Pitman arm source?
#2482473
04/14/18 10:14 AM
04/14/18 10:14 AM
Posts: 10,200 Someplace you aren't
SomeCarGuy
Not seeing any listed for the 70s trucks. 77 d150
Rebuild kit?
I want my fair share
Re: Pitman arm source?
[Re: SomeCarGuy]
#2482602
04/14/18 02:52 PM
04/14/18 02:52 PM
Posts: 15,828 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If someone can chime in with a part number that will help the search. I see NOS ones pop up sometimes.
Facts are stubborn things.
[Re: SomeCarGuy]
#2482711
04/14/18 08:02 PM
04/14/18 08:02 PM
SomeCarGuy
Power
Factory 440 truck
I did see some stuff that made me think it could be engine specific. Can’t remember what right off.
[Re: SomeCarGuy]
#2483147
04/15/18 04:50 PM
04/15/18 04:50 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Why doesn't someone make them. I checked LMC truck and I see they have idler, and pretty much everything but pitman.
It will be a big help if we can just get part number.
[Re: SomeCarGuy]
#2483999
04/17/18 01:47 AM
04/17/18 01:47 AM
SomeCarGuy
After some calling around I ended up with Rare Parts.
They couldn’t find a part number and said I’d need to send one for copying. I asked and several people today including rare parts said only one steering box is listed and there isn’t a reason to believe it’s engine application specific.
So two problems remain, one I need a pitman to send. Two, I need to be willing to part with “at least” 300 bucks. Possibly more once they give it a go.
I’m only guessing mine is worn out. The box pours and I thought I’d just knock this out while doing the repair so things will be golden.
I’d go a hundred for sure if we can get a group going. We all should need one down the line and this project helps us all out. The steering box is for 77-79, so it’s safe to say this is only a three year part, maybe somebody can sort out if it covers more or not.
[Re: SomeCarGuy]
#2484342
04/17/18 07:20 PM
04/17/18 07:20 PM
SomeCarGuy
That’s great news. I assumed they had a wear part like the cars have and might as well knock out now. Not one person thought it was odd to ask. Thanks.
[Re: larrymopar360]
#2485732
04/20/18 07:06 PM
04/20/18 07:06 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
If someone can chime in with a part number that will help the search. I see NOS ones pop up sometimes. My 74-77 DT Parts manual shows a illustration of steering components for D100-200-300 with the following notation. Parts Indicated by name only - order by description The pitman arm does reference 19-27-2 I will dig deeper. Red
[Re: SomeCarGuy]
#2485737
04/20/18 07:21 PM
04/20/18 07:21 PM
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Rebuild kit? Check your pm Red
[Re: SomeCarGuy]
#2485921
04/21/18 03:06 AM
04/21/18 03:06 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Seems strange if it does indeed stop at '77 and not thru at least '80
I guess W150 would be different due to lift?
[Re: SomeCarGuy]
#2485966
04/21/18 09:26 AM
04/21/18 09:26 AM
Posts: 5,777 ohio
ruderunner
ohio
Mopar made almost yearly changes to truck steering in the late 70's. Most notably the mounting of the box for 4wd. Also steering column changes mainly the coupler.
That said pitman arm are non wear items. Differences are manual v power, 2v4 wd, early or late 4wd.
Having not dabbled much with 2wd trucks I wouldn't rule out a steering redesign in the late 70's that would require a different arm.
All in all though it shouldn't be hard to find a good used or nos part once you nail down a part number.
Angry white pureblood male
[Re: larrymopar360]
#2485977
04/21/18 10:00 AM
04/21/18 10:00 AM
BIGGERED
Reasonable Title
Reasonable Title
North East USA
I guess W150 would be different due to lift? Actually my books cover 74-77, 78-81 and 82-83 They all list the same steering arms for 2WD. I think for 2WD they used the same arm through 1993 but I do not have the later books just some random compatibility charts on the net. My 2 cents. Red
[Re: ruderunner]
#2485981
04/21/18 10:08 AM
04/21/18 10:08 AM
BIGGERED
Reasonable Title
Reasonable Title
North East USA
A lot can happen the a steering arm over the years. Beaten to death during a steering box swap etc. I listed the parts number above. Red
[Re: BIGGERED]
#2486208
04/21/18 10:23 PM
04/21/18 10:23 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I guess W150 would be different due to lift? Actually my books cover 74-77, 78-81 and 82-83 They all list the same steering arms for 2WD. I think for 2WD they used the same arm through 1993 but I do not have the later books just some random compatibility charts on the net. My 2 cents. Red Doesn't W150 mean 4 wheel drive?
I have mechanical Aptitude. I can screw up anything.
