Re: E-Body (Barracuda 1971) Door Lock Cylinder and Gasket
[Re: David1971]
#2476741
04/03/18 01:25 PM
04/03/18 01:25 PM
RapidRobert
If you installed the cyl with the thin white gasket in the door then locked it in with the retainer clip (like normal) then installed that other piece on the cyl barrell like it is in the last pic would that be it? Tho I ain't never seen that "other piece" but I have near zero E body exp.
[Re: NANKET]
#2476954
04/03/18 07:19 PM
04/03/18 07:19 PM
RapidRobert
because he was not getting a response & I've noticed on occaision that when that happens (many views/no postings), that sometimes when one person finally responds then others seem to jump in (I've seen that pattern somewhat) so I figured that if I put something out there that was maybe a slight bit helpful (I hoped) that others might chime in with more relevent info & that this would potentially help him solve his issue. Might not be straight thinking but my intent is good & I don't think anything in my post was misleading him soooo are we good! (you may not agree with my reasoning but I sure hope you are no longer baffled!).
[Re: David1971]
#2477199
04/04/18 01:31 AM
04/04/18 01:31 AM
RapidRobert
Robert. Thanks for the reply. The retainer clip that you mention. Are you referring to a "U" shaped clip like the one used on the trunk lock cylinder? If so, the E-Body handle does not use that clip. David Dave, Yes I was thinking that U clip was across the board, I am learning too, my buddy has an E body but he is extremely busy/hard to schedule a common time. I have an E body stock car but it was a stripped out shell when I got it.
[Re: NANKET]
#2477573
04/04/18 09:31 PM
04/04/18 09:31 PM
RapidRobert
Robert. This has baffled me for a long time now so I have to ask. Why do you respond when you openly admit to not knowing the correct answer? Why not just read when the the answers come in? After thinking about this overnight I came to the conclusion that yes you are right, misinformation is misinformation (no matter what the intent) so I will tighten up my game. thank you for the enlightenment.
