Re: 727 Trans Brake Experience and Suggestions
[Re: moparmitch]
#2474674
03/31/18 12:36 AM
03/31/18 12:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was running a TA brake since I built my car and it only wouldnt hold unless it was reved up to around 2000rpms.. had TA send a new part and its been fine since
[Re: moparmitch]
#2474765
03/31/18 08:53 AM
03/31/18 08:53 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I run a Griner brake that I got from John Cope in 2005. It holds rock steady at 1400 rpms.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: moparmitch]
#2474845
03/31/18 12:37 PM
03/31/18 12:37 PM
MR_P_BODY
What was the new part TA sent you that fixed the creep? The brake itself has 2 parts.. the guy that use to do my trans work had the same issue so after checking we found that a crack had developed in a wall of the brake(after contacting TA he sent 2 this was a error on the build.. that wall would flex back and forth and finally cracked.. if I recall right that part was $35...after installing both brakes were great.. the fix was to put a radius in on that wall).. its still running great today EDIT One thing I like about the TA brake is that I dont use a button to get into reverse.. just shift to reverse
[Re: moparmitch]
#2474875
03/31/18 01:59 PM
03/31/18 01:59 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Got 4 of the tranzact brakes in use, one was bought back in 1993. the other 3 are the newer billet valve body.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: a493demon]
#2475078
03/31/18 09:26 PM
03/31/18 09:26 PM
dartman366
Mt. Vernon, Ohio
I have Copes brake and it works great I just went with a Cope unit and love it, I have used Turbo Actions for many years with great success.
[Re: moparmitch]
#2475088
03/31/18 09:59 PM
03/31/18 09:59 PM
dartman366
Mt. Vernon, Ohio
Is there a performance or behavior difference between the Cope and the TA? the applications were different, the Ta's were in 904"s and the Cope went in a 727 so I do not have an apples to apples comparison, the TA's are non low band apply while the Cope is LBA, the Cope is also a pro brake the TA's are not, I think the Ta's have always served me well but I don't think they leave quite as well as the Cope, altho I have not changed the delay in my box and my lights are about the same.
