Re: Oil wt. in rebuilt 340 ?
[Re: ademon]
#2471250
03/24/18 10:05 AM
03/24/18 10:05 AM
Posts: 177 NC
Sixt8Chrgr
NC
Go to napa and get 10w30 Valvoline VR1. 20w 50 is to thick unless you have large clearance I agree. I have had several engines rebuilt and end up putting the viscosity in the engine that the owners manual calls for. By using the Valvoline VR 1 you have a high Zinc content oil which is what you want as others have said.
[Re: 5carguy]
#2471362
03/24/18 03:02 PM
03/24/18 03:02 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
BTW how high on pressure does your gauge read ? I've seen several new high volume pumps for SB LA motors have BB bypass valves in them which made the pump have over 140 Lbs. pressure while running above 1200 RPM with cold oil The BB bypass valves have no holes in the bodies, the SB LA motor should have three or more holes in the sides of them I had to drill a hole in the plug on the bypass passage to get the valves out and then either weld that hole up or use a new welsh cup after replacing the valve with the proper one, problems solved
[Re: rarefish]
#2471457
03/24/18 06:58 PM
03/24/18 06:58 PM
Cab_Burge
That is one of the holes in the bypass valve to allow the oil to flow through it once it is forced open by the pump pressure, your golden The BB valves have no holes in them
[Re: PDR Dude]
#2471577
03/24/18 10:42 PM
03/24/18 10:42 PM
Cab_Burge
Had a 340 rebuilt about a year ago. The machine shop was very adamant about using Brad Penn break in oil for the first 500 miles. Keep your foot out of it and vary the RPMs as much as possible. It really sounds like your machine shop is really old school on clearances and parts You really need to load the rings as soon as possible to help seat them, DO NOT baby the motor for that long
[Re: Cab_Burge]
#2471923
03/25/18 06:19 PM
03/25/18 06:19 PM
Posts: 2,252 New York
rarefish
New York
Take the pressed in plug out and examine the insides so you can see how that bypass valve works The valve has to be shoved past it seat to make the holes in the valve allow oil to bypass into the other part of the pump Let us know what you do and find out When I get the chance I will do that. I first need to find where I put that pump. Question.. I know they were standard pressure and high pressure relief springs, but are the relief springs interchangeable between the SB and BB pumps?
[Re: 5carguy]
#2471996
03/25/18 09:52 PM
03/25/18 09:52 PM
Posts: 506 Utah, USA
1964superstock
Utah, USA
Speedway Motors has Joe Gibbs Driven Oil on sale right now. Hard to beat this quality oil for your 340 engine. HR-2: 10W-30, or HR-5: 10W-40. https://www.speedwaymotors.com/Driven-Racing-Oil-02007-HR2-Conventional-10W30-Motor-Oil-12-Quarts,272680.html http://www.drivenracingoil.com/
