Re: shaft mounted aluminum rocker arms side play
[Re: 1mean340]
#2472768
03/27/18 02:34 PM
03/27/18 02:34 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
There is no place in that set up where you should have 1/4" of side free play.You want somewhere between .015-.020 clearance/end play between pairs. If you are moving the rockers so much that it changes the lash, thats a problem.Fix it before you run it. W2 pushrod angles are bad enough, without them being self adjusting.
RIP Monte Smith
[Re: 1mean340]
#2472776
03/27/18 02:41 PM
03/27/18 02:41 PM
Posts: 4,457 Washington
madscientist
Washington
You also need to make sure the rocker is centered over the valve, from front to rear. If that means milling the hold downs, it's what you have to do.
[Re: 1mean340]
#2472810
03/27/18 03:25 PM
03/27/18 03:25 PM
Posts: 370 Suffolk County, New York
1mean340
Eek, the motor was already run for about 500 miles (those pics were prior to first startup hence the clean ports). I trusted my engine builder with the assembly, only noticed this when I was about to adjust hotlash after the first oil change.
I will check on the front to back centering, I really hope that's right or this could turn into a real PITA 😡
Is less than .015 of clearance ok? It looks like some don't have shims, and the cylinder#1 pair I don't think even has that much. I assume I'll need at least that for expansion so they don't rub.
FWIW this is a low rpm engine, won't see over 6500 (supercharged). The heads/valvetrain I bought on here from a member a few years back, I didn't know much about setting these up so I just gave it to my engine builder to do along with the rest of the motor. Only noticed a tiny bit of metal on the drain plug during the first oil change , no sign of anything crazy but i'll definitely check the push rod clearance was figuring my builder already did all this for how much I paid 🙁
[Re: 1mean340]
#2472843
03/27/18 04:38 PM
03/27/18 04:38 PM
1mean340
Thanks cab! Tell me about it haha, between FITECH issues, supercharger belt issues and now this, I got this car fired up late summer and it hasn't been able to make get even one clean WOT one gear pull after working on it every weekend.
It definitely didn't look like any more metal than I have normally seen on new motors so I wasn't too worried. Next oil change I'll cut the filter as well.
This setup has definitely been more than I bargained for trying to get everything to work right.
this just bothers me because I cut a pretty big check to my engine builder/machinist to assemble the engine and this seems like a pretty big thing to overlook. If it's just a matter of shimming, I don't mind, but if roller tips aren't centered front to back on the valve and the perches have to be milled I am going to have to go back to him and ask what's up. I normally expect a lot of bumps in the road and still have a ton of kinks to work out on my home built procharger setup and FITECH tuning issues so it really sucks having to take time out to fix stuff that I paid to have done.
but if I wanted easy, cheap and slow I would have gotten into marathon running so I'm not complaining, just venting a little LOL!
[Re: 1mean340]
#2472865
03/27/18 05:36 PM
03/27/18 05:36 PM
Posts: 2,857 Pattison Texas
CSK
Pattison Texas
Talk to Mike @ B3racing about the geometry
[Re: CSK]
#2472867
03/27/18 05:39 PM
03/27/18 05:39 PM
madscientist
Washington
Talk to Mike @ B3racing about the geometry ^^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^ You just know the geometry is put correct. It never is.
[Re: 1mean340]
#2472869
03/27/18 05:42 PM
03/27/18 05:42 PM
Posts: 4,206 New York
polyspheric
New York
Another day, another waste of my time.
Boffin Emeritus
[Re: 1mean340]
#2472937
03/27/18 07:21 PM
03/27/18 07:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How thick are the shims at the bottom of the springs.. they look real thick.. what is the installed height Also show your rockers at base and full lift
[Re: 1mean340]
#2472943
03/27/18 07:35 PM
03/27/18 07:35 PM
1mean340
OK, well I may have over-reacted a little on the clearances. The gap between the cylinder 5 rockers that I thought was 1/4" was actually about 36 thousands when I checked it with the feeler gauge. it felt like a lot more...yes this is embarassing LOL
as far as the roller tips being centered forward to back, they appear to be good but I am going to try to snap some pics of them because it is hard to see with the motor in the car. I can't get my head low enough to really get a good view.
My builder said the geometry was funky but he didn't think it would be an issue on a low rpm engine. The last engine the ran on looked about the same and he was taking it up to 7500 IIRC. Not saying it's good, but maybe good enough? I really don't know. I'm just going by what I'm being told.
Poly, makes sense that the lash was changing as i slid the rocker side to side, as you said, it would be changing the pushrod angle as you moved it. I take it the large 36 thousanths clearance is causing that as the others barely move
What I am also worried about is can they be too tight side to side? Most of these rockers seem extremely tight side to side. I mean you can move them freely up and down when they are off the valve but some of them I can't feel any side to side movement. I need to find the rest of my feeler gauges to check but I'm pretty sure most of them are less than .015 of clearance. I could be wrong though, as I just called 39 thousandths a 1/4 inch LOL
Mr P body, i will snap some pics of that.
[Re: 1mean340]
#2472945
03/27/18 07:38 PM
03/27/18 07:38 PM
1mean340
And when I say this thing won't see over 6500rpm's I mean that. I plan to shift at around 6000 and set the rev limited pretty soon after it. It's a 295cfm flowing head, indy single plane, D1SC procharger with intercooler on E85 on a not so crazy bottom end (factory forged crank, H beam rods, stud girdle...that's it) so I figure it may be able to take boost, but not RPM's. It'll make more power than I need at 6000 with 8PSI so I don't plan on really revving it much higher.
[Re: 1mean340]
#2473570
03/28/18 10:21 PM
03/28/18 10:21 PM
madscientist
Washington
RPM has ZERO to do with rocker arm geometry. Before you do anything further, get ahold of Mike at B3 racing engines (b3racingengines.com) and let him help you fix the geometry BEFORE you bother to do anything else.
Bad geometry is bad geometry. RPM means nothing.
I have typed this out so many times in so many places it feels beyond redundant. I can tell you that a great number of engine builders have no idea about rocker arm geometry, let alone rocker arm geometry with a shaft system. I am certainly not an expert, but I learned a long time ago the hard way that you must fix it. It's crazy to say my RPM's are low so I can let it slide.
In 38 years of doing this I have seen more destruction and broken parts from rocker geometry and general valve train issues than almost anything else.
I can tell you that when you fix your geometry, you will have to buy longer pushrods.
Don't put it off. Fix it now.
