Hood Hinges #2473919
03/29/18 05:19 PM
03/29/18 05:19 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
The hood hinges on my 69 Coronet are "lazy". That is, when I close the hood I have to go to the back of the hood and push the corners down.
Is this because the springs have lost some of their spring, or is the rest of the hinge just worn out, or both?
Has anyone else had this problem? I know AMD sells them, but does anyone sell just the spring?
Re: Hood Hinges [Re: 3_RTs] #2473924
03/29/18 05:28 PM
03/29/18 05:28 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Pivot points may be worn? Resto Rick can rebuild them.
Re: Hood Hinges [Re: 3_RTs] #2474066
03/29/18 10:02 PM
03/29/18 10:02 PM
Minn
SportF Offline
SportF  Offline
Minn
I would say the hinges are out of adjustment if you have to push the back corners down. It is certainly that way on the 62-65 cars. Don't know if that newer B body is much different, but I doubt it.
If it is an adjustment, boy, can that be "fun". And moving the hinge in the right direction is really a guessing game.
If your car was an early car as mentioned, I would raise the rear, and lower the front of the hinge to fix that. That doesn't seem right, but it is. Best of luck to you.
Re: Hood Hinges [Re: SportF] #2474455
03/30/18 04:49 PM
03/30/18 04:49 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks, guys, for the suggestions. If the adjustments don't work, I will contact Resto-Rick.
Re: Hood Hinges [Re: 3_RTs] #2474519
03/30/18 07:42 PM
03/30/18 07:42 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Read his post on how to adjust a hood that will not go down in the back.
