2003 Dodge Durango question #2471413
03/24/18 05:21 PM
03/24/18 05:21 PM
Vermont
bracketcharger Offline OP
Vermont
I'm replacing upper control arms on a '03 Durango 4x4 and I'm looking for torque specs for the mounting nuts,bushing nuts, and ball joint nut. Thanks in advance. Ready... go!!
Re: 2003 Dodge Durango question [Re: bracketcharger] #2471500
03/24/18 08:09 PM
03/24/18 08:09 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
TORQUE
DESCRIPTION
Upper Control Arm Frame Nuts
163 Nm
120 Ft.Lbs
Upper Control Arm Axle Nut
163 Nm
120 Ft.Lbs
Hub/Bearing Bolts
202 Nm
149 Ft.Lbs
Axle Nut
179 Nm Beginning Torque, Then Rotate 5 to 10 Times With a Final Torque of 356 Nm
132 Ft.Lbs Beginning Torque, Then Rotate 5 to 10 Times With a Final Torque of 263 Ft.Lbs
BallJoints.....
Upper 60 Ftp
Lower 94 Ftp
Upper Control Arms
Pivot Shaft to Frame 155 Ftp
Pivot Shaft 130 Ftp
Re: 2003 Dodge Durango question [Re: bracketcharger] #2471525
03/24/18 08:55 PM
03/24/18 08:55 PM
Vermont
Vermont
Thank you,CARMAN. This is a big help. I put a set in the same Durango 45-48000 miles ago ,Dorman brand, the ball joints are wasted. Installing Moog this time , hopefully the last time. The only thing good I can say about the Dorman part is that it came with a chart of torque specs. Thanks again and as always MOPAR OR NO CAR!!
Re: 2003 Dodge Durango question [Re: bracketcharger] #2471910
03/25/18 05:45 PM
03/25/18 05:45 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
No problem. Be careful of the moog I replaced all of my balljoints in my 02 Durango and they were all junk within 6 months. The lower's where squeaking and would no longer accept grease. The uppers where just falling apart. I put napa brand upper and lowers in this time. They where more money but looked and felt like a better product. Been about 5 months now and everything is still tight.
Re: 2003 Dodge Durango question [Re: bracketcharger] #2471914
03/25/18 05:47 PM
03/25/18 05:47 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
In January I wasted money on a defective clock spring.
Dorman is junk.
