I use Torco. BOOSTane is a copy of Torco.
Too bad I no longer have access to the gas chromatograph machine I used years ago. It would be interesting to tests samples of a variety of "octane boosters" and "race fuel concentrates" to see what's really in them.
![penguinhat penguinhat](/ubbthreads/images/graemlins/custom/penguinhat.gif)
The one thing in common that I've seen from the ones that are supposed to actually work (to some extent, at least), is MMT. Yes, MMT helps increase octane... but it's the additive that you may have seen is also responsible for leaving an orange/rust-looking deposit on the spark plugs. I have no idea how O2 sensors handle being exposed to that stuff short or long term.
That would be interesting. I started using the Torco Accelerator with my dirt bikes. Saved an incredible amount of money, the bikes ran cleaner (even the 4 strokes), started easier, especially in cold weather and made the tune up more consistent.
After that, I tried it for street/strips deals and it worked as well as lower end race gas and was cheaper.
Only did two dyno tests. One verses straight pump fuel. The Torco picked up ~8-10 hp everywhere over pump gas.
The other was verses a 110 race gas. At 12:1 there was no difference in power between the two.
