Where to buy Alternator and PS bolts for 360?
#2481309
04/11/18 10:32 PM
04/11/18 10:32 PM
Posts: 1,230 Pittsburgh, PA
wayfarer1
Pittsburgh, PA
Mancini's have the bolt kit for the timing cover/water pump but I can't find a listing for the bolts to mount the alternator or the PS pump. These bolts need to be for a LA 360 w/o a/c. Where can I buy these bolts? Any help is appreciated.
Thanks, Joe
Current Project: 72 Roadrunner 340/727/Petty Blue/White Roof Strobe Stripe/Black Bucket Interior
71 Demon project
Re: Where to buy Alternator and PS bolts for 360?
[Re: ahy]
#2481342
04/11/18 11:30 PM
04/11/18 11:30 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
It agree with above. My local Tractor Supply has standard Grade 5 or Grade 8 bolts in the longer lengths. Test fit and add washers or cut length down until they fit. You can use a piece of threaded rod to get your measurement if you have a piece laying around. Then go buy the bolt you need.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#2481360
04/12/18 12:02 AM
04/12/18 12:02 AM
wayfarer1
Pittsburgh, PA
we have all of the original bolts from the front of the engine, however they are not in reusable condition. I can use the old bolts for reference for the diameter and length. I am going to go with a grade 5 bolt. We have a Rural King near us that has a great selection of bolts.
Thanks for all to advice and info, Joe
71 Demon project
