Pinion contact thoughts. #2467720
03/17/18 01:24 PM
03/17/18 01:24 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Factory gears bl .008. Factory shimm.
Re: Pinion contact thoughts. [Re: Scamp408] #2467733
03/17/18 02:02 PM
03/17/18 02:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pinion is to deep. Pattern is to far into the root of the tooth. Go here. This is without a doubt the best rear end set-up instructions I ever read.
You'll see your pattern on page 15 2nd pic down on the far right.
https://www.google.com/search?q=yukon+ge...p;sourceid=chro
Doug
Re: Pinion contact thoughts. [Re: Scamp408] #2467773
03/17/18 04:14 PM
03/17/18 04:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Pull the pinion out .008 or .010 and see what it looks like.
Re: Pinion contact thoughts. [Re: Scamp408] #2471344
03/24/18 02:07 PM
03/24/18 02:07 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
.010 shim
Re: Pinion contact thoughts. [Re: Scamp408] #2471366
03/24/18 03:14 PM
03/24/18 03:14 PM
Move the pinion deeper into the ring gear some more up
Not a bunch tsk grin
Good luck, take the time and effort to get it so you really like it up
Re: Pinion contact thoughts. [Re: Scamp408] #2471373
03/24/18 03:35 PM
03/24/18 03:35 PM
Kirkland, Washington
Pacnorthcuda Offline
Are you putting some drag on the ring as you rotate the pinion? Your faint pattern makes me think you are not.
Re: Pinion contact thoughts. [Re: Scamp408] #2471396
03/24/18 04:29 PM
03/24/18 04:29 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
i stuck a big screwdriver against gear for drag. Right now i have the stk .090 and .010 shim i have plenty more to try. Thanks guys
Re: Pinion contact thoughts. [Re: Cab_Burge] #2471559
03/24/18 10:01 PM
03/24/18 10:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I disagree. Pattern is still to far into the root. Pinion shim still looks to thick. I agree, don't quit until it is right.
Doug
Re: Pinion contact thoughts. [Re: dvw] #2471597
03/24/18 11:32 PM
03/24/18 11:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Doug
I say deeper as well, but op could help by making sure he gets better readable pattern marks. The pattern is looking better with the .010 shim.
Re: Pinion contact thoughts. [Re: Scamp408] #2471731
03/25/18 12:18 PM
03/25/18 12:18 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
.090+.015
Re: Pinion contact thoughts. [Re: Scamp408] #2471735
03/25/18 12:19 PM
03/25/18 12:19 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
.075
Re: Pinion contact thoughts. [Re: Scamp408] #2471804
03/25/18 02:18 PM
03/25/18 02:18 PM
Boise
Moparteacher Offline
Boise
Drive side looks much better and is acceptable. Coast side isn't perfect but acceptable. You don't want to sacrifice the the drive side to change the coast. Patterns are acceptable when the pinion wipes off the toe, as shown on the coast, and wipes off the heel. But it's never acceptable when the pattern wipes off the crown or into the root.
Run it.
Re: Pinion contact thoughts. [Re: Scamp408] #2471839
03/25/18 03:40 PM
03/25/18 03:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Usually, using the shim that came out of it to start will get you pretty close, especially with a factory gear, and as long as the guy before you did it right. Actually, the first pics weren't that far off. I said "pull the pinion out .010" meaning to pull the pinion out of the gear, which would require you to reduce the shim thickness. I expected it to be close or a little over center requiring you to put a few thou back in. If I read it right, you added .010, then added .005 more until it was way deep. Then the last pics were with a .075 shim pack which is not deep enough. You've lost the rabbit, not hard to do.
Put an .084-.086 shim pack in it, just to get back on track. It may be pretty close. An accurate read on the pattern requires that you take time to get the backlash and the pinion preload very close to being correct each time. Set-up preload can be achieved by putting it together with no shims,and tightening the pinion nut until the desired turning torque is achieved. On final assembly, put the correct preload shim pack in to get that torque number used in set up. A PITA with a Dana, but you gotta do it.
Re: Pinion contact thoughts. [Re: Scamp408] #2472486
03/26/18 09:00 PM
03/26/18 09:00 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
This is .085. Forget the 75 bearing didn’t bottom out.
Re: Pinion contact thoughts. [Re: Scamp408] #2472510
03/26/18 09:55 PM
03/26/18 09:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Drive side is close. I would take a few more thou out of the shim. Coast side is also close but running off of the toe. I would take 3 or so out of the shim pack and open the BL up a few or 3 and see what that does. Pulling the pinion out of the ring gear a few and leaving the side shims alone should open the backlash some.
How are you checking backlash?
Having fun? Yeah, this is how you learn - by trying stuff and seeing what it does. When it starts doing what you think it will do, then you're catching on.
Re: Pinion contact thoughts. [Re: Scamp408] #2472520
03/26/18 10:04 PM
03/26/18 10:04 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
BL is set with a dial indicator. Always fun lol. I will get back at it.
Re: Pinion contact thoughts. [Re: Scamp408] #2472604
03/27/18 02:32 AM
03/27/18 02:32 AM
Please check the back lash at 3 or 4 places to make sure the ring gear is seated squarely on the carrier or spool scope
Ain't setting up rear end gears fun by using the pattern only whistling boogie grin
I bought a pinion depth setting tool set a long time ago, maybe you should to up
Re: Pinion contact thoughts. [Re: Scamp408] #2472929
03/27/18 07:01 PM
03/27/18 07:01 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
7bl and .080 shim
Re: Pinion contact thoughts. [Re: Scamp408] #2474317
03/30/18 12:06 PM
03/30/18 12:06 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I tried a true .075 and pattern fell off the edge so I went back to the factory shim and started over which to me isn’t that bad. I think somewhere between that and .085 should be good. After awhile it all looks the same to me.
Re: Pinion contact thoughts. [Re: Scamp408] #2474477
03/30/18 05:33 PM
03/30/18 05:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The .080 looks OK on the drive side. I'm looking beyond the teeth you painted to the ones further down with the compound smeared on them. The coast side is still strange except for the one tooth at the bottom of the picture, which looks OK. I would still open the backlash to .010 or so. Most of what I do gets at least 010.
Try using less marking compound. A thin coat comes off cleaner and helps with seeing what is actually going on.
