Possible Solution to Fuel Sending Unit Problem? #2469138
03/20/18 02:31 PM
03/20/18 02:31 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Has anyone here had any success using one of these products?
https://www.technoversions.com/MeterMatchVRInstructionManualRevB.pdf
Re: Possible Solution to Fuel Sending Unit Problem? [Re: 67Satty] #2469244
03/20/18 05:12 PM
03/20/18 05:12 PM
New York
rarefish Online content
rarefish  Online Content
New York
That's the first time I have seen this, but I'm liking what I see. What's good about this product is that you can compensate for nonlinear tank shapes or sending units. That would improve the accuracy throughout the range of the gauge.
Re: Possible Solution to Fuel Sending Unit Problem? [Re: 67Satty] #2469256
03/20/18 05:31 PM
03/20/18 05:31 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
After looking at this I will stick to the RTE electronic voltage limiters,thanks
Plug n play
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Possible Solution to Fuel Sending Unit Problem? [Re: 68Cbarge] #2469257
03/20/18 05:37 PM
03/20/18 05:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Plug n play
The RTE is not adjustable to correct the readings, fuel level & oil pressure are almost always out of range. None of the aftermarket fuel senders read correct
Re: Possible Solution to Fuel Sending Unit Problem? [Re: CSK] #2469264
03/20/18 05:46 PM
03/20/18 05:46 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Plug n play
Thanks,I was not aware of that.
Re: Possible Solution to Fuel Sending Unit Problem? [Re: 67Satty] #2469278
03/20/18 06:19 PM
03/20/18 06:19 PM
BDW Offline
BDW  Offline
Looks interesting, at $50 the price is not too bad.
Too bad they don't include a calibration point for 1/2 full.
Looks like they set Full and Empty and interpolate all points in between.
Re: Possible Solution to Fuel Sending Unit Problem? [Re: 67Satty] #2469391
03/20/18 09:42 PM
03/20/18 09:42 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
My aftermarket, 1/2" sender from Year One works perfectly. Guess I got lucky...
Re: Possible Solution to Fuel Sending Unit Problem? [Re: Dave Hall] #2469425
03/20/18 10:53 PM
03/20/18 10:53 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
yes you did smile
Re: Possible Solution to Fuel Sending Unit Problem? [Re: BDW] #2469486
03/21/18 12:41 AM
03/21/18 12:41 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Most gauges expect linear results. Even my SpeedHut is a 2point calibration, but it could be a little more accurate.
$50 seems like a fair price to me as well.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Possible Solution to Fuel Sending Unit Problem? [Re: 67Satty] #2470793
03/23/18 01:36 AM
03/23/18 01:36 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
If you read the instruction sheet, it shows that you can cal it at up to 4 points.
It's Swifty! Swifty, you toad sucker!
Re: Possible Solution to Fuel Sending Unit Problem? [Re: zrxkawboy] #2471025
03/23/18 04:51 PM
03/23/18 04:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i see 4 points too. it is on the calibration page towards the end of the instructions
Re: Possible Solution to Fuel Sending Unit Problem? [Re: 67Satty] #2471417
03/24/18 05:29 PM
03/24/18 05:29 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Someone should market a similar unit that would allow the vehicle owner to modify the 0.45 volts output of a narrow band Oxygen sensor. Up to a 2 MPG gain could be achieved.
