2 Post or 4 Post Lift? #2473825
03/29/18 02:13 PM
03/29/18 02:13 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I'm getting close to finishing up my new shop (actually painting this weekend) and I'm curious what is the easiest lift to use in a novices shop?
I know my limits so I doubt I'll be doing body swaps or anything crazy.
Just routine racecar maintenance and daily driver stuff.
I'm leaning towards a 4 Post for ease of use. My cars all sit pretty low and laying on the floor adjusting the 2 post arms sounds like no fun.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473835
03/29/18 02:41 PM
03/29/18 02:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have owned a 2 post for 15 years.. bought
it used.. am getting ready to buy another hoist
and its going to be another 2 post.. I can do
about 90% of my work on a 2 post.. I might even
look at a 4 post also but on rollers
wave
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473838
03/29/18 02:43 PM
03/29/18 02:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
2 post takes up very little floor space. You can put the arms up when not in use and use the space. Also easier to work under the car, around the car, etc. I've used both and have a 2 post in my shop with no regrets. Yes, I have to use a floor jack to get the arms under some of the low stuff.
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473840
03/29/18 02:44 PM
03/29/18 02:44 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
For jobs where you don't need to remove the wheels, a 4 post is easiest. You drive on, and raise it up. But the ramps hinder access to the wheels and under the rockers. A 2 post is harder to lift the car, you have to swing the arms into place. But then the wheels are hanging, you you have unrestricted access to 95% of the underside. So it depends on the type of work you plan to do.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473855
03/29/18 03:36 PM
03/29/18 03:36 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
2 post, easy choice for me. Takes up less floor space and maximum access to the underside for the car. A 4 post is just a PITA to me. Most low cars still have trouble getting on a 4 post lift too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473860
03/29/18 03:44 PM
03/29/18 03:44 PM
IL
Dart451 Offline
Dart451  Offline
IL
Really depends on size of shop, and work you plan on doing.
4-post
pro
Simple oil change or underside inspection. Use it to scale car(Easy to adjust the stops so its level). You also have a shelf to set tools and parts on. I move it around my shop to different locations and store a car all winter on it.
cons
Takes a lot of space when not used. Make sure on wider cars the mirrors don't hit the posts. The antenna on the lower car can snag. I do not have the lift jacks to raise the wheels off the lift so no brake work or tire rotations. The ramps are fairly heavy, probably can get some lighter aluminum ones
2 post
pro
All tires, suspension, and brakes easy to work on. Takes less shop space when not used.
cons
I can not move the lift around and sometimes it just in my way, Always have to crawl around to position lift arms, and I always seem to have the tool I need out of reach.
I would keep the two post if I only had one lift. Tire rotation and brake work is often at my house.
Re: 2 Post or 4 Post Lift? [Re: an8sec70cuda] #2473862
03/29/18 03:45 PM
03/29/18 03:45 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I'm thinking about this one.
NSS-8 8,000 lb Service Storage Four Post Automotive Lift
https://nationalautotools.com/products/nss-8-service-storage-four-post-automotive-lift
It comes with casters.
I'm not sure space is huge concern right now. The shop is 30x40 and I only have a couple cars right now.
68 Dart - 340
66 Belvedere - 400
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473880
03/29/18 04:28 PM
03/29/18 04:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
laugh2
I laugh because I said the same thing. Don't kid yourself. When I got my shop done and walked in before there was a thing in it, it looked like an aircraft hanger. Now? It's crowded, I have to move stuff around all the time to get it out of my way and I'm going to get an estimate on a cold storage addition soon.
Re: 2 Post or 4 Post Lift? [Re: CMcAllister] #2473895
03/29/18 04:46 PM
03/29/18 04:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree They just finished a new industrial building near me (about 200' square) and, as I drove by this morning, I was thinking it'd take me about a year to fill that.
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473897
03/29/18 04:48 PM
03/29/18 04:48 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think it depends on you what you are doing and why you want a lift. If you are guy that primarily does oil change type work or like to clean the car or using it simply for additional storage of two cars where one would fit then use a 4 post. If you are a guy who does most of your own work on your cars then a 2 post is by far more versatile a tool than the 4 post variety.
Re: 2 Post or 4 Post Lift? [Re: CMcAllister] #2473927
03/29/18 05:31 PM
03/29/18 05:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
laugh2
LOL.. a shop is never big enough and you can never have
enough light.. I have my shop basically broke down into
3rd.. the one third is my machine shop and welding area..
the center is the hoist area and the far section is storage
area for my 38 Ply and my small trailer(goes behind the
Rampage.. I wanted 2000sqft but the township shut that
down.. I have 1200sqft in the shop and a 2000sqft pole barn
and the wifes garage... I do have a office and a clean room
thats part of the machine shop area.. they are all small
if you ask me
wave
Re: 2 Post or 4 Post Lift? [Re: MR_P_BODY] #2473933
03/29/18 05:47 PM
03/29/18 05:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
No matter which one you get buy it and enjoy it ASAP. I've been working on my back for 44 plus years and will never have a lift, but I sure would have loved one. I finally bought a used Quick Lift 6 years or so ago and it helps some. Last years transmission issues about wore me out pulling and installing my transmission 6 or 7 times by myself on the floor. I built my 28-36 shop in 1991 with 8 foot ceilings and was so used to working on my back and knees from doing Millwright work I never thought about my old age years.
https://www.kwik-lift.com/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473944
03/29/18 06:07 PM
03/29/18 06:07 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I hope to be in a very similar boat in the next 12-16 months and the only thing that keeps me looking towards a 4 post lift is that it would be a better option (I feel) for storing cars/parking under a lifted car. I'll be using mine for this purpose as much as other uses. Ill just need to buy the jack that connects to the lift to remove wheels.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 2 Post or 4 Post Lift? [Re: pittsburghracer] #2473950
03/29/18 06:19 PM
03/29/18 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The one reason I am replacing my 2 post hoist
is that its a little short on vertical lift..
