Milodon pump with remote filter? #2469868
03/21/18 06:46 PM
03/21/18 06:46 PM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Have a milodon oil pump with remote filter. Trying to find out the inlet and outlet ports to filter? Have old style cover 21220 i think is part number
Re: Milodon pump with remote filter? [Re: rick4106] #2469954
03/21/18 08:09 PM
03/21/18 08:09 PM
AndyF Offline
AndyF  Offline
The port that goes to the engine is an open passage. The other port comes from the pump.
Re: Milodon pump with remote filter? [Re: rick4106] #2469968
03/21/18 08:25 PM
03/21/18 08:25 PM
The upper one, closest to the headers, is the pump output to the filter, the bottom one is the return into the motor scope thumbs
Which brand remote filter mount are you going to use?
Re: Milodon pump with remote filter? [Re: Cab_Burge] #2469993
03/21/18 09:06 PM
03/21/18 09:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just remember that the center port goes to the
engine(the center of any filter is the return
going to the engine)
wave
Re: Milodon pump with remote filter? [Re: rick4106] #2470189
03/22/18 01:46 AM
03/22/18 01:46 AM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Cast housing for a spin on filter. Have a oberg 600 also but not to familiar with them. Thanks for info filter housing is marked. Was looking for pump inlet and outlet
Re: Milodon pump with remote filter? [Re: rick4106] #2470415
03/22/18 02:59 PM
03/22/18 02:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The center hole on the pump goes to the engine..
outer hole on the pump is the outlet which
will supply oil to the filter.. the port on the
pump that is plugged isnt used.. that was used
in the machining process and is a cross drilled
hole.. it has a plugged port in there also
EDIT
this is how the SB works.. but the center hole
on any filter is always the return going TO
the engine
EDIT
the outer area of the filer is much larger so it can
filter more oil before getting plugged up
wave
Re: Milodon pump with remote filter? [Re: rick4106] #2470681
03/22/18 09:13 PM
03/22/18 09:13 PM
Is this Milidon oil pump cover for a BB or SB V8?
Re: Milodon pump with remote filter? [Re: rick4106] #2471030
03/23/18 04:55 PM
03/23/18 04:55 PM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Big block
Re: Milodon pump with remote filter? [Re: rick4106] #2471105
03/23/18 08:26 PM
03/23/18 08:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Old style cover...
