Re: Fuel pressure gauge isolator
[Re: cdwmotorsports]
#2475662
04/01/18 11:20 PM
04/01/18 11:20 PM
Posts: 608 TN
1DGEMAN
TN
I had one of those on a NHRA Stocker. Was mounted on the inner fender by the firewall. Never questioned. On another note, I never liked the gauge it would change pressure with temperature and altitude wasn't very accurate. Autometer makes a digital gauge that is going in my new car.
Real Men shift for themselves
#2475712
04/02/18 12:28 AM
04/02/18 12:28 AM
Posts: 4,457 Washington
madscientist
Washington
I mounted mine on the fender.
#2476027
04/02/18 12:54 PM
04/02/18 12:54 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Never liked isolators. They are VERY slow to react if there is a problem and the aforementioned issues.
#2476087
04/02/18 02:06 PM
04/02/18 02:06 PM
Posts: 16,491 On the run…
BloFish
On the run…
So is there a better mouse trap?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2476152
04/02/18 03:10 PM
04/02/18 03:10 PM
madscientist
Washington
So is there a better mouse trap? The best mouse trap is data logging. I don't want all the crap that goes with it at this point. So I just use a gauge.
[Re: CMcAllister]
#2476168
04/02/18 03:52 PM
04/02/18 03:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you do use a isolator you HAVE to have it FULL of oil otherwise it will be slow and give a bogus reading and when I say full I mean ZERO air.. I used them in the past but now days I use the electric gauges so I dont need the isolators
#2476176
04/02/18 04:05 PM
04/02/18 04:05 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't think I would use a mechanical gauge for anything anymore except for brake pressure.
[Re: CMcAllister]
#2476222
04/02/18 06:14 PM
04/02/18 06:14 PM
Posts: 608 TN
1DGEMAN
TN
I don't think I would use a mechanical gauge for anything anymore except for brake pressure. Autometer also makes a digital gauge 1600 psi for brake pressure. I run a stick shift car so only need 100-200 psi to hold on the line. It is so much easier to run wire instead of steel line.
[Re: MR_P_BODY]
#2476280
04/02/18 08:07 PM
04/02/18 08:07 PM
madscientist
Washington
If you do use a isolator you HAVE to have it FULL of oil otherwise it will be slow and give a bogus reading and when I say full I mean ZERO air.. I used them in the past but now days I use the electric gauges so I dont need the isolators My isolator uses antifreeze not oil. I didn't know they made an isolator that used oil. And you do have to get ALL the air out of the line. Or it will drive you bonkers.
[Re: madscientist]
#2476460
04/02/18 09:29 PM
04/02/18 09:29 PM
MR_P_BODY
If you do use a isolator you HAVE to have it FULL of oil otherwise it will be slow and give a bogus reading and when I say full I mean ZERO air.. I used them in the past but now days I use the electric gauges so I dont need the isolators My isolator uses antifreeze not oil. I didn't know they made an isolator that used oil. And you do have to get ALL the air out of the line. Or it will drive you bonkers. Basically they make any one with a fluid that doesnt freeze.. mine are oil( a very thin oil)
[Re: MR_P_BODY]
#2476645
04/03/18 08:37 AM
04/03/18 08:37 AM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I just went thru this a few weeks ago as I moved my fuel pressure gauge from the cowl to inside the car. I mounted my isolator on the inner fender by the master cylinder. I used 50/50 mix anti- freeze as recommended. It was kind of a pia to get the anti - freeze to the right level to get the gauge to work using a squeeze bottle to add it to the guage and isolator. I also had to bleed the fuel side several times to get it to work. I finally got it right and the car looks better with out the gauge outside we're its been for 35 years.
[Re: 11secdart]
#2476658
04/03/18 10:10 AM
04/03/18 10:10 AM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
I just went thru this a few weeks ago as I moved my fuel pressure gauge from the cowl to inside the car. I mounted my isolator on the inner fender by the master cylinder. I used 50/50 mix anti- freeze as recommended. It was kind of a pia to get the anti - freeze to the right level to get the gauge to work using a squeeze bottle to add it to the guage and isolator. I also had to bleed the fuel side several times to get it to work. I finally got it right and the car looks better with out the gauge outside we're its been for 35 years. I dont have inner fenderwells as I have fenderwell headers. I don't think I would use a mechanical gauge for anything anymore except for brake pressure. All I use is mechanical gauges. I know they will work no matter what happens unlike data loggers and computers. I will look into an electrical fuel pressure gauge.
eBay-cdwmotorsports
