Air conditioning compressor ideas
#2479066
04/07/18 09:39 PM
04/07/18 09:39 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. In my future there is possibly a triple black '70 Road Runner, 383 pistol-grip 4speed with a/c. The car has a 440 in it now. I was thinking of putting my six pack set up on it along with a complete air grabber hood assembly. As we all know, the factory RV2 compressor is too big for the base plate for either a fresh-air or 6 barrel set up. I was toying with one of the later model rotary compressors, but that seems to create a very busy engine compartment. I could have swore I once saw a '70 Challenger at a show a long time ago that has a compressor under the alternator. This was facilitated with the use of an electric fuel pump and the elimination of the mechanical pump. I think this would be a very cool combination on a '70 Road Runner.
Ideas?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Air conditioning compressor ideas
[Re: hemi68charger]
#2479095
04/07/18 10:30 PM
04/07/18 10:30 PM
Posts: 553 DE
Ply72rr
DE
[Re: hemi68charger]
#2479128
04/07/18 11:08 PM
04/07/18 11:08 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I have the Sanden, with factory style hoses with R134a compatible rubber hose upgrade, will freeze you out.
[Re: 62maxwgn]
#2479938
04/09/18 12:55 PM
04/09/18 12:55 PM
hemi68charger
Houston, Tx
Troy,years ago Direct Connection had this air cleaner available to cleared the RV2 compressor,still have it. Thanks all......... Hey there Bill, Thanks for the reply... Let me think if I want the compressor on top or hidden under the alternator... Hope you've been well.......... Troy
[Re: hemi68charger]
#2479951
04/09/18 01:16 PM
04/09/18 01:16 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I too run a triple black six pack and aftermarket A/C. I used the Bouchillon under alternator bracket, but modified it to change the belt paths to gain more belt wrap around the pulleys.
The new routing uses one belt from the crank to the A/C compressor, and a separate belt from the A/C compressor to the beefed up CS140 alternator. My power steering belt goes from the crank to the water pump and then to the power steering pump.
Most people never know it has A/C while looking under the hood.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: hemi68charger]
#2480406
04/10/18 11:43 AM
04/10/18 11:43 AM
Posts: 8,847 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I also want to put new style a.c. on 71 440 6 pack charger.(clone) I don't want anything up front on top of the motor. Want it bolted down under the alt. Don't know which sanden pump to use Will be using a v belt style. And if I can't find a bracket setup I like il make my own I don't want to see the pump at all
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2480457
04/10/18 01:14 PM
04/10/18 01:14 PM
jbc426
West Coast, USA
The Sanden compressor is nicknamed "the Shorty". Buschillion carries them. I bought my condenser, receiver dryer and some hardlines used between the two from Nostalgic Air in Florida.
Nostalgic Air has great customer service and tech help, plus their prices are better than most. I also bought my R-134 specific condenser from them. It fills my entire radiator opening, and I sealed it along all the edges, so all the air has to go through it and pass through the radiator.
I used the GenV in car kit from VintageAir. It is a nice kit.
[Re: hemi68charger]
#2481217
04/11/18 06:59 PM
04/11/18 06:59 PM
Posts: 1,883 Northern OH
rapom
Northern OH
I did what jbc426 did and bought the bouchillon low mount kit and rerouted the belts and have had no problems going on 6 years now. I even ran a gm based powermaster alt. which works nicely with the kit.
