Pitman arm source? #2482473
04/14/18 10:14 AM
04/14/18 10:14 AM
Someplace you aren't
SomeCarGuy Offline OP
Not seeing any listed for the 70s trucks. 77 d150
Rebuild kit?
I want my fair share
Re: Pitman arm source? [Re: SomeCarGuy] #2482602
04/14/18 02:52 PM
04/14/18 02:52 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
If someone can chime in with a part number that will help the search. I see NOS ones pop up sometimes.
Facts are stubborn things.
Re: Pitman arm source? [Re: SomeCarGuy] #2482609
04/14/18 03:04 PM
04/14/18 03:04 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Not sure if this will help, I'm assuming your looking for Power steering App ?
Manual steering I believe is 3492213.
Re: Pitman arm source? [Re: SomeCarGuy] #2482711
04/14/18 08:02 PM
04/14/18 08:02 PM
Power
Factory 440 truck
I did see some stuff that made me think it could be engine specific. Can’t remember what right off.
Re: Pitman arm source? [Re: SomeCarGuy] #2483147
04/15/18 04:50 PM
04/15/18 04:50 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Why doesn't someone make them. I checked LMC truck and I see they have idler, and pretty much everything but pitman.
It will be a big help if we can just get part number.
Re: Pitman arm source? [Re: SomeCarGuy] #2483999
04/17/18 01:47 AM
04/17/18 01:47 AM
After some calling around I ended up with Rare Parts.
They couldn’t find a part number and said I’d need to send one for copying. I asked and several people today including rare parts said only one steering box is listed and there isn’t a reason to believe it’s engine application specific.
So two problems remain, one I need a pitman to send. Two, I need to be willing to part with “at least” 300 bucks. Possibly more once they give it a go.
I’m only guessing mine is worn out. The box pours and I thought I’d just knock this out while doing the repair so things will be golden.
I’d go a hundred for sure if we can get a group going. We all should need one down the line and this project helps us all out. The steering box is for 77-79, so it’s safe to say this is only a three year part, maybe somebody can sort out if it covers more or not.
Re: Pitman arm source? [Re: SomeCarGuy] #2484226
04/17/18 02:11 PM
04/17/18 02:11 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
If this includes 4WD I will go $100 but it has to be guaranteed to cover 4WD too.
Re: Pitman arm source? [Re: SomeCarGuy] #2484321
04/17/18 06:42 PM
04/17/18 06:42 PM
scratchnfotraction Offline
PITMAN ARM?
what wears out on a solid piece of steel? the conical hole for the draglink tapered end? splines on the sector shaft hole?
2x idler arm/center link/tie rods/BJ wear out
4x4 the drag link/tie rods/BJ wear out...the steer arm & pitman arm are solid steel
only time I have saw a difference was 2x or 4x4 and power or manual steer
not counting the pitman arm/steer arm for 4x4 lift kits.
you can check with them for replacements or lift arms if in need. skyjacker/rough country/JC Whitney
Re: Pitman arm source? [Re: SomeCarGuy] #2484323
04/17/18 06:45 PM
04/17/18 06:45 PM
I converted a couple dodge drag links over to chebby adjustable draglinks and used chebby lift steer arms/springs/8 lug hubs/knuckles/spindles for lifting 4x4s running 40s or bigger tires.
Re: Pitman arm source? [Re: SomeCarGuy] #2484342
04/17/18 07:20 PM
04/17/18 07:20 PM
That’s great news. I assumed they had a wear part like the cars have and might as well knock out now. Not one person thought it was odd to ask. Thanks.
Re: Pitman arm source? [Re: SomeCarGuy] #2484422
04/17/18 11:17 PM
04/17/18 11:17 PM
5thAve Offline
5thAve  Offline
On the big GMs it was the drag link and idler arm that were replaceable so guessing that's why you can't find pitman arm? I would have thought anyway that if it was a part that needed to be replaced it wouldn't be this hard to find. But I've never had to replace one.
Re: Pitman arm source? [Re: SomeCarGuy] #2484495
04/18/18 08:26 AM
04/18/18 08:26 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I've seen a few Pitman arms wore out from the drag link not being tightened properly.
Re: Pitman arm source? [Re: larrymopar360] #2485732
04/20/18 07:06 PM
04/20/18 07:06 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
My 74-77 DT Parts manual shows a illustration of steering components for D100-200-300 with the following notation.
Parts Indicated by name only - order by description
The pitman arm does reference 19-27-2
I will dig deeper.
Red
Re: Pitman arm source? [Re: SomeCarGuy] #2485737
04/20/18 07:21 PM
04/20/18 07:21 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Rebuild kit?
Check your pm
Red
Re: Pitman arm source? [Re: SomeCarGuy] #2485738
04/20/18 07:27 PM
04/20/18 07:27 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
OK I found it
74-77 D100-200-300
Arm, Steering Gear
3492214 Power
3492213 Manual
I cannot guarantee the accuracy of this info, it's only what I read in the manual.
Note initially I thought you might have a hard time finding this but they are on eBay aplenty and may have been used thru 1993, you may be able to buy one from Ma?
Red
Re: Pitman arm source? [Re: SomeCarGuy] #2485921
04/21/18 03:06 AM
04/21/18 03:06 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Seems strange if it does indeed stop at '77 and not thru at least '80
I guess W150 would be different due to lift?
Re: Pitman arm source? [Re: SomeCarGuy] #2485966
04/21/18 09:26 AM
04/21/18 09:26 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Mopar made almost yearly changes to truck steering in the late 70's. Most notably the mounting of the box for 4wd. Also steering column changes mainly the coupler.
That said pitman arm are non wear items. Differences are manual v power, 2v4 wd, early or late 4wd.
Having not dabbled much with 2wd trucks I wouldn't rule out a steering redesign in the late 70's that would require a different arm.
All in all though it shouldn't be hard to find a good used or nos part once you nail down a part number.
Angry white pureblood male
Re: Pitman arm source? [Re: larrymopar360] #2485977
04/21/18 10:00 AM
04/21/18 10:00 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Actually my books cover 74-77, 78-81 and 82-83
They all list the same steering arms for 2WD.
I think for 2WD they used the same arm through 1993 but I do not have the later books just some random compatibility charts on the net.
My 2 cents.
Red
Re: Pitman arm source? [Re: ruderunner] #2485981
04/21/18 10:08 AM
04/21/18 10:08 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
A lot can happen the a steering arm over the years. Beaten to death during a steering box swap etc.
I listed the parts number above.
Red
Re: Pitman arm source? [Re: BIGGERED] #2486208
04/21/18 10:23 PM
04/21/18 10:23 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
My 2 cents.
Red
Doesn't W150 mean 4 wheel drive?
I have mechanical Aptitude.
I can screw up anything.
