mopar intakes #2468963
03/20/18 09:14 AM
03/20/18 09:14 AM
ma.
duspan Offline OP
duspan  Offline OP
ma.
hello
why mopar intakes are made with the spread bore carb mount instead of square bore, is there any performance from this?
thanks
Re: mopar intakes [Re: duspan] #2468989
03/20/18 10:29 AM
03/20/18 10:29 AM
Guitar Jones Offline
No.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: mopar intakes [Re: duspan] #2470333
03/22/18 12:49 PM
03/22/18 12:49 PM
Earth
Rob C Offline
Rob C  Offline
Earth
The intake are made for use with the TQ carb. This is ether for class racing requiring the use of the TQ,
OR, for use of the TQ in the street, street strip adventure. The reusing of a TQ keeps costs down and is a very good street, street/strip carb.
More power can be found with welding, cutting, grinding the intake into a square bore. Follow MoPars recommendations and use the pop sticks in the intake as shown in the engines book.
Re: mopar intakes [Re: Rob C] #2470356
03/22/18 01:37 PM
03/22/18 01:37 PM
dogdays Offline
dogdays  Offline
They're made with the spreadbore pattern because that's the type of carb Chrysler Corp was using that year.
The spreadbore 360 intakes are quite good. They're pretty tall for a stock intake. If it's an EGR intake and you don't want EGR just stick a valve on the pad and don't plumb up any vacuum to it.
I believe the reason Chrysler went to spreadbore intakes was that the Thermoquad was much more tunable and easier with which to get legal emissions readings.
GM and Ford had been using spreadbore carbs since 1967. Chrysler started in 1971, IIRC.
One benefit of the TQ is that even the smaller carb was 750cfm, which was as large or larger than the AFB or AVS that it replaced.
UNLESS you are in a racing class that requires stock intakes, it is far easier to just buy a decent intake than to attempt to modify a cast iron intake.
R.
Re: mopar intakes [Re: duspan] #2470422
03/22/18 03:15 PM
03/22/18 03:15 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Pretty sure Duspan is referring to the still currently available aluminum intakes from Mopar Performance...like the M1 single planes for small or big blocks, which are spread bore pattern.
Not sure why they do it. No one runs a spread bore in a performance application unless they have to for class reasons. There are a few Thermoquad loyalists, but they are few and far between. There's no performance benefit from it, just makes it easier to bolt on and run a POS carb. Mopar Performance has sold crap for a long time and been pretty disassociated w/ what Mopar racers need and want.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: mopar intakes [Re: duspan] #2470452
03/22/18 03:54 PM
03/22/18 03:54 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
so now that the MP manifolds have been mentioned.
I have an NOS single plane low deck manifold, I only plan to run holley carbs, should I have a buddy weld up the flange so I can make it a square bore, or is it minimal gains for the work??
Re: mopar intakes [Re: duspan] #2470743
03/22/18 11:50 PM
03/22/18 11:50 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
the intake is the m-1 that i used, but i bought the adapter to use the holley carb? would have like to try a tapered 4 hole spacer to see if they helped in the performance?
Re: mopar intakes [Re: duspan] #2470855
03/23/18 10:04 AM
03/23/18 10:04 AM
I've never used an adapter to bolt a normal square bore carb onto one of those manifolds.
Only way to know if a spacer works is to try it. They're very combo specific.
CHIP
Re: mopar intakes [Re: duspan] #2471141
03/23/18 09:58 PM
03/23/18 09:58 PM
Washington
skrews Offline
skrews  Offline
Washington
What makes even less sense is the MP duel plane M1 is square flange. Azz backward if you ask me.
Re: mopar intakes [Re: skrews] #2471666
03/25/18 04:22 AM
03/25/18 04:22 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The dual plane is just an Eddy RPM with “Mopar” cast into it instead of Edelbrock. I believe it is made by Eddy under contract from Mopar, so Mopar had nothing to do with designing that manifold.
Re: mopar intakes [Re: StealthWedge67] #2471864
03/25/18 04:21 PM
03/25/18 04:21 PM
Earth
Rob C Offline
Rob C  Offline
Earth
That would be for the big block only. If you watch carefully, they can be had for cheaper then an Edelbrock sometimes.
