Oil wt. in rebuilt 340 ? #2471071
03/23/18 07:20 PM
03/23/18 07:20 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
71 340 engine.Started on a run stand and oil pressure at 2000-2500 rpm was 100 lbs.Engine totally rebuilt,all bearings within specs.Oil used was Pennzoil 20-50.If I went with 5-30 would that bring the pressure down? Thanks in advance
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471077
03/23/18 07:29 PM
03/23/18 07:29 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Give it some break in time the pressure will go down some as things seat.
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471081
03/23/18 07:40 PM
03/23/18 07:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd be using a 10W-30. Yes, lower viscosity should produce less pressure & quicker flow. 100PSI is a lot, not necessary.
Re: Oil wt. in rebuilt 340 ? [Re: topside] #2471098
03/23/18 08:16 PM
03/23/18 08:16 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
10w-40 or 10w-30 is what you want.
Re: Oil wt. in rebuilt 340 ? [Re: Neil] #2471118
03/23/18 08:51 PM
03/23/18 08:51 PM
IN
ahy Offline
ahy  Offline
IN
I also would suggest you start with 10W30. With flat tappet cam it is really important to use a high zinc oil or add zinc.
The 20W50 likely is already formulated with higher zinc as a classic car performance lube. Most 10W30 sold does not have enough.
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471163
03/23/18 11:35 PM
03/23/18 11:35 PM
Tell us what brand and type, stock, high pressure or hi volume,oil pump you used in your motor?
100 Lbs. is excessive in any SB, I've seen this happen in the past and ended up switching the pump to a standard 318 non high volume pump to get the pressure down to 65 to 70 lbs cold and 30 lbs. hot idling up work
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471167
03/23/18 11:38 PM
03/23/18 11:38 PM
Grand Prairie,Texas
Grand Prairie,Texas
The reason I say break it in is because I have had more than one new engine start with high oil pressure and after a few run in sessions it dropped to a normal level. I really don't think you have a problem if it has not been run long.
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471204
03/24/18 01:25 AM
03/24/18 01:25 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Go to napa and get 10w30 Valvoline VR1. 20w 50 is to thick unless you have large clearance
Re: Oil wt. in rebuilt 340 ? [Re: ademon] #2471250
03/24/18 10:05 AM
03/24/18 10:05 AM
NC
Sixt8Chrgr Offline
Sixt8Chrgr  Offline
NC
I agree. I have had several engines rebuilt and end up putting the viscosity in the engine that the owners manual calls for. By using the Valvoline VR 1 you have a high Zinc content oil which is what you want as others have said.
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471289
03/24/18 12:11 PM
03/24/18 12:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I agree, 10w30. I would go with a synthetic hi-zinc muscle car/race car formulation once the break-in is completed.
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471362
03/24/18 03:02 PM
03/24/18 03:02 PM
BTW how high on pressure does your gauge read ?
I've seen several new high volume pumps for SB LA motors have BB bypass valves in them which made the pump have over 140 Lbs. pressure while running above 1200 RPM with cold oil down
The BB bypass valves have no holes in the bodies, the SB LA motor should have three or more holes in the sides of them scope
I had to drill a hole in the plug on the bypass passage to get the valves out and then either weld that hole up or use a new welsh cup after replacing the valve with the proper one, problems solved wrench scope
Re: Oil wt. in rebuilt 340 ? [Re: Cab_Burge] #2471442
03/24/18 06:41 PM
03/24/18 06:41 PM
New York
rarefish Offline
rarefish  Offline
New York
On the subject of SB Oil Pumps. Is this a stuck open bypass valve?
This pump I thinks was new or had very little use. I was going to install it in my 340, but decided to take a peek inside first. Maybe the relief spring is broken?
Re: Oil wt. in rebuilt 340 ? [Re: rarefish] #2471457
03/24/18 06:58 PM
03/24/18 06:58 PM
That is one of the holes in the bypass valve to allow the oil to flow through it once it is forced open by the pump pressure, your golden twocents
The BB valves have no holes in them scope
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471499
03/24/18 08:09 PM
03/24/18 08:09 PM
Ohio
P
PDR Dude Offline
PDR Dude  Offline
P
Ohio
Had a 340 rebuilt about a year ago. The machine shop was very adamant about using Brad Penn break in oil for the first 500 miles. Keep your foot out of it and vary the RPMs as much as possible.
Re: Oil wt. in rebuilt 340 ? [Re: PDR Dude] #2471577
03/24/18 10:42 PM
03/24/18 10:42 PM
It really sounds like your machine shop is really old school on clearances and parts work
You really need to load the rings as soon as possible to help seat them, DO NOT baby the motor for that long tsk twocents
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471658
03/25/18 03:21 AM
03/25/18 03:21 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Agreed, work that engine from the start, not too much RPM though.
Re: Oil wt. in rebuilt 340 ? [Re: Cab_Burge] #2471872
03/25/18 04:34 PM
03/25/18 04:34 PM
New York
rarefish Offline
rarefish  Offline
New York
The issue is that the valve is open with no oil pressure. The relief spring should have pushed the valve close. If I ran this pump I would then most likely have low oil pressure.
Re: Oil wt. in rebuilt 340 ? [Re: rarefish] #2471896
03/25/18 05:15 PM
03/25/18 05:15 PM
Take the pressed in plug out and examine the insides so you can see how that bypass valve works up twocents
The valve has to be shoved past it seat to make the holes in the valve allow oil to bypass into the other part of the pump work
Let us know what you do and find out thumbs
Re: Oil wt. in rebuilt 340 ? [Re: Cab_Burge] #2471923
03/25/18 06:19 PM
03/25/18 06:19 PM
New York
rarefish Offline
rarefish  Offline
New York
When I get the chance I will do that. I first need to find where I put that pump.
Question.. I know they were standard pressure and high pressure relief springs, but are the relief springs interchangeable between the SB and BB pumps?
Re: Oil wt. in rebuilt 340 ? [Re: 5carguy] #2471996
03/25/18 09:52 PM
03/25/18 09:52 PM
Utah, USA
1964superstock Offline
Utah, USA
Speedway Motors has Joe Gibbs Driven Oil on sale right now. Hard to beat this quality oil for your 340 engine. HR-2: 10W-30, or HR-5: 10W-40.
https://www.speedwaymotors.com/Driven-Racing-Oil-02007-HR2-Conventional-10W30-Motor-Oil-12-Quarts,272680.html
http://www.drivenracingoil.com/
