Page 3 of 4 1 2 3 4
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: rb446] #2471026
03/23/18 04:52 PM
03/23/18 04:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted By rb446
I ran the CC .650" 290@.050 sft in my stock 440SP motor, didn't class that as big at all, it ticked over at 900rpm, sweet as, even without the CR it really needed,
Car was 3000lbs race weight, ran a best of 11.2@118 with stock 906 heads.
Added a pair of 2.14/1.81 mildly ported 906's, (probably 255cfm) went 10.7@125 which would've gone 10.5's with more air in slicks, and a few tweeks, was in 1990 and knowledge wasn't what it is today.
So working on that gain from stock 215>220cfm 906's > to BV 255cfm 906's = .5/sec gain, what would it run today with a pair of Trickflow 240's, (328@.650) 10.0's?...the cam/converter/gears/tyres were there for it....just theorizing....would love to get that back and run it today with the 240's to see, and all this from a stock balanced s-pack bottom end, a crappy Team G, small 850DP and just 10:1CR....anyone reckon I could've got into the 10.0's?
So if thats not big what is your definition of big?
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: HotRodDave] #2471045
03/23/18 06:01 PM
03/23/18 06:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Some of you guys should have raced with us in the 70's and 80's and you would get a better understanding of how you have to work with JUNK or within the rules. my Duster ran 9.82 back then at 2950 weight with a .030 over 440 block, 906 heads, stock crank, stock rods, TRW heavy weight pistons, and super stock springs. To get there I used a tunnel ram with two 750 holleys and a 750 lift cam. So with today's way better chassis, tires, HEADS, intakes, cams, and pistons it would be a "cakewalk". A 650 lift cam is not big.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2471117
03/23/18 08:49 PM
03/23/18 08:49 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
My solid tappet cam in my 451 is .640 advertised lift @ 260/264 and pushed my 3800lb Coronet to 10.38s at 128. I'm sure .38 could be found losing that 800lbs.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: pittsburghracer] #2471124
03/23/18 09:13 PM
03/23/18 09:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the .650 dont seem big to me, it was the 290@.050 thats big
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2471261
03/24/18 10:36 AM
03/24/18 10:36 AM
gregsdart Offline
gregsdart  Offline
What is the original posters' version of small?
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2471285
03/24/18 12:02 PM
03/24/18 12:02 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
The largest and most successful cam that I used for both SB/BB was the MP 590. I made good power and it had longevity. These were back in the 80's when iron heads were all we had. With better flowing heads, intakes, carbs ignition system, etc as per present day, I thought that a cam in the 550-580 range could get the job done and be reliable(500-700 passes per refresh). I did my fair amount of power and breakage issues with my hemi MP car and my VW powered Gasser. Been there, done that, and that's how I race anymore.
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: pittsburghracer] #2471361
03/24/18 03:00 PM
03/24/18 03:00 PM
UK
rb446 Offline
rb446  Offline
UK
up....exactly. We had about 6 Koffel iron 451's over here in cars at £5000 a pop in the 80's, they had max ported heads, ultra thin rings and .750 roller cams, they managed 10.0's in most of the cars that were lucky enough to afford to run them. The MP .590 with 271@.050 is a good cam but its done in most race 440's at around 6500ish with Good modern heads, if you wanna run in the 9's@3000lbs+ you gotta turn one more than that unless your light.
My junk 440 with junk 906's was still pulling like crazy at 6700 in the traps with 290@.050
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: rb446] #2471393
03/24/18 04:21 PM
03/24/18 04:21 PM
PA.
"Little"John
"Little"John
PA.
I got one heck of a laugh years ago (1980's). While I was laid off from the steel mill I picked up a job at a local transmission shop pulling and replacing transmissions to stay out of the bars every night. This place was owned and operated by several dirt track racers so "dirt track" books were laying around. I picked one up and it was discussing camshafts and how they work. Towards the end of the article it touched on drag racing. The author wrote " I don't know how these drag racing machines even start with these BIG, sometimes up to .750 lift even start. LOL. Boy he should see what we are running now.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: gregsdart] #2471592
03/24/18 11:21 PM
03/24/18 11:21 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
.590 flat tappet, 3000# sb or bb
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: pittsburghracer] #2472414
03/26/18 06:08 PM
03/26/18 06:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... The author wrote " I don't know how these drag racing machines even start with these BIG, sometimes up to .750 lift even start. LOL. Boy he should see what we are running now.
In one of the old Smokey Yunick books I have, he commented on how he didn't know how drag racing valve trains even held up given the extra lift and spring loads they used compared to the roundy-round engines he specialized in. I think at that time a .600"-ish SFT cam was probably typical for his stuff, so a more aggressive solid roller with .750" lift and 600#s open pressure would have seemed... "different", for sure.
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: BradH] #2472434
03/26/18 06:47 PM
03/26/18 06:47 PM
Todays technology and ramp designs are nothing like what was available ten to fifteen years ago, I have a solid roller Ultra Dyne, Bullitt cam in my new bracket motor with Jesel paired shaft rocker system, once the motor starts to spin over I can NOT feel the valve springs(325 Lbs. on the seats and 840 Lbs opend at .780 lift) working at all shock confused shruggy
I'm waiting to see if I dyno this rascal first or put it in the bracket car to see what it does at the track shruggy
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2472675
03/27/18 11:04 AM
03/27/18 11:04 AM
New York
polyspheric Offline
polyspheric  Offline
New York
From Vizard:
1. huge rocker ratio
2. tiny LSA
3. shorten duration
Boffin Emeritus
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: polyspheric] #2472848
03/27/18 04:59 PM
03/27/18 04:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted By polyspheric
From Vizard:
2. tiny LSA
3. shorten duration
I like the way he thinks
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2472871
03/27/18 05:45 PM
03/27/18 05:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
On his BBC mule engines, this had the effect of increasing torque all over, needing less valve spring, and making the same max power at lower RPM with better idle quality and part-throttle manners.
His opinion is that you HAVE to initiate intake flow ASAP or the rest of the intake cycle is playing catch-up, so big OL + 1.9:1 rockers get the valve open around TDC really quick & far.
Boffin Emeritus
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2475523
04/01/18 07:16 PM
04/01/18 07:16 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I have seen a 383 with AVS carb runs 9s in a 1969 Cuda, just look at Super Stock, lots of iron heads and small cams going fast.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2475664
04/01/18 11:22 PM
04/01/18 11:22 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Back in the early 2000, SS cars were running .750+ lifts. I doubt that have gotten smaller.
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2475698
04/02/18 12:12 AM
04/02/18 12:12 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ok, and that would be a Big cam, not a small cam. But your def was .590 or below, that's even a big cam by most. ???
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: A/MP] #2475755
04/02/18 01:03 AM
04/02/18 01:03 AM
gregsdart Offline
gregsdart  Offline
One mag article reported Paul Rossi's 440 ss motor was using a .750 lift roller, and .035 lash, which would be more in line with Vizards methods.
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: gregsdart] #2475761
04/02/18 01:09 AM
04/02/18 01:09 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Crane R286 .750 lift roller was the baseline 440 Superstock cam in the late 70's.
Re: CAN YOU MAKE BIG HP WITH A SMALL CAM [Re: GomangoCuda] #2475794
04/02/18 01:22 AM
04/02/18 01:22 AM
iagree up
Mark Heffington owner and designer of Cam Dynamics made that lift possible with his lobe designs, no one else could make the valve heads stay on the valves back then with that much lift shruggy Hence Harvey Crane buying out the completion to get his technology work scope
Page 3 of 4 1 2 3 4
