Re: 03 2500 diesel change to dual rear wheels
[Re: fpmopar]
#2477582
04/04/18 09:45 PM
04/04/18 09:45 PM
Posts: 5,821 ohio
ruderunner
ohio
More involved than you think. Are you going flatbed or pickup?
Dana 60 or 44 front?
Angry white pureblood male
[Re: fpmopar]
#2479865
04/09/18 10:57 AM
04/09/18 10:57 AM
Posts: 15,760 Jefferson State
srt
ESYC
ESYC
Jefferson State
Will it make it more stable for towing a trailer? I can happily report that I've been using our 'o3 since I bought it used for towing regularly including several (>15) long distant trips moving while loaded to the gills. Also, regularrly use it towing a laden travel trailer while on vacations, hunting trips and other journeys. All w/o dwd. I've never had an issue and just eclipsed 200k mi adding over 130k from when I bought it. I keep up on maintenance and change the diff oil and additive (have a factory locking 3.73). The diff is noted to be "free floating". Depending on what you're using it for I would go with the stock diff and save your # for if there is a problem. I've not heard a lot of issues from other owners.
[Re: ahy]
#2480414
04/10/18 11:56 AM
04/10/18 11:56 AM
Posts: 6,710 KY
65pacecar
KY
Personal choice I think. 8 sidewalls in the rear vs 4 sidewalls will increase towing stability somewhat. Agree with that.
Still, single tires chosen well can work fine also towing. Pick a 10 ply rated tire with stiff sidewalls. Tire Rack has good reviews on LT tires. Inflate well also. With that, your single tires should handle anything your truck can reasonably tow.
Personally, I would not mess with the conversion.
Also worth noting, dual rear is not so good in snow. Single is better, especially when running light. I wont even try to drive my Dually in the snow. I keep highway tires on it and it would be a horrible experience.
