Re: 2 Post or 4 Post Lift?
[Re: 69dart]
#2474414
03/30/18 03:12 PM
03/30/18 03:12 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Another vote for 2 post. I agree with most of what's been said so far - 2 post takes less room and allows more access under the car. IMO, a 4 post isn't good for much except storage. A 2 post can be used for short term storage too. If you have the height, 2 post is best.
As for what was mentioned about having doors open while in the air - I'm not sure that's terribly relevant because in general, you wouldn't have the doors open while the car is up in the air. Besides, you can open them depending on how the car is set up. If the doors are open, it's probably best that the car is on the ground anyway.
Someone mentioned that a 2 post lift can be tougher to get a car on which isn't really a fair comparison. Backing a car off a 4 post lift can be tricky sometimes if you have limited sight lines or obstacles around the lift. Sliding the lift arm underneath the car is not hard unless you have mobility issues or the car is really low. Even if it's low, you just use little blocks to raise the car up a bit before sliding the lift arm under. Once you do it a few times, it will become second nature. You could even put some sort of mark on the floor or wall so the car is in the same spot every time.
2 post is also good for attaching an air hose reel so you will have easy access to it.
But whatever you do, don't buy a cheap off-shore one!
'71 Duster '72 Challenger '17 Ram 1500
[Re: 69dart]
#2474418
03/30/18 03:17 PM
03/30/18 03:17 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
2 post for sure... have used both and I'd never consider buying a 4 post for anything but storage.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
