Dual conical valve springs #2467741
03/17/18 02:40 PM
03/17/18 02:40 PM
AndyF Offline OP
AndyF  Offline OP
Finished up the dyno testing with the dual conical valve springs and got the article submitted to Hot Rod. The springs worked just fine even with a super aggressive QRI lobe on the cam. The intake lobe was .780 lift with the 1.65 rocker arms and the engine pulled nice and smooth up past 7000 rpm. I don't think I'd recommend that lobe for a bracket racer but it was interesting to run it as a test.
Here is the article: http://www.hotrod.com/articles/dyno-tested-dual-conical-valve-springs/
Re: Dual conical valve springs [Re: AndyF] #2467766
03/17/18 04:00 PM
03/17/18 04:00 PM
Texas
RustyM Offline
RustyM  Offline
Texas
thanks Andy
Re: Dual conical valve springs [Re: RustyM] #2467813
03/17/18 06:51 PM
03/17/18 06:51 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Good to see the valve spring tech moving along. That website is nearly unviewable, even with adblock and ghostery it's so loaded with garbage ads and auto play vids I just clicked out. I just picked up one of the last hex-a-just timing chains for a BBM, next up is the ARE timing cover. Working my way up to a roller cam.
Re: Dual conical valve springs [Re: AndyF] #2467884
03/17/18 10:20 PM
03/17/18 10:20 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Great article, thanks for sharing...
What is the part number on the lifters?
Are these in non-bushed lifter bores?
Re: Dual conical valve springs [Re: AndyF] #2467969
03/18/18 02:27 AM
03/18/18 02:27 AM
AndyF Offline OP
AndyF  Offline OP
Lifters are the AMC solid rollers from Comp Cams. Non-bushed lifter bores.
Re: Dual conical valve springs [Re: AndyF] #2468131
03/18/18 03:29 PM
03/18/18 03:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
950 Carb.............what happened to the EFI......... work whistling
Re: Dual conical valve springs [Re: AndyF] #2468175
03/18/18 05:16 PM
03/18/18 05:16 PM
AndyF Offline OP
AndyF  Offline OP
This engine uses a 950 Dominator that Mark W. reworked. He did a nice job, changed the boosters and redid the calibration. It works pretty well but I'll most likely convert the engine to EFI at some point. EFI works better for the stuff I do.
Re: Dual conical valve springs [Re: AndyF] #2468339
03/18/18 10:31 PM
03/18/18 10:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cool, just figured you had gone EFI on pretty much everything........ beer
