water vs oil #2482110
04/13/18 12:44 PM
04/13/18 12:44 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
What is the average temperature difference between the water in the block temperature and oil in the pan at operating temperature.
Re: water vs oil [Re: rowin4] #2482133
04/13/18 01:12 PM
04/13/18 01:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They tend to be pretty close(just normal block)
wave
Re: water vs oil [Re: rowin4] #2482140
04/13/18 01:27 PM
04/13/18 01:27 PM
New York
polyspheric Offline
polyspheric  Offline
New York
True.
Oil temp will rise pretty quickly with load, water won't unless the cooling system isn't big enough.
Boffin Emeritus
Re: water vs oil [Re: rowin4] #2482154
04/13/18 01:57 PM
04/13/18 01:57 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Not exactly a high performance machine lol, but my ‘16 Journey with a 3.6 will usually be within 10 degrees of each other. Coolant is usually 90C, oil 80-85C.
Re: water vs oil [Re: rowin4] #2482183
04/13/18 02:45 PM
04/13/18 02:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
what is this "C" you speak of?
Re: water vs oil [Re: HotRodDave] #2482208
04/13/18 03:32 PM
04/13/18 03:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Normally C would be Celsius
EDIT
if you notice he is Canadian
wave
Re: water vs oil [Re: rowin4] #2482321
04/13/18 09:18 PM
04/13/18 09:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
With my Mega block drag car the water can be manipulated where ever you want its . Oil, that's a different story. Getting it above 150 F before a single run, good luck. Even a diaper hasn't increased it. Back to back runs at 80+ F ambient it might hit 180. This is with the temp sensor in the pan filled with 7 qts.
Doug
Re: water vs oil [Re: rowin4] #2482359
04/13/18 11:14 PM
04/13/18 11:14 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Oil is normally about 30F hotter in my half filled 440
1963 Plymouth Max Wedge
1971 Barracuda
