pics of electruc fuel set up underneath by the gas tank #2462405
03/07/18 02:17 AM
03/07/18 02:17 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Im puttin a electric fuel pump in and i know goes by the gas tank.lookin for pics how you have yours set up and mounted underneath your mopars.its goin a in 71 dart with a 440.also using the mr.gasket fuel pump 95gph with the mallory fuel filter canister as well.
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2462426
03/07/18 04:22 AM
03/07/18 04:22 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
I'm curious too. I had one in a b body mounted in the trunk by p.o., removed it. Bought a new pump and see it's supposed to be mounted lower than fuel level. I'd also like to know if it can be mounted sideways or upside down to get ground clearance. May get a different pump that can be mounted above fuel level.
I bookemarked this link that had good info, esp. the oil pressure switch <- Click
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2462429
03/07/18 04:36 AM
03/07/18 04:36 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I seem to remember pics in the tread the first time you asked. whistling
https://board.moparts.org/ubbthreads/ubbt...tml#Post2434810
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2462453
03/07/18 10:06 AM
03/07/18 10:06 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Great memory, just short.
Re: pics of electruc fuel set up underneath by the gas tank [Re: SNK-EYZ] #2462483
03/07/18 11:34 AM
03/07/18 11:34 AM
las vegas,nv
las vegas,nv
That was legit...Don't be an ass and members will help you. tsk
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2462509
03/07/18 12:23 PM
03/07/18 12:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Use a rubber isolated p-clamp to mount the pump. Mount it as close to the tank as you can, as low as you can. Unless you have a fuel cell in the trunk you're not going to get the pump below the tank, but if you can get the bottom of the pump close to flush with the bottom of the tank you're doing good IMO.
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2462662
03/07/18 04:46 PM
03/07/18 04:46 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Originally Posted By mopar muscle7271
Wasn't askin for any smartass remarks either.
If you think that's smartass, you've got a lot to learn. laugh2
Exactly how many times are you going to ask the same question?
If you haven't figured out how to mount the pump by now, you definitely need to have someone else install it.
Re: pics of electruc fuel set up underneath by the gas tank [Re: markz528] #2462667
03/07/18 04:52 PM
03/07/18 04:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine is similar but I mounted mine through the floor with a mouting plate under so it is not just going through sheet metal in case of a roller over. I wanted mine in the trunk so it was up out of the way from the wheelie bars and away from rubber debris from underneath.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: pics of electruc fuel set up underneath by the gas tank [Re: 6PKRTSE] #2462795
03/07/18 09:28 PM
03/07/18 09:28 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I mounted this Carter pump in the axle tunnel just forward of the gas tank. I made a plate and used a couple of existing bolt holes so nothing was modified on the body. I use this pump as my primer pump to fill the carbs before starting car. This is a 68 B body with a dana 60 - still plenty of room. The hose coming from the tank to the pump is maybe 12" long.
Good luck with the project.
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2463512
03/09/18 01:29 AM
03/09/18 01:29 AM
las vegas,nv
las vegas,nv
Anyone running the mr.gasket pumps or holleys?
Re: pics of electruc fuel set up underneath by the gas tank [Re: 68jim] #2464864
03/11/18 07:02 PM
03/11/18 07:02 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
did the exact same thing with exact same pump. 69 B 8 3/4
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2467662
03/17/18 10:39 AM
03/17/18 10:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the Holley black pump. Its mounted right in front of the gas tank as since I run a stock gas tank its really nowhere to mount it lower then the tank. So its bolted on the floor right in front of the gas tank near the sending unit. Its actually sitting level with the top of my stock tank.
It has worked fine mounted there for 12 years so far as I put the car on the road in 2006. And it feeds enough fuel to my 850 carb for my 63 to run 10's and not lay over in the traps. I have not been able to get any pics as my left knee is real bad and my other joints have been giving me so much trouble its tuff to lay under the car and get a pic. I am actually getting my left knee replace this Monday on March 19th. Ron
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2467666
03/17/18 10:53 AM
03/17/18 10:53 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't have a pic but before I went EFI I had a Holley Blue pump mounted in front of the spring mount on the passenger side. It worked well there for a very long time.
68 Barracuda Formula S 340
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2467811
03/17/18 06:40 PM
03/17/18 06:40 PM
usa
smos001 Offline
smos001  Offline
usa
On my 70 challenger, I put my electric pump right in front of the fuel tank. I made a bracket to have it hang a bit lower. I also found a thick rubber exhaust hanger material that I used to put behind the fuel pump and the bracket to reduce the noise and vibration.
Works great.
Re: pics of electruc fuel set up underneath by the gas tank [Re: 383man] #2467879
03/17/18 09:53 PM
03/17/18 09:53 PM
Minnesota
peabodyracing Offline
Minnesota
Ron, best of luck on your surgery. Knee replacement has come a long way in the past few years, so seems to get simpler all the time. Hope you're back up and running in short order. You're always a great help to us here with questions.
Lead, follow or get the hell out of the way
Re: pics of electruc fuel set up underneath by the gas tank [Re: peabodyracing] #2468408
03/19/18 12:30 AM
03/19/18 12:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thank you as I go in tomorrow morning. Ron
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2468577
03/19/18 01:54 PM
03/19/18 01:54 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Here is a Holley Black pump mounted on a plate off of the shock cross member. This is an E body with a Dana.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: pics of electruc fuel set up underneath by the gas tank [Re: 383man] #2471193
03/24/18 12:49 AM
03/24/18 12:49 AM
las vegas,nv
las vegas,nv
Hope your surgery went well
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2471199
03/24/18 01:07 AM
03/24/18 01:07 AM
las vegas,nv
las vegas,nv
Thanks for the tips i wil probably do the same mount in front of the tank.im runnin the stock tank to.any advice/pics how you wire it up?
Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271] #2471315
03/24/18 12:46 PM
03/24/18 12:46 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
It will take only one muscle car with a rear mounted exposed electric fuel pump to be involved in a fender bender with a loaded school bus for all this electric fuel DIYI upgrades to go legally bye bye. Taking that into account, installing one of these might save you and your car also.
https://www.summitracing.com/parts/rfw-cr92/overview/
