Re: LAST TIME T&T I SWEAR...............
[Re: Sport440]
#2475462
04/01/18 04:46 PM
04/01/18 04:46 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
[/quote] I see the problem Thump, When you launch get a 1.34 60 ft pull her into second. You don't then pound on the brakes, you pound on the throttle. Problem solved. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) [/quote] Dom unless you are going toward the wall or the centerline, stay on it! If you get the BIG # then get kicked out. You accomplished a goal and save wear and tear on slicks, engine and fuel. It takes seat time to get used to the track, just like it did for the street. Good luck buddy! Don
[Re: Thumperdart]
#2475674
04/01/18 11:33 PM
04/01/18 11:33 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Dom, it wouldn't hurt to sit in your car before a race, and mentally as well as physically go through your chosen routine as many as 100 times! When you pull to the line the next time, you will not have any distracting thoughts, you know you are doing the right sequence of things!
[Re: cudadon]
#2475687
04/01/18 11:47 PM
04/01/18 11:47 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Dom unless you are going toward the wall or the centerline, stay on it! If you get the BIG # then get kicked out. You accomplished a goal and save wear and tear on slicks, engine and fuel. Good luck buddy! Don [/quote] Hindsight is 20/20, wish you would of stayed in it on that wheelie 1.34 60 ft. pass. Understand the issue of being kicked out, but that was the run you should of went with. Again though, hindsight is 20/20 ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Thumperdart]
#2475885
04/02/18 10:11 AM
04/02/18 10:11 AM
Posts: 570 UK
rb446
UK
All things being equal if you had stayed in it your ticket should've looked like this on that run> 60 Foot E.T. : 1.34 1/8 Mile E.T. : 6.06 1/8 Mile Trap Speed : 112.12 1/4 Mile E.T. : 9.61 1/4 Mile Trap Speed : 139 ![cool cool](/ubbthreads/images/graemlins/custom/cool.gif)
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Thumperdart]
#2475909
04/02/18 10:50 AM
04/02/18 10:50 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
As inconsistent as the track prep seems to be where you race and you chasing ET...you KNEW it was on a helluva run that first pass leaving hard w/ the wheels in the air, so why in the world did you lift???
[Re: an8sec70cuda]
#2476060
04/02/18 01:25 PM
04/02/18 01:25 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
As inconsistent as the track prep seems to be where you race and you chasing ET...you KNEW it was on a helluva run that first pass leaving hard w/ the wheels in the air, so why in the world did you lift??? Just my guess but I think Dom did the first couple hits to make sure his launch and 60' Were where he wanted them as He and his car aren't certified to go as quick as he planned to go on his last hit of the Night which got cut short for his last run. Had he got that last hit he would've gotten a talking to and Dominic has no plans of upgrading his car for the few times he hits the track. Street Racer.... ![apimp apimp](/ubbthreads/images/graemlins/custom/apimp.gif)
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#2476064
04/02/18 01:28 PM
04/02/18 01:28 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you plan to abort a run go to at least the 330 timer. You will gain a lot more info to log.
[Re: an8sec70cuda]
#2476122
04/02/18 02:40 PM
04/02/18 02:40 PM
Thumperdart
State of confusion
As inconsistent as the track prep seems to be where you race and you chasing ET...you KNEW it was on a helluva run that first pass leaving hard w/ the wheels in the air, so why in the world did you lift??? Been doin it that way for years w/good results sometimes but as pointed out the fist passes there are the best due to all of the street vehicles that kill the hook so next time one and done........... ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Thumperdart]
#2476486
04/02/18 10:10 PM
04/02/18 10:10 PM
dartman366
Mt. Vernon, Ohio
I agree with Pittsburgh racer on this one, try to get it to the 330' mark then you have some info to work with.
[Re: rb446]
#2476518
04/02/18 11:01 PM
04/02/18 11:01 PM
Sport440
Canton, Ohio
All things being equal if you had stayed in it your ticket should've looked like this on that run> 60 Foot E.T. : 1.34 1/8 Mile E.T. : 6.06 1/8 Mile Trap Speed : 112.12 1/4 Mile E.T. : 9.61 1/4 Mile Trap Speed : 139 That could of been a new best. ![cool cool](/ubbthreads/images/graemlins/custom/cool.gif)
[Re: Sport440]
#2476634
04/03/18 03:56 AM
04/03/18 03:56 AM
Thumperdart
State of confusion
Agreed and I went a 1.40 6.15 @ 112.05 already...........
[Re: Thumperdart]
#2476832
04/03/18 04:04 PM
04/03/18 04:04 PM
Posts: 861 lancaster,california
johnnycuda
Is the Ford on spray from over here in Lancaster?
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: johnnycuda]
#2476945
04/03/18 07:05 PM
04/03/18 07:05 PM
Thumperdart
State of confusion
No, it's from Vegas or at least that's where he lived a while back but may move back here...............
