gen 1 or 2 hemi coil on plug? #2479020
04/07/18 08:51 PM
04/07/18 08:51 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, does anyone make coils for coil on plug installation entirely within the spark plug tubes of a gen 1 or 2 Hemi?
Thanks,
Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479104
04/07/18 10:41 PM
04/07/18 10:41 PM
AndyF Offline
AndyF  Offline
I don't think so. Some people use a Lexus pencil type coil but I'm not sure how well it works. Give Rich at FAST Man EFI a call and talk to him. He did a Hemi that way once.
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479111
04/07/18 10:49 PM
04/07/18 10:49 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yep I did it using Lexus coils. It worked but the coils were not hot enough for a race engine with high compression.
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479114
04/07/18 10:53 PM
04/07/18 10:53 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Thanks,
Joel
I have seen articles about using Yota coils on Mopar HEMI engines like Andy probably seen the same article. Being a Toyota tech I have a selection of "known good" coils for testing misfires. I could send you a few different length coils for test fitting if you want shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479125
04/07/18 11:06 PM
04/07/18 11:06 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Usually, it's really not the coil that is any longer or shorter. It's the boot and wire. There are some boot kits available aftermarket (I know the Jeep 4.0 coil assembly has available boot kits). Wouldn't be impossible to make up some of your own. Just use the proper connection from the coil to the plug.
[image][/image]
Re: gen 1 or 2 hemi coil on plug? [Re: sgcuda] #2479147
04/07/18 11:31 PM
04/07/18 11:31 PM
Rittman Ohio
Rittman Ohio
He's talking about a coil pack that fits down inside the tube so there is no wire.
Gus beer
64 Plymouth Savoy
Dana 60
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479150
04/07/18 11:39 PM
04/07/18 11:39 PM
Minnesota
Minnesota
What I have in mind is something that would look old school. Like a coil package that will fit entireley within the spark plug tube, and be concealed by a stock rubber tube cover. The 2 coil wires would be hid inside a rubber tube that would look like a traditional spark plug wire.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479187
04/08/18 01:14 AM
04/08/18 01:14 AM
Minnesota
Minnesota
On the valve covers in my signature picture, the spark plug tubes are recessed in. So from the top of the valve cover to the top of the spark plug tube is 1.1". This recess is 1.6" diameter. The spark plug tube itself is 1.1" inside diameter. From the top of the spark plug to the top of the valve cover is 4.85".
Does anyone have a coil that fits this dimension?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479191
04/08/18 01:17 AM
04/08/18 01:17 AM
Minnesota
Minnesota
maybe something like THIS BOSCH
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479196
04/08/18 01:23 AM
04/08/18 01:23 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Did you look at the picture I posted? The Lexus coils fit rather nice.
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479217
04/08/18 02:34 AM
04/08/18 02:34 AM
Minnesota
Minnesota
Rich, I did look at that thanks. Maybe I'm seeing it wrong, but it dosen't look like I could hide those under a stock rubber dust boot. What's your take on that?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479351
04/08/18 12:48 PM
04/08/18 12:48 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
There are no coils that I know that are small enough in diameter at the top.
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479368
04/08/18 01:09 PM
04/08/18 01:09 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I thought about putting coil on plug while building my Hemi, just not that informed as most on what would work. Whats the point of hiding the coils in the tubes? You still have #14 gauge wire coming out of the hole to the box. Or is there a plan to hide those also.
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479385
04/08/18 01:23 PM
04/08/18 01:23 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The coils in rich’s pick look very similar to the coils you will find on most ford mod motors. I’ve used the ford coils in remote mount situations. You can put a plug wire on the ford coil.
I get what you are trying to do. And I like the idea. The ford coils are small enough that they would fit in a “simulated” distributor cap. Maybe try that route?
Or there are these... not sure of dimensions.
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479775
04/09/18 02:03 AM
04/09/18 02:03 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think he wants to hide them under the original covers.
Would coil near plug work? You could hide the coil packs at the back of the engine.
Kevin
Edit
Just read it again. Not what your looking for... lol
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479782
04/09/18 02:42 AM
04/09/18 02:42 AM
Minnesota
Minnesota
Kevin, that would work. I could mount coils on the inside of the firewall.I was just fishing for a more compact way of doing it.
The problem I am trying to solve is that on my coupe the throttle pivot ended up in a bad spot on the firewall, right where the distributor is, almost touching. And the support for the throttle pivot comes off the cage. Plus the hi-rise x-ram intake and carbs hinders access to the dist for maintenance. It's a small car with a lot going on, packaging is an issue. So I can move the throttle things and gain a little room around the dist, but I have to cut and reweld the support to the cage under the cowl. Or get rid of the distributor and gain the benefits of distributorless. I've never done distributorless before, I'm try to learn so I can decide which way to go. THe whole concept of the car is old school, so I can't just slap coils on the valve covers.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479786
04/09/18 03:08 AM
04/09/18 03:08 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
8 of those Stromberg 97 TBI's could hide quite nicely in plain site.
Is a throttle cable too new school for your theme?
Kevin
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479790
04/09/18 03:17 AM
04/09/18 03:17 AM
Minnesota
Minnesota
THe classes I plan to race in prohibit EFI. Or else I'd have a hilborn with 8 caliope stacks! THrottle cable is an idea to consider. It hadn't crossed my feeble old mind.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479807
04/09/18 06:10 AM
04/09/18 06:10 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Im not sure about interchange, but I do have an old aluminum timing cover with a mag. It fits a baby red ram hemi. Guaranteed not to have any interference with the firewall, and quite period correct.
Re: gen 1 or 2 hemi coil on plug? [Re: Hemi_Joel] #2479856
04/09/18 10:30 AM
04/09/18 10:30 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
For gen II, since there is room for a second plug tube, couldn't you custom build an aluminum shell around the coil, then cut and weld the top and bottom of your spark plug tube to the shell? Then you wouldn't have to worry about fitting the whole works in a tube, just need to fit under the valve cover amongst the rocker assembly.
Something shaped like a muffler with the entrance and exit offset. Just need somebody with a TIG welder.
