With my Mega block drag car the water can be manipulated where ever you want its . Oil, that's a different story. Getting it above 150 F before a single run, good luck. Even a diaper hasn't increased it. Back to back runs at 80+ F ambient it might hit 180. This is with the temp sensor in the pan filled with 7 qts.
Doug
