Re: 2 Post or 4 Post Lift?
[Re: 69dart]
#2473835
03/29/18 02:41 PM
03/29/18 02:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have owned a 2 post for 15 years.. bought it used.. am getting ready to buy another hoist and its going to be another 2 post.. I can do about 90% of my work on a 2 post.. I might even look at a 4 post also but on rollers
[Re: 69dart]
#2473838
03/29/18 02:43 PM
03/29/18 02:43 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
2 post takes up very little floor space. You can put the arms up when not in use and use the space. Also easier to work under the car, around the car, etc. I've used both and have a 2 post in my shop with no regrets. Yes, I have to use a floor jack to get the arms under some of the low stuff.
[Re: 69dart]
#2473840
03/29/18 02:44 PM
03/29/18 02:44 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
For jobs where you don't need to remove the wheels, a 4 post is easiest. You drive on, and raise it up. But the ramps hinder access to the wheels and under the rockers. A 2 post is harder to lift the car, you have to swing the arms into place. But then the wheels are hanging, you you have unrestricted access to 95% of the underside. So it depends on the type of work you plan to do.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 69dart]
#2473855
03/29/18 03:36 PM
03/29/18 03:36 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
2 post, easy choice for me. Takes up less floor space and maximum access to the underside for the car. A 4 post is just a PITA to me. Most low cars still have trouble getting on a 4 post lift too.
[Re: 69dart]
#2473897
03/29/18 04:48 PM
03/29/18 04:48 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
I think it depends on you what you are doing and why you want a lift. If you are guy that primarily does oil change type work or like to clean the car or using it simply for additional storage of two cars where one would fit then use a 4 post. If you are a guy who does most of your own work on your cars then a 2 post is by far more versatile a tool than the 4 post variety.
[Re: CMcAllister]
#2473927
03/29/18 05:31 PM
03/29/18 05:31 PM
MR_P_BODY
I laugh because I said the same thing. Don't kid yourself. When I got my shop done and walked in before there was a thing in it, it looked like an aircraft hanger. Now? It's crowded, I have to move stuff around all the time to get it out of my way and I'm going to get an estimate on a cold storage addition soon. LOL.. a shop is never big enough and you can never have enough light.. I have my shop basically broke down into 3rd.. the one third is my machine shop and welding area.. the center is the hoist area and the far section is storage area for my 38 Ply and my small trailer(goes behind the Rampage.. I wanted 2000sqft but the township shut that down.. I have 1200sqft in the shop and a 2000sqft pole barn and the wifes garage... I do have a office and a clean room thats part of the machine shop area.. they are all small if you ask me
[Re: MR_P_BODY]
#2473933
03/29/18 05:47 PM
03/29/18 05:47 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
No matter which one you get buy it and enjoy it ASAP. I've been working on my back for 44 plus years and will never have a lift, but I sure would have loved one. I finally bought a used Quick Lift 6 years or so ago and it helps some. Last years transmission issues about wore me out pulling and installing my transmission 6 or 7 times by myself on the floor. I built my 28-36 shop in 1991 with 8 foot ceilings and was so used to working on my back and knees from doing Millwright work I never thought about my old age years. https://www.kwik-lift.com/
[Re: pittsburghracer]
#2473950
03/29/18 06:19 PM
03/29/18 06:19 PM
MR_P_BODY
The one reason I am replacing my 2 post hoist is that its a little short on vertical lift.. I'm sick of banging my head and the new one I'm going to buy will lift another 10 above the one I have now... this new one has lower arms on it also.. my Rampage is VERY LOW and the arms will still get under it.. my buddy has one right now and I love it.. I have plenty of over head clearance
[Re: 69dart]
#2473961
03/29/18 06:54 PM
03/29/18 06:54 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Best money spent. Maybe a toss up with A/C. I was putting gears in a 7.5 in a Trans Am or something and cracked my head getting up from under it for about the hundredth time. Put tools down, wiped my hands off, called the parts store and ordered it. Express. Didn't even ask the price.
