pics of electruc fuel set up underneath by the gas tank
#2462405
03/07/18 02:17 AM
03/07/18 02:17 AM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
Im puttin a electric fuel pump in and i know goes by the gas tank.lookin for pics how you have yours set up and mounted underneath your mopars.its goin a in 71 dart with a 440.also using the mr.gasket fuel pump 95gph with the mallory fuel filter canister as well.
Re: pics of electruc fuel set up underneath by the gas tank
[Re: mopar muscle7271]
#2462426
03/07/18 04:22 AM
03/07/18 04:22 AM
Posts: 15,661 Jefferson State
srt
ESYC
ESYC
Jefferson State
I'm curious too. I had one in a b body mounted in the trunk by p.o., removed it. Bought a new pump and see it's supposed to be mounted lower than fuel level. I'd also like to know if it can be mounted sideways or upside down to get ground clearance. May get a different pump that can be mounted above fuel level. I bookemarked this link that had good info, esp. the oil pressure switch <- Click
#2462662
03/07/18 04:46 PM
03/07/18 04:46 PM
Posts: 10,115 A Red State
SNK-EYZ
A Red State
Wasn't askin for any smartass remarks either. If you think that's smartass, you've got a lot to learn. Exactly how many times are you going to ask the same question? If you haven't figured out how to mount the pump by now, you definitely need to have someone else install it.
[Re: markz528]
#2462667
03/07/18 04:52 PM
03/07/18 04:52 PM
Posts: 4,539 Motor City
6PKRTSE
Motor City
Mine is similar but I mounted mine through the floor with a mouting plate under so it is not just going through sheet metal in case of a roller over. I wanted mine in the trunk so it was up out of the way from the wheelie bars and away from rubber debris from underneath.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 68jim]
#2464864
03/11/18 07:02 PM
03/11/18 07:02 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I mounted this Carter pump in the axle tunnel just forward of the gas tank. I made a plate and used a couple of existing bolt holes so nothing was modified on the body. I use this pump as my primer pump to fill the carbs before starting car. This is a 68 B body with a dana 60 - still plenty of room. The hose coming from the tank to the pump is maybe 12" long. Good luck with the project. did the exact same thing with exact same pump. 69 B 8 3/4
#2467662
03/17/18 10:39 AM
03/17/18 10:39 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Anyone running the mr.gasket pumps or holleys? I run the Holley black pump. Its mounted right in front of the gas tank as since I run a stock gas tank its really nowhere to mount it lower then the tank. So its bolted on the floor right in front of the gas tank near the sending unit. Its actually sitting level with the top of my stock tank. It has worked fine mounted there for 12 years so far as I put the car on the road in 2006. And it feeds enough fuel to my 850 carb for my 63 to run 10's and not lay over in the traps. I have not been able to get any pics as my left knee is real bad and my other joints have been giving me so much trouble its tuff to lay under the car and get a pic. I am actually getting my left knee replace this Monday on March 19th. Ron
#2467666
03/17/18 10:53 AM
03/17/18 10:53 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I don't have a pic but before I went EFI I had a Holley Blue pump mounted in front of the spring mount on the passenger side. It worked well there for a very long time.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
#2467811
03/17/18 06:40 PM
03/17/18 06:40 PM
Posts: 152 usa
smos001
usa
On my 70 challenger, I put my electric pump right in front of the fuel tank. I made a bracket to have it hang a bit lower. I also found a thick rubber exhaust hanger material that I used to put behind the fuel pump and the bracket to reduce the noise and vibration. Works great. S
[Re: 383man]
#2467879
03/17/18 09:53 PM
03/17/18 09:53 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Anyone running the mr.gasket pumps or holleys? I run the Holley black pump. Its mounted right in front of the gas tank as since I run a stock gas tank its really nowhere to mount it lower then the tank. So its bolted on the floor right in front of the gas tank near the sending unit. Its actually sitting level with the top of my stock tank. It has worked fine mounted there for 12 years so far as I put the car on the road in 2006. And it feeds enough fuel to my 850 carb for my 63 to run 10's and not lay over in the traps. I have not been able to get any pics as my left knee is real bad and my other joints have been giving me so much trouble its tuff to lay under the car and get a pic. I am actually getting my left knee replace this Monday on March 19th. Ron Ron, best of luck on your surgery. Knee replacement has come a long way in the past few years, so seems to get simpler all the time. Hope you're back up and running in short order. You're always a great help to us here with questions.
Lead, follow or get the hell out of the way
[Re: peabodyracing]
#2468408
03/19/18 12:30 AM
03/19/18 12:30 AM
383man
Balt. Md
Anyone running the mr.gasket pumps or holleys? I run the Holley black pump. Its mounted right in front of the gas tank as since I run a stock gas tank its really nowhere to mount it lower then the tank. So its bolted on the floor right in front of the gas tank near the sending unit. Its actually sitting level with the top of my stock tank. It has worked fine mounted there for 12 years so far as I put the car on the road in 2006. And it feeds enough fuel to my 850 carb for my 63 to run 10's and not lay over in the traps. I have not been able to get any pics as my left knee is real bad and my other joints have been giving me so much trouble its tuff to lay under the car and get a pic. I am actually getting my left knee replace this Monday on March 19th. Ron Ron, best of luck on your surgery. Knee replacement has come a long way in the past few years, so seems to get simpler all the time. Hope you're back up and running in short order. You're always a great help to us here with questions. Thank you as I go in tomorrow morning. Ron
#2471315
03/24/18 12:46 PM
03/24/18 12:46 PM
Posts: 22,695 Bitopia
jcc
Bitopia
It will take only one muscle car with a rear mounted exposed electric fuel pump to be involved in a fender bender with a loaded school bus for all this electric fuel DIYI upgrades to go legally bye bye. Taking that into account, installing one of these might save you and your car also. https://www.summitracing.com/parts/rfw-cr92/overview/
