Do I have what I need for an FMJ spindle swap? #2472884
03/27/18 05:59 PM
03/27/18 05:59 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I have been very bad at not checking myself before I dive into a project, so I beseech you all to help me make sure I've got all my bolts and bits for this one.
Current setup: 67 Coronet with manual drum spindles, using Dr. Diff's adapters for GM Metric calipers on a drum spindle. Uses 11.75 Cordoba discs with a bearing spacer on the '67 spindle.
New caliper adapters: Dr. Diff's adapters for Metric calipers on FMJ spindles
New spindles: disc spindles off of a '78 Volare
UCAs: QA1 tubular (big ball joint)
I'm a tad confused/unsure because most comparos I find are talking about using these spindles on A-bodies.
1. Do I use my regular 67 B-body lower ball joints with this spindle? This article appears to confirm this: http://www.bigblockdart.com/techpages/spindles.shtml
2. I assume I lose Dr Diff's bearing spacers I used for the Cordoba bearing on the '67 B-spindle?
3. Do I need any mounting bolts that aren't coming from the Volare spindles or my car?
Sorry if this is super duper obvious, but my confidence has bitten me in the butt a couple times this month smile
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Do I have what I need for an FMJ spindle swap? [Re: Secret Chimp] #2472895
03/27/18 06:16 PM
03/27/18 06:16 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
1. you should be able to use your existing lower ball joints, if you want to check, look up the LBJ part numbers for the Coronet and the Volare on rockauto.
2. again, look up the part numbers or look what the description says on D.r Diffs website for the spacers. I think you do just lose the spacers but I'm not positive.
3. I'm not sure on that one as I haven't looked at the kits descriptions. Dr. Diff I think is pretty good about sending all hardware with his kits.
something else you might want to look at is your brake hoses. most hose routing is cleaner if the caliper is at the front, I swapped some FMJ spindles side to side on my Coronet so I could put the caliper to the front...I'm using slider calipers though.
Re: Do I have what I need for an FMJ spindle swap? [Re: Secret Chimp] #2472961
03/27/18 08:14 PM
03/27/18 08:14 PM
okla.
sam64 Offline
sam64  Offline
okla.
yes use your lower ball joints,but why not just use all the volare parts?rotors,calipers,etc.
Re: Do I have what I need for an FMJ spindle swap? [Re: sam64] #2473107
03/28/18 01:22 AM
03/28/18 01:22 AM
Eugene, Oregon
Eugene, Oregon
If I were coming fresh off of drums I would, but I already have great performance from the 11.75/overbore GM Metric setup I have now. I'm doing this solely to get rid of the old bias ply geometry. This thing will really scoot when it stops gaining positive camber in turns.
Re: Do I have what I need for an FMJ spindle swap? [Re: Secret Chimp] #2473128
03/28/18 02:20 AM
03/28/18 02:20 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Are you wanting to bolt he early drum spindle conversion parts onto the FMJ spindle?
Re: Do I have what I need for an FMJ spindle swap? [Re: Secret Chimp] #2473147
03/28/18 02:53 AM
03/28/18 02:53 AM
Eugene, Oregon
Eugene, Oregon
No, I grabbed Dr. Diff's last kit for Metric on a disc spindle last year. Incidentally I'll have some DD Metric-on-drum adapters for sale soon wrench
Re: Do I have what I need for an FMJ spindle swap? [Re: Secret Chimp] #2473168
03/28/18 04:16 AM
03/28/18 04:16 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
OK,I looked at his site and didn't see anything like that.Thanks for the update!
Re: Do I have what I need for an FMJ spindle swap? [Re: Secret Chimp] #2473248
03/28/18 11:59 AM
03/28/18 11:59 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
are you going to use some aftermarket upper control arms?
Re: Do I have what I need for an FMJ spindle swap? [Re: Secret Chimp] #2473413
03/28/18 05:37 PM
03/28/18 05:37 PM
Eugene, Oregon
Eugene, Oregon
Yes, I'm switching to QA1's uppers and lowers. I considered the super-adjusty ones made out of a bunch of rod ends and couplers but that's overkill for me.
