572 B1 headed NGK sparkplug number question
#2481847
04/12/18 09:56 PM
04/12/18 09:56 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This is my first B1 headed combo and very first nitrous application. I have used Autolite plugs in all my builds for the past 44 years but NGK seems to be the go to plug with nitrous. Brad Watt was gracious enough to get me pointed in the right direction but before I order several boxes I would like to pick other B1 guys brain. I want to start out NA and then slowly apply the juice after a week or two so I need a NA and nitrous NGK plug number. Thanks guys. Its a 200-650 plate system
Re: 572 B1 headed NGK sparkplug number question
[Re: Sammy]
#2481862
04/12/18 10:31 PM
04/12/18 10:31 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
NGK 5672A-9 from 14-15.5 Compression is what my friends use on their B1 engines NA or nitrous. Thanks Sammy
[Re: pittsburghracer]
#2481868
04/12/18 10:38 PM
04/12/18 10:38 PM
dartman366
Mt. Vernon, Ohio
NGK 5672A-9 from 14-15.5 Compression is what my friends use on their B1 engines NA or nitrous. Thanks Sammy I run the 5671a-9 in my car and it is NA and 12.3 comp ratio
#2481888
04/12/18 10:58 PM
04/12/18 10:58 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Start with a -9 on motor IMO.
[Re: a493demon]
#2481971
04/13/18 01:44 AM
04/13/18 01:44 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I already gave you the number for nitrous The 9s for NA the 10s for spray I know and I appreciate it but I want to be FASTER than you so I was just checking. LOL
[Re: a493demon]
#2481976
04/13/18 01:54 AM
04/13/18 01:54 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks buddy. lov ya. 2nd one to the finish line buys first round.
[Re: dartman366]
#2481980
04/13/18 02:31 AM
04/13/18 02:31 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
NGK 5672A-9 from 14-15.5 Compression is what my friends use on their B1 engines NA or nitrous. Thanks Sammy I run the 5671a-9 in my car and it is NA and 12.3 comp ratio That's a bit cold for that compression imo and I run 8's at 12.1.1..I agree on 9's for Pittsburghracer though...........
[Re: Thumperdart]
#2482015
04/13/18 09:09 AM
04/13/18 09:09 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
NGK 5672A-9 from 14-15.5 Compression is what my friends use on their B1 engines NA or nitrous. Thanks Sammy I run the 5671a-9 in my car and it is NA and 12.3 comp ratio That's a bit cold for that compression imo and I run 8's at 12.1.1..I agree on 9's for Pittsburghracer though........... I agree with this, I also ran -8 plugs at 15:1 and would have went to a -9 for a small shot of spray.
#2482046
04/13/18 10:23 AM
04/13/18 10:23 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The 5671A is the number for non-projected tip. The 5672A is the number for projected tip.
The heat ranges run from 5 to 11, hot to cold, and are closer together than most of the other plugs.
I've found with my 11 to 1 small block, I can get away with 8s on Drag Week, driving on pump gas, and then spraying at the track with 114 in the tank.
My brothers like to switch to a colder 9 or 10 when spraying their big blocks.
Plug Number/Part number Projected tip BCP6ES/4930 BCP7ES/5030 R5672A-8/7173 R5672A-9/7405 R5672A-10/7942
Non-projected tip R5671A-7/4091 R5672A-8/4554 R5671A-9/5238 R5671A-10/5820 R5671A-11/6596
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2482049
04/13/18 10:35 AM
04/13/18 10:35 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks guys. It sounds like Brad (a493demon) was on point recommending R5671A-9 (5238) NA and R5671A-10 (5820) Nitrous. Hope o place the order today and make some noise with this thing soon.
[Re: a493demon]
#2482410
04/14/18 01:55 AM
04/14/18 01:55 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
John I want you to be fast . But just a little slower then I am lol . Just bring the Absolute Vodka Brad. I will bring my Diet Dew mixer. I ordered 10 sets of plugs today so that will get me started. Thanks for the plug numbers.
[Re: dthemi]
#2482729
04/14/18 08:59 PM
04/14/18 08:59 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
No way possible to use a 13/16 plug on my combo. I’m making special tools for 5/8 plugs.
