Re: mopar intakes
[Re: duspan]
#2468989
03/20/18 10:29 AM
03/20/18 10:29 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: mopar intakes
[Re: Rob C]
#2470356
03/22/18 01:37 PM
03/22/18 01:37 PM
dogdays
They're made with the spreadbore pattern because that's the type of carb Chrysler Corp was using that year.
The spreadbore 360 intakes are quite good. They're pretty tall for a stock intake. If it's an EGR intake and you don't want EGR just stick a valve on the pad and don't plumb up any vacuum to it.
I believe the reason Chrysler went to spreadbore intakes was that the Thermoquad was much more tunable and easier with which to get legal emissions readings. GM and Ford had been using spreadbore carbs since 1967. Chrysler started in 1971, IIRC.
One benefit of the TQ is that even the smaller carb was 750cfm, which was as large or larger than the AFB or AVS that it replaced.
UNLESS you are in a racing class that requires stock intakes, it is far easier to just buy a decent intake than to attempt to modify a cast iron intake.
R.
Re: mopar intakes
[Re: duspan]
#2470422
03/22/18 03:15 PM
03/22/18 03:15 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Pretty sure Duspan is referring to the still currently available aluminum intakes from Mopar Performance...like the M1 single planes for small or big blocks, which are spread bore pattern.
Not sure why they do it. No one runs a spread bore in a performance application unless they have to for class reasons. There are a few Thermoquad loyalists, but they are few and far between. There's no performance benefit from it, just makes it easier to bolt on and run a POS carb. Mopar Performance has sold crap for a long time and been pretty disassociated w/ what Mopar racers need and want.
Re: mopar intakes
[Re: duspan]
#2470855
03/23/18 10:04 AM
03/23/18 10:04 AM
an8sec70cuda
I've never used an adapter to bolt a normal square bore carb onto one of those manifolds. Only way to know if a spacer works is to try it. They're very combo specific.
Re: mopar intakes
[Re: skrews]
#2471666
03/25/18 04:22 AM
03/25/18 04:22 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
What makes even less sense is the MP duel plane M1 is square flange. Azz backward if you ask me. The dual plane is just an Eddy RPM with “Mopar” cast into it instead of Edelbrock. I believe it is made by Eddy under contract from Mopar, so Mopar had nothing to do with designing that manifold.
