disc brake help #2472236
03/26/18 12:00 PM
03/26/18 12:00 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Alright, finally have my car in the shop at my house and have it on jack stands to install the disc brakes. Car is a 66 Fury II, I'm putting the spindles and disc brakes off a 73 New Yorker on it. Does someone have a diagram, or a picture of how the spring goes on? When I took the brakes off, the spring was rusted and fell to bits. I took these off about two years ago, so my memory is a little fuzzy.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: disc brake help [Re: KingTuna] #2472255
03/26/18 12:43 PM
03/26/18 12:43 PM
which spring/where was it at?
Re: disc brake help [Re: KingTuna] #2472331
03/26/18 03:32 PM
03/26/18 03:32 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
I think I found the answer. It's the anti rattle spring that goes on the outside of the caliper and wraps around the bolts.
1966 Fury II 4 door
Re: disc brake help [Re: KingTuna] #2472358
03/26/18 04:17 PM
03/26/18 04:17 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Can you put up a picture? If they are like the B/E bodies calipers, you don't need that spring, or the splash plate.
Re: disc brake help [Re: KingTuna] #2472369
03/26/18 04:34 PM
03/26/18 04:34 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: disc brake help [Re: KingTuna] #2472403
03/26/18 05:58 PM
03/26/18 05:58 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
1966 Fury II 4 door
Re: disc brake help [Re: KingTuna] #2472405
03/26/18 06:00 PM
03/26/18 06:00 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
These are the springs I'm talking about. The disc brakes I have are different from the ones posted by Mr. Tom. I have the fixed calipers, I believe thats what they are called. Have two bolts that hold the caliper on.
1966 Fury II 4 door
Re: disc brake help [Re: KingTuna] #2472408
03/26/18 06:02 PM
03/26/18 06:02 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
picture of the calipers.
1966 Fury II 4 door
Re: disc brake help [Re: KingTuna] #2472409
03/26/18 06:03 PM
03/26/18 06:03 PM
amxautox Offline
amxautox  Offline
Saved that picture. Thanks.
Tom
author unknown
Re: disc brake help [Re: KingTuna] #2472411
03/26/18 06:04 PM
03/26/18 06:04 PM
amxautox Offline
amxautox  Offline
Saved that picture too, thanks.
Tom
author unknown
Re: disc brake help [Re: amxautox] #2472412
03/26/18 06:05 PM
03/26/18 06:05 PM
amxautox Offline
amxautox  Offline
Yes, there is the pin type and slider type calipers with different type/shaped anti-rattle springs. I don't know which year cars had which design. I've had both, but forget which on which car.
Tom
author unknown
Re: disc brake help [Re: KingTuna] #2472481
03/26/18 08:51 PM
03/26/18 08:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You don't need those springs, or the things that center the pads, or the slash shields. Those are the same as 71/2 B body, and 70/74 E body.
Re: disc brake help [Re: KingTuna] #2472488
03/26/18 09:03 PM
03/26/18 09:03 PM
Conway, SC
T2R9 Online confused
T2R9  Online Confused
Conway, SC
Here is a pic with them installed. As 71Bird said they are not necessary and the brakes will work fine without them.
Re: disc brake help [Re: KingTuna] #2472692
03/27/18 11:56 AM
03/27/18 11:56 AM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Ok, thank yall. I guess I'll go ahead and remove the splash shields if they are not needed.
1966 Fury II 4 door
Re: disc brake help [Re: KingTuna] #2473279
03/28/18 12:51 PM
03/28/18 12:51 PM
moparx Offline
moparx  Offline
a lot of new stuff, for many years, have had the splash shield removed per OEM. in my opinion, removing these are an extra cooling option that costs nothing, and should be done on all but total restorations.
beer
Re: disc brake help [Re: KingTuna] #2473304
03/28/18 01:44 PM
03/28/18 01:44 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
I'm glad ya'll told me, because I sure would have left it on there. I took off Friday, so I have plans to light the grill for a few butts, pack the cooler with a 6 pack, and get to work on installing these brakes. I also get to take out exhaust manifold studs and put some liquid teflon on them, because I have one leaking antifreeze onto the manifold.
Thanks again, don't think I would have every gotten this far with the car without ya'll.
1966 Fury II 4 door
Re: disc brake help [Re: KingTuna] #2473336
03/28/18 02:55 PM
03/28/18 02:55 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Here's a pic of the slider type calipers. This setup is from a '76 Dart and uses Dodge Monaco rotors and it's mounted on my '64 Polara.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
