Re: 70s door interchangeability
[Re: hosehead]
#2468625
03/19/18 03:52 PM
03/19/18 03:52 PM
Posts: 996 Central US
grancuda
Central US
What'd you do?
Pretty sure '72-80 are the same?
I've got a pair of '72 rust free doors but I know you are not close enough to be feasible.
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
[Re: hosehead]
#2468630
03/19/18 04:04 PM
03/19/18 04:04 PM
Posts: 1,179 Canada
demon
Canada
72-74 doors are the same. Accept Fiberglass or metal screw on panels only
75 doors are a one year deal. Will fit. First year of plastic clip on door panel. Will accept any door panel.
76-80 doors have the recess around the exterior door handle.
72-77 have the early vent window lock. 78-80 have the push button vent window lock These can all be swapped. Some later years have riveted in window regulators.
As far as fit, any 72-80 door will bolt on and function
Regular cab, crew cab, Ramcharger and club cab doors all interchange
[Re: grancuda]
#2468789
03/19/18 09:46 PM
03/19/18 09:46 PM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
What'd you do?
I've got a pair of '72 rust free doors but I know you are not close enough to be feasible. Pretty much the Chris Farley photo is what happened, Chris. Lol. I wasn't in the car though. Setting the timing and it popped out of park. Bent the door on my fence. Not my proudest moment, for sure. Thanks for the info guys! I'm trying to find a replacement now. That door had a bunch of holes in it anyway from about 5 different mirror installations so I'm trying not to be too bummed about it.
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
[Re: hosehead]
#2468845
03/19/18 11:36 PM
03/19/18 11:36 PM
grancuda
Central US
That's always been my biggest fear, seems I have nothing old with an operating e-brake & no one wants to just hang out in the thing while I'm tweaking on the distributor, plus on the Barracuda I'm always checking the 3000 rpm total advance, can't imagine it jumping in Reverse then.,. I figured messed up latch area or hinge area.
[Re: grancuda]
#2468862
03/20/18 12:07 AM
03/20/18 12:07 AM
hosehead
Grove, OK
That's always been my biggest fear, seems I have nothing old with an operating e-brake & no one wants to just hang out in the thing while I'm tweaking on the distributor, plus on the Barracuda I'm always checking the 3000 rpm total advance, can't imagine it jumping in Reverse then.,. I figured messed up latch area or hinge area. Yep, it was a little scary. I was able to jump in it pretty quickly but I got my foot on the brake at the exact moment the door hit the fence. I'll never do that again without chocking the wheels. On a happier note. The door needed a bunch of bodywork and there was no damage to the hinge area. Just need a good door and a lower hinge.
