Page 1 of 5 1 2 3 4 5
What went wrong? #2469889
03/21/18 07:09 PM
03/21/18 07:09 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I had built a 505 stroker. here is the list of parts:
440 bored .30
505 stroker kit from Ohio Crankshaft
84cc Edelbrock heads with stock rocker arms
Edelbrock Torker 2 intake
Holley 850 carb
HYDRAULIC − Serious street and bracket
race cam.
10:1 compression, lower gears,
headers and 3500+ stall.
Hyd. Hyd. 3000 to 6500 21-229-428
Single-Bolt
XE295HL 295 307 251 257.564.564 110°
Dougs 3" headers
Took it to the dyno and it only put out 231 hp and 286 torque.
I lost probably about half the horse power somewhere.
Re: What went wrong? [Re: Shatar4] #2469910
03/21/18 07:28 PM
03/21/18 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you degree the cam
wave
Re: What went wrong? [Re: Shatar4] #2469913
03/21/18 07:29 PM
03/21/18 07:29 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Are those rear wheel HP and TQ numbers?
Re: What went wrong? [Re: MR_P_BODY] #2469930
03/21/18 07:51 PM
03/21/18 07:51 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Yes
Re: What went wrong? [Re: Shatar4] #2469931
03/21/18 07:52 PM
03/21/18 07:52 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Stock rocker arms? Is that meaning stamped steel? If so get rid of them and get some adjustable's. That's a pretty decent hyd cam should make over 600 hp easily. Degree the cam? Break in the cam with proper lube?
Re: What went wrong? [Re: Mopar_Rich] #2469932
03/21/18 07:52 PM
03/21/18 07:52 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Rear wheel
Re: What went wrong? [Re: merpar] #2469952
03/21/18 08:07 PM
03/21/18 08:07 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Yes,stamped steel rockers.
Broke the motor in with Joe Gibbs oil.
We did degree the cam.
Hot rod magizine built a 573 hp and used stamped steel rockers so I doubt that would make me lose that much hp and tq.
http://www.hotrod.com/how-to/engine/1412-how-you-can-build-a-stout-537hp-street-440/
Re: What went wrong? [Re: Shatar4] #2469955
03/21/18 08:10 PM
03/21/18 08:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What did you degree the cam into
wave
Re: What went wrong? [Re: Shatar4] #2469958
03/21/18 08:13 PM
03/21/18 08:13 PM
AndyF Online content
AndyF  Online Content
I don't see any problems with that parts list so I'm guessing the tune is way off. Do the standard checks and see what you find.
Spark plug wires connected? Plug wires in the correct order? Compression check? Look at plugs, look at ports, etc. Vacuum leaks? Air Fuel ratio? Ignition timing? etc.
Re: What went wrong? [Re: Shatar4] #2469965
03/21/18 08:23 PM
03/21/18 08:23 PM
That sounds like half throttle or less results work
Did you verify that you have the carb opened all the way with you in the car with the gas pedal on the floor? If not try that up twocents
Let us know what you find to fix this luck thumbs
Re: What went wrong? [Re: Shatar4] #2469970
03/21/18 08:25 PM
03/21/18 08:25 PM
Cochise Co, Az, From Detroit
moetown Offline
moetown  Offline
Does the car run and drive like a 230hp engine or what it should be over 500hp ?. With numbers that low, but the car runs strong, I might have to question the dyno itself.
Re: What went wrong? [Re: AndyF] #2469971
03/21/18 08:26 PM
03/21/18 08:26 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I hate the intake for that combo, I hate the convertor choice for that combo, did you check for total timing in the 32-36 range for a start. Did you check for proper preload on those non adjustable rockers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What went wrong? [Re: AndyF] #2469974
03/21/18 08:29 PM
03/21/18 08:29 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
They did change the plugs and upped the jets to 88 and 90. They reset the timing to 34 degrees. I have the dyno sheet at home and I’ll post it when I get there. It’s a very well Mopar place in Michigan that ran it on the Dyno and he can’t figure it out. Very disappointing
Re: What went wrong? [Re: moetown] #2469977
03/21/18 08:34 PM
03/21/18 08:34 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I had it dyno’d at Jake’s. He’s a Mopar guy so I don’t think it’s the dyno
Re: What went wrong? [Re: Shatar4] #2469978
03/21/18 08:34 PM
03/21/18 08:34 PM
P
Porter67 Offline
Porter67  Offline
P
Wondering what you used for push rods and lifter preload?
Do ya got a vid of this dyno session or of the car running, id think it probably dont sound well when running either.
Re: What went wrong? [Re: Porter67] #2469984
03/21/18 08:46 PM
03/21/18 08:46 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I do have a video but have no idea how to post it here
Re: What went wrong? [Re: Shatar4] #2469987
03/21/18 08:59 PM
03/21/18 08:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had my car checked at Jakes also... did you
ask him what might be your issue(if he throught
there was)
wave
Re: What went wrong? [Re: Shatar4] #2469992
03/21/18 09:05 PM
03/21/18 09:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Something going on besides the jetting or the timing being off a few numbers. Compression test, leak it, get the timing cover off and check the cam timing. Cut the oil filter apart and check it. Exhaust blocked. Transmission OK. Has to run and sound bad when it's being driven.
Re: What went wrong? [Re: MR_P_BODY] #2470005
03/21/18 09:29 PM
03/21/18 09:29 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
there was)
wave
I did and he had no idea. He was going to ask his buddy at Modern to see if he had anything and get back with me.
I believe I'm going to pull the motor and dissect it and maybe something will show up.
Re: What went wrong? [Re: CMcAllister] #2470006
03/21/18 09:31 PM
03/21/18 09:31 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Did all that. Did the compession check and leak down and everything looked great. Trans is good. I just dont know. I sank and boat load of money in this thing and my Ford Focus has more power!
