Fuel pressure gauge isolator #2475648
04/01/18 11:04 PM
04/01/18 11:04 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I have this gauge and isolator and i keep seeing not to mount it on the firewall (per NHRA and Autometer instructions). However every pic I see that is exactly where it is mounted. So which is right?
eBay-cdwmotorsports
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2475662
04/01/18 11:20 PM
04/01/18 11:20 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I had one of those on a NHRA Stocker. Was mounted on the inner fender by the firewall. Never questioned. On another note, I never liked the gauge it would change pressure with temperature and altitude wasn't very accurate. Autometer makes a digital gauge that is going in my new car.
Real Men shift for themselves
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2475712
04/02/18 12:28 AM
04/02/18 12:28 AM
Washington
madscientist Offline
Washington
I mounted mine on the fender.
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2476027
04/02/18 12:54 PM
04/02/18 12:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Never liked isolators. They are VERY slow to react if there is a problem and the aforementioned issues.
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2476087
04/02/18 02:06 PM
04/02/18 02:06 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
So is there a better mouse trap?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Fuel pressure gauge isolator [Re: BloFish] #2476152
04/02/18 03:10 PM
04/02/18 03:10 PM
Washington
Washington
The best mouse trap is data logging. I don't want all the crap that goes with it at this point. So I just use a gauge.
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2476159
04/02/18 03:20 PM
04/02/18 03:20 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Carburated? 4461. Electric with a transducer. Simple.
Re: Fuel pressure gauge isolator [Re: CMcAllister] #2476168
04/02/18 03:52 PM
04/02/18 03:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you do use a isolator you HAVE to have it FULL
of oil otherwise it will be slow and give a bogus
reading and when I say full I mean ZERO air.. I
used them in the past but now days I use the electric
gauges so I dont need the isolators
wave
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2476176
04/02/18 04:05 PM
04/02/18 04:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I don't think I would use a mechanical gauge for anything anymore except for brake pressure.
Re: Fuel pressure gauge isolator [Re: CMcAllister] #2476222
04/02/18 06:14 PM
04/02/18 06:14 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Autometer also makes a digital gauge 1600 psi for brake pressure.
I run a stick shift car so only need 100-200 psi to hold on the line. It is so much easier to run wire instead of steel line.
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2476250
04/02/18 07:21 PM
04/02/18 07:21 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
I have not seen the rule but I would think that they don't want the fuel side near the flywheel or converter so it won't get cut in the event of a flywheel or trans explosion. On my big block with a tunnel ram I bolt it to the rear of the engine using the valley cover bolts.
Re: Fuel pressure gauge isolator [Re: MR_P_BODY] #2476280
04/02/18 08:07 PM
04/02/18 08:07 PM
Washington
Washington
wave
My isolator uses antifreeze not oil. I didn't know they made an isolator that used oil.
And you do have to get ALL the air out of the line. Or it will drive you bonkers.
Re: Fuel pressure gauge isolator [Re: madscientist] #2476460
04/02/18 09:29 PM
04/02/18 09:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Basically they make any one with a fluid that
doesnt freeze.. mine are oil( a very thin oil)
wave
Re: Fuel pressure gauge isolator [Re: MR_P_BODY] #2476645
04/03/18 08:37 AM
04/03/18 08:37 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I just went thru this a few weeks ago as I moved my fuel pressure gauge from
the cowl to inside the car. I mounted my isolator on the inner fender by the master cylinder. I used 50/50 mix anti- freeze as recommended. It was kind of a pia to get the anti - freeze to the right level to get the gauge to work using a squeeze bottle to add it to the guage and isolator. I also had to bleed the fuel side several times to get it to work. I finally got it right and the car looks better with out the gauge outside we're its been for 35 years.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Fuel pressure gauge isolator [Re: 11secdart] #2476658
04/03/18 10:10 AM
04/03/18 10:10 AM
Martinsville, IN
Martinsville, IN
I dont have inner fenderwells as I have fenderwell headers.
All I use is mechanical gauges. I know they will work no matter what happens unlike data loggers and computers.
I will look into an electrical fuel pressure gauge.
eBay-cdwmotorsports
Re: Fuel pressure gauge isolator [Re: cdwmotorsports] #2478273
04/06/18 12:21 PM
04/06/18 12:21 PM
Martinsville, IN
Martinsville, IN
Sent the mechanical one back ordered an electrical one.
eBay-cdwmotorsports
