gen 1 or 2 hemi coil on plug?
#2479020
04/07/18 08:51 PM
04/07/18 08:51 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
Hi, does anyone make coils for coil on plug installation entirely within the spark plug tubes of a gen 1 or 2 Hemi? Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: gen 1 or 2 hemi coil on plug?
[Re: Hemi_Joel]
#2479114
04/07/18 10:53 PM
04/07/18 10:53 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hi, does anyone make coils for coil on plug installation entirely within the spark plug tubes of a gen 1 or 2 Hemi? Thanks, Joel I have seen articles about using Yota coils on Mopar HEMI engines like Andy probably seen the same article. Being a Toyota tech I have a selection of "known good" coils for testing misfires. I could send you a few different length coils for test fitting if you want Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Hemi_Joel]
#2479125
04/07/18 11:06 PM
04/07/18 11:06 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Usually, it's really not the coil that is any longer or shorter. It's the boot and wire. There are some boot kits available aftermarket (I know the Jeep 4.0 coil assembly has available boot kits). Wouldn't be impossible to make up some of your own. Just use the proper connection from the coil to the plug.
[image][/image]
[Re: sgcuda]
#2479147
04/07/18 11:31 PM
04/07/18 11:31 PM
fourgearsavoy
Rittman Ohio
He's talking about a coil pack that fits down inside the tube so there is no wire. Gus
[Re: Hemi_Joel]
#2479150
04/07/18 11:39 PM
04/07/18 11:39 PM
Hemi_Joel
Minnesota
What I have in mind is something that would look old school. Like a coil package that will fit entireley within the spark plug tube, and be concealed by a stock rubber tube cover. The 2 coil wires would be hid inside a rubber tube that would look like a traditional spark plug wire.
[Re: Hemi_Joel]
#2479187
04/08/18 01:14 AM
04/08/18 01:14 AM
Hemi_Joel
Minnesota
On the valve covers in my signature picture, the spark plug tubes are recessed in. So from the top of the valve cover to the top of the spark plug tube is 1.1". This recess is 1.6" diameter. The spark plug tube itself is 1.1" inside diameter. From the top of the spark plug to the top of the valve cover is 4.85".
Does anyone have a coil that fits this dimension?
[Re: Hemi_Joel]
#2479217
04/08/18 02:34 AM
04/08/18 02:34 AM
Hemi_Joel
Minnesota
Rich, I did look at that thanks. Maybe I'm seeing it wrong, but it dosen't look like I could hide those under a stock rubber dust boot. What's your take on that?
[Re: Hemi_Joel]
#2479351
04/08/18 12:48 PM
04/08/18 12:48 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Rich, I did look at that thanks. Maybe I'm seeing it wrong, but it dosen't look like I could hide those under a stock rubber dust boot. What's your take on that? There are no coils that I know that are small enough in diameter at the top.
[Re: Hemi_Joel]
#2479368
04/08/18 01:09 PM
04/08/18 01:09 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I thought about putting coil on plug while building my Hemi, just not that informed as most on what would work. Whats the point of hiding the coils in the tubes? You still have #14 gauge wire coming out of the hole to the box. Or is there a plan to hide those also.
[Re: Hemi_Joel]
#2479385
04/08/18 01:23 PM
04/08/18 01:23 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The coils in rich’s pick look very similar to the coils you will find on most ford mod motors. I’ve used the ford coils in remote mount situations. You can put a plug wire on the ford coil.
I get what you are trying to do. And I like the idea. The ford coils are small enough that they would fit in a “simulated” distributor cap. Maybe try that route?
Or there are these... not sure of dimensions.
[Re: Hemi_Joel]
#2479775
04/09/18 02:03 AM
04/09/18 02:03 AM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I think he wants to hide them under the original covers.
Would coil near plug work? You could hide the coil packs at the back of the engine.
Kevin
Edit
Just read it again. Not what your looking for... lol
[Re: Hemi_Joel]
#2479782
04/09/18 02:42 AM
04/09/18 02:42 AM
Hemi_Joel
Minnesota
Kevin, that would work. I could mount coils on the inside of the firewall.I was just fishing for a more compact way of doing it.
The problem I am trying to solve is that on my coupe the throttle pivot ended up in a bad spot on the firewall, right where the distributor is, almost touching. And the support for the throttle pivot comes off the cage. Plus the hi-rise x-ram intake and carbs hinders access to the dist for maintenance. It's a small car with a lot going on, packaging is an issue. So I can move the throttle things and gain a little room around the dist, but I have to cut and reweld the support to the cage under the cowl. Or get rid of the distributor and gain the benefits of distributorless. I've never done distributorless before, I'm try to learn so I can decide which way to go. THe whole concept of the car is old school, so I can't just slap coils on the valve covers.
[Re: Hemi_Joel]
#2479790
04/09/18 03:17 AM
04/09/18 03:17 AM
Hemi_Joel
Minnesota
THe classes I plan to race in prohibit EFI. Or else I'd have a hilborn with 8 caliope stacks! THrottle cable is an idea to consider. It hadn't crossed my feeble old mind.
[Re: Hemi_Joel]
#2479807
04/09/18 06:10 AM
04/09/18 06:10 AM
TRENDZ
Milwaukee WI
Im not sure about interchange, but I do have an old aluminum timing cover with a mag. It fits a baby red ram hemi. Guaranteed not to have any interference with the firewall, and quite period correct.
[Re: Hemi_Joel]
#2479856
04/09/18 10:30 AM
04/09/18 10:30 AM
Posts: 313 Northeast Indiana
73DAD
Northeast Indiana
For gen II, since there is room for a second plug tube, couldn't you custom build an aluminum shell around the coil, then cut and weld the top and bottom of your spark plug tube to the shell? Then you wouldn't have to worry about fitting the whole works in a tube, just need to fit under the valve cover amongst the rocker assembly.
Something shaped like a muffler with the entrance and exit offset. Just need somebody with a TIG welder.