[Re: 69dart]
#2474015
03/29/18 08:30 PM
03/29/18 08:30 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I have both . For 2 post get a clear floor type, but this needs a higher ceiling . Way better if pulling transmissions With a 4 post i have a air operated scissor lift that slides end to end for wheels off work
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 69dart]
#2474021
03/29/18 08:41 PM
03/29/18 08:41 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I had a version of this at the dealer. I loved it. Building a new workspace next year, and this is part of it. I am limited to 1000 sq ft in my neighborhood so space is at a premium. The benefits, they take up no space, they give you a table area for brake work, doesn’t matter how low your car is, can use as a motorcycle/ atv lift etc... Drawbacks are washing the floor or spills fill the pits, initial install is trickier than a flat floor. Not horribly difficult to do to an existing floor. Cost for hoist set is cheaper than a two post in most cases( under 10,000 lbs). That doesn’t factor in the floor cost though. https://youtu.be/JcJAnEcCsnM
[Re: CMcAllister]
#2474025
03/29/18 08:49 PM
03/29/18 08:49 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I'm fortunate to have one of each now.
Started with an asymmetric 2 post based on consulting with numerous people more experienced with shop hoists than I was. My original leaning had been a four post, like you. I've never regretted the decision.
The only thing that bugs me is if I'm going to have a big car sitting on the hoist for a long time (as in a day or two) I start worrying about the rear end and suspension hanging there unsupported and the stress on the body. My biggest concern came when I did the brakes on a 70 convertible. I put screw type jack stands under the rear end to provide some support while the convertible was up there for a couple days.
As it is you can see the body of most any car move around some when using this style lift by watching the door gaps. I'm not talking about rusty, patched up bodies, either. Perhaps I'm over thinking this entire subject. The cars always come right back in line when I set them back down. It just bugs me. You're lifting a unibody car from the ends of the front and rear frame rails, so the engine is hanging out front and rear end hanging out back, along with all that rear end sheet metal, gas tank, etc.
Access under the car with a 2 post is very nice. When I installed the four post I quickly realized you have to stoop down to get under the ramps to work under the car. Remember the ramps are below the wheels, and are 4-6" thick, so you need to stoop over a fair amount to clear.
That I found to be a pain in the rear, especially when you're going back and forth a lot. That is much more irritating to me than kneeling down to place the arms on the 2 post.
The second thing I don't like is the ramps are hanging out there at the back, at an elevation that it's just a matter of time before you walk into one of them. I speak from experience and wrap foam around the leading edge of each.
Finally, the wheel kit is handy, but in my case at least, even with a good floor, it's enough work to push it around that I don't care to do it very often. I'm using my 4 post more for storage than work.
One last thought on a 4 post. Get the wider version if at all possible. Many of the standard ones are quite narrow between posts when you're dealing with a full size car or a truck.
Lead, follow or get the hell out of the way
[Re: 69dart]
#2474414
03/30/18 03:12 PM
03/30/18 03:12 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
Another vote for 2 post. I agree with most of what's been said so far - 2 post takes less room and allows more access under the car. IMO, a 4 post isn't good for much except storage. A 2 post can be used for short term storage too. If you have the height, 2 post is best.
As for what was mentioned about having doors open while in the air - I'm not sure that's terribly relevant because in general, you wouldn't have the doors open while the car is up in the air. Besides, you can open them depending on how the car is set up. If the doors are open, it's probably best that the car is on the ground anyway.
Someone mentioned that a 2 post lift can be tougher to get a car on which isn't really a fair comparison. Backing a car off a 4 post lift can be tricky sometimes if you have limited sight lines or obstacles around the lift. Sliding the lift arm underneath the car is not hard unless you have mobility issues or the car is really low. Even if it's low, you just use little blocks to raise the car up a bit before sliding the lift arm under. Once you do it a few times, it will become second nature. You could even put some sort of mark on the floor or wall so the car is in the same spot every time.
2 post is also good for attaching an air hose reel so you will have easy access to it.
But whatever you do, don't buy a cheap off-shore one!
'71 Duster '72 Challenger '17 Ram 1500
[Re: 69dart]
#2474418
03/30/18 03:17 PM
03/30/18 03:17 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
2 post for sure... have used both and I'd never consider buying a 4 post for anything but storage.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
