Problems with Hughes Whiplash cam in 383
#2480283
04/10/18 12:05 AM
04/10/18 12:05 AM
Posts: 869 Keizer, Oregon U.S.A.
elmor353
Recently put a Hughes Whiplash cam in a 71 383 and I'm having some problems. According to their website, you should be able to use a stock converter with this cam. It kept choking down the engine and dying when put in gear, so I replaced the stock converter with a 2800 stall unit. It's better, but I still have trouble keeping it running in gear. It acts almost like there is a vacuum leak somewhere. It is a 71 383 that was freshened up. 8.5 to 1 compression, fresh set of 346 heads with valve springs to match the cam, torker intake, Hooker super comps, 3310 Holley carb, factory single point distributor. I have replaced the intake gaskets using a new bathtub with the Fel-pro sandwich gaskets. I checked the carb base to make sure it isn't warped. This engine ran fine with the same set up before, the only difference was a factory cam and a Carter AVS carb. I have tried the avs with this cam and it runs the same as the Holley. I installed the cam straight up,should I advance it a couple degrees? I'm drawing a blank here.
Re: Problems with Hughes Whiplash cam in 383
[Re: krautrock]
#2480301
04/10/18 12:59 AM
04/10/18 12:59 AM
RapidRobert
yes you should advance the cam, prob 4*. you are also going to want to run alot of initial ignition advance, you have to modify the advance plates in the dist so your total timing will be proper. Agreed, & rework the timing first (& if you adv the cam then the timing needs to be reworked again). bump up the initial for a start, what are you running now?
[Re: elmor353]
#2480320
04/10/18 01:40 AM
04/10/18 01:40 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Trouble keeping it running in gear , how many Rpms does it drop in gear versus park , you mentioned vacuum leak - Did you spray looking for leak
Factory single point distributor , with the 1971 electronic retard box on distributor ?
I would bee looking at dwell versus timing versus points versus distributor springs especially if factory original
Distributor intermediate shaft and rotor position versus spark plug wiring order
Timing set position dot to dot , double check if you only replaced the camshaft
Sounds like your overlooking something simple
Torque Converter would have been the last thing I would have thought of based on what your saying
[Re: elmor353]
#2480345
04/10/18 05:11 AM
04/10/18 05:11 AM
Posts: 4,848 Memphis
HemiRick
Memphis
The torquer is a really poor intake and hard to tune a carb to work on IMHO, need a performer or perf rpm, or a stock intake. The only good single plane is Holley street Dominator.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: elmor353]
#2480379
04/10/18 10:06 AM
04/10/18 10:06 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
I love it when people start changing out carbs..... "I just did this and now it runs terrible" did you use any real diagnostic tools or are you just going to keep changing parts till you find something that fixes it? did you check lifter preload? did you put a vacuum gauge on the motor to see where it is? doesn't sound like it. keep changing carbs....
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: elmor353]
#2480419
04/10/18 12:02 PM
04/10/18 12:02 PM
Posts: 3,916 usa
lewtot184
usa
may need more initial timing; which the distributor should be reworked to reduce centrifugal degrees in it. single plane intakes/low vacuum cams/low compression/high overlap aren't a good mix for something your going to drive. power valve in carb may need changed. to me this is the perfect example for not over camming a 383.
just looked at hugh's website. that cam has 21 degrees of overlap at .050". that's nearly identical to the 284/.484 cam. in my opinion, over cammed for 8.5:1 compression 383 and definitely won't run thru stock exhaust manifolds (if they're being used).
[Re: elmor353]
#2480430
04/10/18 12:24 PM
04/10/18 12:24 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
I'd get it running with points. Each change made adds another variable. Find the reason its got no power. http://www.hughesengines.com/Index/produ...mp;partid=30172over 230* on a 383, it will want at least 16* initial and maybe up to 20*. Once that's done and off idle is OK, the rest of the curve can be corrected; either by moving the both spring perches out, and if needed by also shortening the slots. Depends on what the factory curve looks like to begin with. Tach - for idle with points or a simple ECU, a tach/dwell is the easiest. Easy to find at garage sales, etc. Vacuum gage - really handy - totally worth it. Mityvac silverline also really handy and a good investment. With that you can figure out what the vac advance is doing. Timing Tape - Black with white or yellow numbering. Things thing s will help you. There's still a learning curve, but it takes a guy with tons of experience to do it by sight sound and smell. Even then, those guys will still use instruments to fine tune and write in their notebooks.
[Re: Mattax]
#2480512
04/10/18 03:00 PM
04/10/18 03:00 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I'd get it running with points. Each change made adds another variable. Find the reason its got no power. http://www.hughesengines.com/Index/produ...mp;partid=30172over 230* on a 383, it will want at least 16* initial and maybe up to 20*. Once that's done and off idle is OK, the rest of the curve can be corrected; either by moving the both spring perches out, and if needed by also shortening the slots. Depends on what the factory curve looks like to begin with. Tach - for idle with points or a simple ECU, a tach/dwell is the easiest. Easy to find at garage sales, etc. Vacuum gag e - really handy - totally worth it. Mityvac silverline also really handy and a good investment. With that you can figure out what the vac advance is doing. Timing Tape - Black with white or yellow numbering. Things thing s will help you. There's still a learning curve, but it takes a guy with tons of experience to do it by sight sound and smell. Even then, those guys will still use instruments to fine tune and write in their notebooks. ^^This^^ Start with the timing. As someone else posted I think the advance is ground into the Hughes cam, but verify where it is anyway. I also agree that the intake is not a good choice for this engine.
[Re: elmor353]
#2480533
04/10/18 03:35 PM
04/10/18 03:35 PM
bee1971
Sobieski Wi
In his initial post he said he also tried the Carter AVS with this cam
He said it ran the same as the Holley
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: elmor353]
#2480608
04/10/18 05:36 PM
04/10/18 05:36 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Initial timing... FBO sells a plate to limit the amount mechanical advance in the distributor so you can run a lot more initial ...the plate is pretty cheap. http://www.manciniracing.com/fbomodilipl.html
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
