Re: BEST INTAKE FOR 512 STROKER AND SNIPER EFI?
[Re: CUDA8U]
#2482397
04/14/18 12:53 AM
04/14/18 12:53 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Being a throttle body style EFI you definitely want a single plane intake....The Holley street Dom is one of the best single planes.....There have been reports of this style EFI not working hardly at all on dual plane intakes....Port fuel injection is so much better than this TBI crap.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2482489
04/14/18 11:28 AM
04/14/18 11:28 AM
Posts: 1,039 ALBERTA CANADA
CUDA8U
ALBERTA CANADA
Being a throttle body style EFI you definitely want a single plane intake....The Holley street Dom is one of the best single planes.....There have been reports of this style EFI not working hardly at all on dual plane intakes....Port fuel injection is so much better than this TBI crap. the multi port kits range up to $4000 no one is running a sniper or fitech?
[Re: CUDA8U]
#2482508
04/14/18 11:50 AM
04/14/18 11:50 AM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Heh, I'm going this exact same route this summer: 512ci with a Holley Sniper EFI. My motor already has a Torquer 383 single plane on it. If you look it up the Engine Master guys had an issue using a TBI setup (might have been FiTech) where the fuel was puddling on the floor of the dual plane intake they were using. They couldn't get the motor to run straight until they swapped to a single plane.
[Re: CUDA8U]
#2483620
04/16/18 02:52 PM
04/16/18 02:52 PM
Posts: 59 Florida
Sweet5ltr
Holley Sniper EFI works great. I'm running an M1-4500 intake manifold with 4150 adapter on my 470ci stroker. Trying to fit it under a factory hood, not a chance. With a 3" (total) height 15" oval filter, it's around .25" of clearance under my six pack hood. Your going to have to sacrifice on port volume (HP potential) and go with something like the Holley Street Dominator, and that may even be tough depending on your air cleaner choice.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
[Re: Sweet5ltr]
#2483782
04/16/18 07:05 PM
04/16/18 07:05 PM
Posts: 30,995 Oregon
AndyF
Holley Sniper EFI works great. I'm running an M1-4500 intake manifold with 4150 adapter on my 470ci stroker. Trying to fit it under a factory hood, not a chance. With a 3" (total) height 15" oval filter, it's around .25" of clearance under my six pack hood. Your going to have to sacrifice on port volume (HP potential) and go with something like the Holley Street Dominator, and that may even be tough depending on your air cleaner choice. What you need is one of my old AR372 adapters. Not sure that it would work with a Sniper though since it was designed for the dual pattern carbs. But it was only 1/2 tall and it worked pretty well.
