588 cubes #2475860
04/02/18 07:48 AM
04/02/18 07:48 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
What's your guys thoughts on a 588 build? I have the option of buying an aftermarket shortblock with a Molnar crank, GRD alloy rods & Diamond pistons. The crank & rods are new, pistons have seen some action. Is this a good combo? I see a lot of 572 & 604 combos, 588 seems to be a bit of an orphan but keen to hear opinions.
Re: 588 cubes [Re: rebel] #2475867
04/02/18 08:53 AM
04/02/18 08:53 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Good combo. Lots of torque. A 572 is 4.50 bore x 4.50 stroke. So, a 588 is a little more of either. A good head will go a long way. I'm building a 605, 4.625 stroke x 4.560 bore, with an Indy solid block and B1 heads. Pistons are specific for Indy heads vs. B1 heads.
[image][/image]
Re: 588 cubes [Re: rebel] #2475881
04/02/18 09:51 AM
04/02/18 09:51 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I just purchased a Molnar crank. Seems to be a nice piece. A 588 is generally a 4.560" bore 4.500 stroke. It's at max bore for standard bore spacing.
Doug
Re: 588 cubes [Re: dvw] #2475884
04/02/18 10:02 AM
04/02/18 10:02 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I had Todd at Marsh performance build Me a 588 for my 68 Cuda street car. 4.5 bore 4.625 stroke. It made 960 horsepower and 860 foot pounds of torque. It's an awesome combo......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 588 cubes [Re: Old School] #2476014
04/02/18 12:35 PM
04/02/18 12:35 PM
Penna
70satelliteguy Offline
Penna
"It's an awesome combo....."
Old school could you give some details?
Re: 588 cubes [Re: rebel] #2476023
04/02/18 12:49 PM
04/02/18 12:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Id say 4.500 X 4.625 is the Mopar std for a 588. IMO just need a good set of heads to support the cubes.
Re: 588 cubes [Re: 70satelliteguy] #2476029
04/02/18 12:55 PM
04/02/18 12:55 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Sure. Indy aluminum RB Block. Indy 572 - 13 heads, they flow 410 CFM. 14.1 cr. .800" 290@.050 solid roller cam... It's in a 68 Cuda Fastback with a passion 5-speed Overdrive.
On the dyno graph the top two lines are with an indy 3x manifold and Dominator. The lower two or with a Mopar 337 and 850 double Pumper. The double pumper and 337 manifold really choked it down!
Screenshot_2016-08-01-11-32-07.pngScreenshot_2016-08-01-11-32-07.pngScreenshot_2016-08-01-11-31-46.png
Re: 588 cubes [Re: dvw] #2476035
04/02/18 01:01 PM
04/02/18 01:01 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Doug
Molnar is nice stuff...I have his crank and rods in the Arrow.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 588 cubes [Re: Old School] #2476066
04/02/18 01:29 PM
04/02/18 01:29 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
What are you using for clutching behind that 572 ???
Re: 588 cubes [Re: rebel] #2476068
04/02/18 01:31 PM
04/02/18 01:31 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
4.375 bore and 4.625 crank is the most popular and make gobs of torque.
I'm a fan
Re: 588 cubes [Re: Sammy] #2476073
04/02/18 01:38 PM
04/02/18 01:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I'm a fan
FYI that would be 566" and cant say I've ever heard anyone running one like that
Re: 588 cubes [Re: rebel] #2476076
04/02/18 01:40 PM
04/02/18 01:40 PM
ky
68roadrunner Offline
ky
4.625 stroke, i wonder what the longevity of the bearings are beating on it in a bracket car turning it 7k?
Re: 588 cubes [Re: RATTRAP] #2476083
04/02/18 01:57 PM
04/02/18 01:57 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
It's 588 cubic inches. I use a McLeod dual disk clutch. I expect zero problems with it
Re: 588 cubes [Re: Sammy] #2476088
04/02/18 02:07 PM
04/02/18 02:07 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I'm a fan
At that small of a bore, it would really shroud the valves and not let it breathe.....
Re: 588 cubes [Re: Old School] #2476128
04/02/18 02:48 PM
04/02/18 02:48 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
[quote=Old School]It's 588 cubic inches. I use a McLeod dual disk clutch. I expect zero problems with it
What RPM are you going to shift at ? I hear a duel clutch will not be able to handle a higher RPM shift, say around 7800 to 8000 RPM. Anyone else want to chime in!
Re: 588 cubes [Re: rebel] #2476151
04/02/18 03:06 PM
04/02/18 03:06 PM
Washington
madscientist Offline
Washington
The clutch will be a problem if you want to shift above 6000ish.
Re: 588 cubes [Re: madscientist] #2476185
04/02/18 04:20 PM
04/02/18 04:20 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Who told you that? I do it every time I drive and have been for the last 20 years with no problems......๐Ÿ‘
Re: 588 cubes [Re: RATTRAP] #2476187
04/02/18 04:21 PM
04/02/18 04:21 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I will probably shift around 7000. I have been using these clutches for the last 20 years and I have never had a problem with them๐Ÿ‘
Re: 588 cubes [Re: rebel] #2476479
04/02/18 09:58 PM
04/02/18 09:58 PM
sgcuda Offline
sgcuda  Offline
My new mill is 4.625 stroke x 4.560 bore. I will more than likely be using a single disc 10" clutch. Works fine well above the engines potential. Still deciding on Black Magic (Cale Aronson), Advanced (Robe Youngblood) or HRS (Chris Hyatt). You can't go wrong with any of them.
[image][/image]
Re: 588 cubes [Re: rebel] #2476522
04/02/18 11:07 PM
04/02/18 11:07 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
I run a 588 in my 64 Dodge. Engine was built by Todd Goodwin. It runs very strong.
