars until they need a repaint. i did test a small peice using the clear and laquir thinner and it shines like a BC/CC job, but i just did a really small test peice and it really looked awesome. definatly will give it a try. The tremclad guy said the clear coat stuff reflects 90% at 60*deg of light, so it is highly reflective, but you must use laquir thinner not mineral spirits.
By the way, i found another use for mineral spirits, i cleaned my tires with it, and man, they look like brand new. on my 74 beetle, i used to dress the tires with all that tire shine stuff, for the "wet" look" and over the winter it left this residue that would'nt come off, like a brown crud that almost looked like sticker residue. the mineral spirits really makes your tires look like new, not the shiny look, but like brand new rubber, try it, you'll be amazed, mineral spirits has so many uses i'm just discovering, it also safely removes paint over-spray from lenses, rubber, ect....i cleaned my carb with it, and it shines like new. ![](/ubbthreads/images/graemlins/drinking.gif)
[Re: Exit1965]
#24825
06/27/06 02:02 PM
06/27/06 02:02 PM
69chargeryeehaa
toronto canada
Does the clearcoat you played with get as hard and tough as the tremclad paint?
I'd like to get some roll on cleacoat to play with sometime. In the meantime though, I noticed that even though the red paint on my car is still a tad "soft", the red paint I sprayed onto the door is ROCK and I mean ROCK hard. So maybe the spray on clearcoat is worth a serious look..
the paint will get rock hard exit, after 3 months of driving the car and sun exposure trust me it will be super hard. and yes the clear dries harder than the paint, almost no thinning is requred as it is allready really thin out of the can, and needs about 5% thinning with laquir thinner, rolls better than the paint. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 69chargeryeehaa]
#24826
06/27/06 04:52 PM
06/27/06 04:52 PM
I'm ready to start painting my car tonight. Body work is done. I have only one question. I'm still confused about the mix of mineral spirits to paint. I've seen anywhere from 10% to 40%. Am I correct to assume that one of the biggest factors is sunlight and heat? I live in Arizona. It gets hot here. Will that effect the percentage?
[Re: Exit1965]
#24828
06/27/06 08:31 PM
06/27/06 08:31 PM
Here is another Aussie update with my Miata. Most of my painting is now finished, and the car is going to sit out in the sun for a few days to help cure the paint. I'm really impressed with the way that it has turned out. If it looks this good now, I can't wait to see how it will look once it's polished!!
[Re: Exit1965]
#24829
06/27/06 08:48 PM
06/27/06 08:48 PM
Hey, this is sideglide. I have ZERO clue as to why I was banned. I am just a fellow car enthusist that was trying this cool paint job.
The only think I can think of was that I left the computer on at a public place and someone might have messed with it.
I just wanted to say this place is cool and this paint tech is going good for me. I hope that I will be able to continue to post as I have some good pics coming.
Thanks for your understanding.
#24830
06/27/06 09:20 PM
06/27/06 09:20 PM
alright guys, i need some help here. I really need some rustoleum clear, and i cant find it anywhere. So can someone buy some and ship it to me? email me at big_blue_mnm@hotmail.com, that is also my msn, and my aim is p8intballer12. Thanks -Greg
#24831
06/27/06 09:29 PM
06/27/06 09:29 PM
#24832
06/27/06 10:33 PM
06/27/06 10:33 PM
Posts: 1,819 Central New Jersey
Ira
super gas
super gas
Central New Jersey
Brandon, post as slideglede, its turned back on, try to not leave the computer unattended, sorry for the confusion ![](/ubbthreads/images/graemlins/wave.gif) and now back to the subject
#24834
06/27/06 11:16 PM
06/27/06 11:16 PM
Exit1965
Rancho Cordova, CA
Thanks -Greg
Where have you looked? I've seen it at walmart, home depot, lowes, OSH hardware.
If all else fails, you can try emailing this place: http://www.hardwareworld.com/contact.aspx
in a google search, it showed up for them, but the don't seem to have it on the site anymore. They have a bunch of other rustoleum at good prices. You're looking for Crystal Clear #7701.
Also, might try calling Rustoleum and ask them where you can get it, see if they tell you somewhere new..
[Re: Exit1965]
#24835
06/27/06 11:25 PM
06/27/06 11:25 PM
Thanks -Greg
i dont know if your talking about the spray, or in quarts/gallons. ive looked at walmart, lowes, home depot. I can find the spray, but not in quarts etc.
#24836
06/27/06 11:54 PM
06/27/06 11:54 PM
Exit1965
Rancho Cordova, CA
That explains it. There is no such thing as RUSTOLEUM clear in anything but a spray. I've posted this before more than once but I'm sure not everyone's seen it. This is straight from the horse's (rustoleum's) mouth. I searched high and low for quarts and gallons too, then finally called rustoleum and it does not exist except in spray.
82Scirocco uploaded some pics a few pages back of what he got with the spray on kind, and it looks like a pretty sweet deal.
edit: I see now that 82scirocco was using tremclad clear in a spray can and not rustoleum. as nice as his looks I hope rustoleum spray isn't far off. I have read good things about rustoleum clear on other sites though, just never talking about cars in particular.
[Re: Exit1965]
#24837
06/28/06 12:20 AM
06/28/06 12:20 AM
well... i guess that does explain everything... maybe there is another company that has an oil based paint in clear? ill see if i can find some