I'm sick of banging my head and the new one I'm
going to buy will lift another 10 above the one
I have now... this new one has lower arms on it
also.. my Rampage is VERY LOW and the arms will
still get under it.. my buddy has one right now
and I love it.. I have plenty of over head clearance
wave
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2473961
03/29/18 06:54 PM
03/29/18 06:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Best money spent. Maybe a toss up with A/C. I was putting gears in a 7.5 in a Trans Am or something and cracked my head getting up from under it for about the hundredth time. Put tools down, wiped my hands off, called the parts store and ordered it. Express. Didn't even ask the price.
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2474015
03/29/18 08:30 PM
03/29/18 08:30 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I have both . For 2 post get a clear floor type, but this needs a higher ceiling . Way better if pulling transmissions
With a 4 post i have a air operated scissor lift that slides end to end for wheels off work
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2474021
03/29/18 08:41 PM
03/29/18 08:41 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I had a version of this at the dealer. I loved it. Building a new workspace next year, and this is part of it. I am limited to 1000 sq ft in my neighborhood so space is at a premium. The benefits, they take up no space, they give you a table area for brake work, doesn’t matter how low your car is, can use as a motorcycle/ atv lift etc...
Drawbacks are washing the floor or spills fill the pits, initial install is trickier than a flat floor. Not horribly difficult to do to an existing floor.
Cost for hoist set is cheaper than a two post in most cases( under 10,000 lbs). That doesn’t factor in the floor cost though.
https://youtu.be/JcJAnEcCsnM
Re: 2 Post or 4 Post Lift? [Re: 69dart] #2474024
03/29/18 08:48 PM
03/29/18 08:48 PM
Cochise Co, Az, From Detroit
moetown Offline
moetown  Offline
As a former longgg time mechanic I would have a 2 post lift.
A 4 post is safer for a novice to use, no arms to move around. But is a pain to use to actually work on a car, but good to use for extra car storage, no tires hanging down.
This is the 2 post lift I will be getting for my 30x40 pole barn this summer.
http://www.gregsmithequipment.com/Elite-9KOH
Re: 2 Post or 4 Post Lift? [Re: CMcAllister] #2474025
03/29/18 08:49 PM
03/29/18 08:49 PM
Minnesota
peabodyracing Offline
Minnesota
I'm fortunate to have one of each now.
Started with an asymmetric 2 post based on consulting with numerous people more experienced with shop hoists than I was. My original leaning had been a four post, like you. I've never regretted the decision.
The only thing that bugs me is if I'm going to have a big car sitting on the hoist for a long time (as in a day or two) I start worrying about the rear end and suspension hanging there unsupported and the stress on the body. My biggest concern came when I did the brakes on a 70 convertible. I put screw type jack stands under the rear end to provide some support while the convertible was up there for a couple days.
As it is you can see the body of most any car move around some when using this style lift by watching the door gaps. I'm not talking about rusty, patched up bodies, either. Perhaps I'm over thinking this entire subject. The cars always come right back in line when I set them back down. It just bugs me. You're lifting a unibody car from the ends of the front and rear frame rails, so the engine is hanging out front and rear end hanging out back, along with all that rear end sheet metal, gas tank, etc.
Access under the car with a 2 post is very nice. When I installed the four post I quickly realized you have to stoop down to get under the ramps to work under the car. Remember the ramps are below the wheels, and are 4-6" thick, so you need to stoop over a fair amount to clear.
That I found to be a pain in the rear, especially when you're going back and forth a lot. That is much more irritating to me than kneeling down to place the arms on the 2 post.
The second thing I don't like is the ramps are hanging out there at the back, at an elevation that it's just a matter of time before you walk into one of them. I speak from experience and wrap foam around the leading edge of each.
Finally, the wheel kit is handy, but in my case at least, even with a good floor, it's enough work to push it around that I don't care to do it very often. I'm using my 4 post more for storage than work.
One last thought on a 4 post. Get the wider version if at all possible. Many of the standard ones are quite narrow between posts when you're dealing with a full size car or a truck.
Lead, follow or get the hell out of the way
Re: 2 Post or 4 Post Lift? [Re: peabodyracing] #2474383
03/30/18 02:17 PM
03/30/18 02:17 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The main issue with a 2-post lift is that it will always be where it is, you can't move it around like a 4-post. Also you limit access to the interior with a 2-post while you can have the doors wide open on a 4-post. So like said above, it really depends on what you will mainly do on the lift. Plenty of accessories for a 4-post to mimic a 2-post. work
JB Rhinehart, Realist
A-Body's RULE!
