727 Trans Brake Experience and Suggestions #2474671
03/31/18 12:23 AM
03/31/18 12:23 AM
MI, USA
moparmitch Offline OP
MI, USA
Hello All,
I have an older Turbo Action 727 Tranz Brake (#17998) that I'll be using for bracket racing. I have not used this setup before and I'm wondering which make of t-brakes you guys use and have proven to be reliable and great performers, especially without any tendency to creep...
I let a friend borrow my trans setup and he had to carry approximately 2000rpm for the turbo action brake to hold steady without any creep. If I run into this same issue, I'll be looking for a better brake that is rock solid without the need for extra rpm to function.
I see products from Cope, Griner, ATI, TCI, etc...
Which has worked for you?
Thanks!
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474674
03/31/18 12:36 AM
03/31/18 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was running a TA brake since I built my car
and it only wouldnt hold unless it was reved up
to around 2000rpms.. had TA send a new part
and its been fine since
wave
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474765
03/31/18 08:53 AM
03/31/18 08:53 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I run a Griner brake that I got from John Cope in 2005. It holds rock steady at 1400 rpms.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474817
03/31/18 11:41 AM
03/31/18 11:41 AM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
I don't think 2000 rpms is bad, I was taught positive displacement pump needs more rpms to set brake. I always power brake when stageing, and then set the brake. And keep up with band adjustments
Re: 727 Trans Brake Experience and Suggestions [Re: MR_P_BODY] #2474821
03/31/18 11:53 AM
03/31/18 11:53 AM
MI, USA
MI, USA
What was the new part TA sent you that fixed the creep?
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474828
03/31/18 12:02 PM
03/31/18 12:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My Griners (2), Tranzact, and currently Pro Trans brakes all lock in at around 1000 rpm. Only "creep" issue I had was with the 727 that had the Tranzact brake and it was the stator support seals that were worn, not the brake itself.
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474845
03/31/18 12:37 PM
03/31/18 12:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The brake itself has 2 parts.. the guy that use
to do my trans work had the same issue so after
checking we found that a crack had developed in
a wall of the brake(after contacting TA he sent
2 this was a error on the build.. that wall would
flex back and forth and finally cracked.. if I
recall right that part was $35...after installing
both brakes were great.. the fix was to put a radius
in on that wall).. its still running great today
EDIT
One thing I like about the TA brake is that I dont
use a button to get into reverse.. just shift to
reverse
wave
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474850
03/31/18 12:46 PM
03/31/18 12:46 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I have Copes brake and it works great
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474873
03/31/18 01:50 PM
03/31/18 01:50 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Set up the 12V to not only apply the trans. brake but the line lock as well. Your last move before pushing the button is to apply brake pressure with the pedal so why not? My Challenger and other door cars I know of are wired this way. It is an option on some delay boxes so no extra wire needed.
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474875
03/31/18 01:59 PM
03/31/18 01:59 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Got 4 of the tranzact brakes in use, one was bought back in 1993. the other 3 are the newer billet valve body.
Tony
70 AARCuda Vitamin C
Re: 727 Trans Brake Experience and Suggestions [Re: Dave Hall] #2474896
03/31/18 02:46 PM
03/31/18 02:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I only use my line lock in the burn out so I
dont want the brake on then
wave
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2474981
03/31/18 06:36 PM
03/31/18 06:36 PM
MI, USA
MI, USA
Do the billet based brakes perform better than the cast/oem pieces?
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2475006
03/31/18 07:19 PM
03/31/18 07:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The newer unit release a bit quicker.. I dont
know why they do but what are you going for
wave
Re: 727 Trans Brake Experience and Suggestions [Re: 70AARcuda] #2475007
03/31/18 07:19 PM
03/31/18 07:19 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
X2 on the tranzact, mine worked perfectly.
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2475011
03/31/18 07:21 PM
03/31/18 07:21 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I've been running the same T/A brake since the early 90's and it's always held from idle to WOT. Your friend might have had a leaky trans or weak pump.
Re: 727 Trans Brake Experience and Suggestions [Re: a493demon] #2475078
03/31/18 09:26 PM
03/31/18 09:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I just went with a Cope unit and love it, I have used Turbo Actions for many years with great success. up
Re: 727 Trans Brake Experience and Suggestions [Re: dartman366] #2475084
03/31/18 09:51 PM
03/31/18 09:51 PM
MI, USA
MI, USA
Is there a performance or behavior difference between the Cope and the TA?
Re: 727 Trans Brake Experience and Suggestions [Re: MR_P_BODY] #2475087
03/31/18 09:57 PM
03/31/18 09:57 PM
MI, USA
MI, USA
I'm just wanting a t-brake that is solid and doesn't creep, pretty basic...
I've spoken to several local racers in the last year or two who have complained about turbo action brakes creeping, with the end result being a switch to another manufactures product. There may have been other transmission issues contributing to the TAs poor performance, but who knows...?
Thanks to all for sharing your thoughts, much appreciated!
Re: 727 Trans Brake Experience and Suggestions [Re: moparmitch] #2475088
03/31/18 09:59 PM
03/31/18 09:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the applications were different, the Ta's were in 904"s and the Cope went in a 727 so I do not have an apples to apples comparison, the TA's are non low band apply while the Cope is LBA, the Cope is also a pro brake the TA's are not, I think the Ta's have always served me well but I don't think they leave quite as well as the Cope, altho I have not changed the delay in my box and my lights are about the same.
