disc brake help
#2472236
03/26/18 12:00 PM
03/26/18 12:00 PM
Posts: 416 Georgia
KingTuna
Georgia
Alright, finally have my car in the shop at my house and have it on jack stands to install the disc brakes. Car is a 66 Fury II, I'm putting the spindles and disc brakes off a 73 New Yorker on it. Does someone have a diagram, or a picture of how the spring goes on? When I took the brakes off, the spring was rusted and fell to bits. I took these off about two years ago, so my memory is a little fuzzy.
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
Re: disc brake help
[Re: KingTuna]
#2472331
03/26/18 03:32 PM
03/26/18 03:32 PM
Posts: 416 Georgia
KingTuna
Georgia
I think I found the answer. It's the anti rattle spring that goes on the outside of the caliper and wraps around the bolts.
Re: disc brake help
[Re: KingTuna]
#2472405
03/26/18 06:00 PM
03/26/18 06:00 PM
Posts: 416 Georgia
KingTuna
Georgia
These are the springs I'm talking about. The disc brakes I have are different from the ones posted by Mr. Tom. I have the fixed calipers, I believe thats what they are called. Have two bolts that hold the caliper on.
Re: disc brake help
[Re: KingTuna]
#2472408
03/26/18 06:02 PM
03/26/18 06:02 PM
Posts: 416 Georgia
KingTuna
Georgia
picture of the calipers.
Re: disc brake help
[Re: KingTuna]
#2472409
03/26/18 06:03 PM
03/26/18 06:03 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Saved that picture. Thanks.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: disc brake help
[Re: KingTuna]
#2472411
03/26/18 06:04 PM
03/26/18 06:04 PM
amxautox
Saved that picture too, thanks.
Tom
author unknown
Re: disc brake help
[Re: amxautox]
#2472412
03/26/18 06:05 PM
03/26/18 06:05 PM
amxautox
Yes, there is the pin type and slider type calipers with different type/shaped anti-rattle springs. I don't know which year cars had which design. I've had both, but forget which on which car.
Tom
author unknown
Re: disc brake help
[Re: KingTuna]
#2472692
03/27/18 11:56 AM
03/27/18 11:56 AM
Posts: 416 Georgia
KingTuna
Georgia
Ok, thank yall. I guess I'll go ahead and remove the splash shields if they are not needed.
Re: disc brake help
[Re: KingTuna]
#2473304
03/28/18 01:44 PM
03/28/18 01:44 PM
Posts: 416 Georgia
KingTuna
Georgia
I'm glad ya'll told me, because I sure would have left it on there. I took off Friday, so I have plans to light the grill for a few butts, pack the cooler with a 6 pack, and get to work on installing these brakes. I also get to take out exhaust manifold studs and put some liquid teflon on them, because I have one leaking antifreeze onto the manifold.
Thanks again, don't think I would have every gotten this far with the car without ya'll.
Re: disc brake help
[Re: KingTuna]
#2473336
03/28/18 02:55 PM
03/28/18 02:55 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Here's a pic of the slider type calipers. This setup is from a '76 Dart and uses Dodge Monaco rotors and it's mounted on my '64 Polara.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
