Crane cams rocker screws #247591
03/09/09 12:14 AM
03/09/09 12:14 AM
A Red State
SNK-EYZ Online tonguue OP
SNK-EYZ  Online Tonguue OP
A Red State
I need to get a set of rocker arm adjusting screws for the DLI Hemi rocker arms.
I was just going to buy a set of Crane Cams billet screws from Summit, but a buddy of mine says that the Crane ones have issues (soft metal or too hard and brittle).
Can anyone shed any light on if there's a real problem?
I'm planning on running a hydraulic cam (he keeps saying I need to go to a mechanical roller cam).
http://store.summitracing.com/partdetail.asp?part=CRN-99802-16&autoview=sku
Thanks!
Re: Crane cams rocker screws [Re: SNK-EYZ] #247592
03/09/09 12:31 AM
03/09/09 12:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Crane has had problems in the past, supposed to be fixed but the stories continue...I'd use either Smith Bros or RAS adjusters...
http://www.pushrods.net/
http://www.rockerarms.com/
Re: Crane cams rocker screws [Re: SNK-EYZ] #247593
03/09/09 02:13 AM
03/09/09 02:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the problem they had with the adjuster screws was about 10 years ago, the problem has been fixed.
Re: Crane cams rocker screws [Re: 451Mopar] #247594
03/09/09 10:55 AM
03/09/09 10:55 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
But Crane is now out of business. There certainly may be some adjusters around, though.
Re: Crane cams rocker screws [Re: BobR] #247595
03/09/09 11:36 AM
03/09/09 11:36 AM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
I replaced all of the adjusters on my rockers last summer. The issue that I had was the treads coming off in the area were the lock nut is tightend. I then replaced the thin lock nuts with ARP 12 point nuts. I have done this on both my race engine and now my street engine. This doubles the tread engagement and makes adjusting the valves easier because now there is some nut for the wrench to grab. In the past adjusting the valves always ended with loosing some blood. NOT anymore!!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Crane cams rocker screws [Re: 451Guy] #247596
03/09/09 05:04 PM
03/09/09 05:04 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Recent mopar engine dyno test had adjusters break. This was a professionally built engine. Are these adj from the same vendor that Crane uses?
Keep old mopars alive.
Re: Crane cams rocker screws [Re: 2boltmain] #247597
03/09/09 05:25 PM
03/09/09 05:25 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
the usual reason they break is from over tightening the locknut. I broke a few and then was told by a friend to use the shortest wrench I had when locking the nut down . Haven't broke one since
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Crane cams rocker screws [Re: 451Guy] #247598
03/09/09 07:16 PM
03/09/09 07:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Maybe a different problem than I remembered?
The issue with them several years ago was the ball end was breaking off. What I was told is they were not hardened correctly?
Re: Crane cams rocker screws [Re: 65dragnet] #247599
03/09/09 09:17 PM
03/09/09 09:17 PM
Texas
6packattk Offline
6packattk  Offline
Texas
I always place thumb on box end of wrench no matter how long wrench is and is guaranteed to torque same on all nuts or bolts and won`t over tighten,works on long or short handled ratchets too.Old indian trick I learned from an old head when I was a railroad machinist for 12 years in 70`s and 80`s.When it has to be precise use torque wrench.Not trying to be smart alec,just passing on some knowledge that works anywhere but especially where you have previously skinned knuckles.....
