70 Hemi 727. Is there any EXTERNAL difference. #2466300
03/14/18 12:02 PM
03/14/18 12:02 PM
SC
V194 Offline OP
V194  Offline OP
SC
Other than the stamping on the rail is there any difference externally of a HEMI 727 vs. a RB or b 727?
I know the pan rail should read:
xx 3410671 xxx xxx (for a 70 unit)
Was the HEMI unit only made at one plant location?
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2466302
03/14/18 12:08 PM
03/14/18 12:08 PM
A727Tflite Online content
A727Tflite  Online Content
All automatic trans back in the day where made at one plant - the Kokomo Trans Plant.
There are no external differences between a big block and hemi 727.
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: A727Tflite] #2466306
03/14/18 12:14 PM
03/14/18 12:14 PM
SC
V194 Offline OP
V194  Offline OP
SC
As I suspected. Now what is the prefix for the Kokomo plant in the pan rail number sequence? I see one with a J xxxxxxx and one with a PK xxxxxxx
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2466441
03/14/18 04:01 PM
03/14/18 04:01 PM
dogdays Offline
dogdays  Offline
PK
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2466623
03/14/18 10:08 PM
03/14/18 10:08 PM
SC
V194 Offline OP
V194  Offline OP
SC
So what is "J"
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2466668
03/14/18 11:31 PM
03/14/18 11:31 PM
Never got a good explanation for all the strange prefixes and suffixes after the base part number - but all of these transmissions should have had a PK in front.
I can't confirm a story I heard but some units were shipped in pieces then "built" at another location - but that has never been confirmed.
The suffix after the part number may have something to do with the line that built the unit.
The plant so many transmissions that is is likely to have had more than one line - or shifts - and the alpha may be for tracking line or shift.
Only a few people are alive that still work at the plant - they may know the real reason.
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2466711
03/15/18 12:49 AM
03/15/18 12:49 AM
SC
V194 Offline OP
V194  Offline OP
SC
Thanks I appreciate it.
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2466878
03/15/18 01:13 PM
03/15/18 01:13 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The transmission Dip stick tube is unique to a Hemi Transmission.
1971 HEMI E BODY REGISTRY
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2466905
03/15/18 02:13 PM
03/15/18 02:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By V194
So what is "J"
Someone opined that this means it is a parts room replacement built at a date later than the model year. shruggy
The example below is for a '67-'68 model year but the build date is mid-'72.
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: John_Kunkel] #2466927
03/15/18 03:13 PM
03/15/18 03:13 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I have ran into the question of date before where some were dated with the normal 10,000 day calendar. But have noticed that 67 and back the date doesn't seem to be the same. I have a 67 440 HP trans and I believe that it stamped H for the plant, then the part number, followed by the date. but the date is not correct for the year. I have seen them stamped PK, H, and J before the part number. Would like to know more on the dating as well. I can try to get pictures maybe later, if that helps.
Matt
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: mattsmopars] #2466967
03/15/18 05:01 PM
03/15/18 05:01 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there is some discussion of non-"PK" transmission part numbers '62 auto trans - on MOPARTS shruggy
Originally Posted By mr426427
Galen's book is wrong on 62 and 63 max wedge trannys. 007 is the correct number for 63 model year cars. 007 was used in the 300J along with 63 max wedge cars. the second number is not a date code either as Galen has always suggested. It is simply a continuing assembly number that is carried on year after year. the C suggests it was assembled in the second half of the 62 calendar year. a D in front of it would indicate the first half of 63. then E and F would be the 64 model year, G and H would be the 65 model year, etc. I think your tranny could very well have been out of a 300J that was likely assembled late in 62 or early 63. it would fit a lot of max wedge cars built around the same time frame. it should be worth at least 500 hundred dollars to someone trying to make a maxie as correct as possible.
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: 6bblgt] #2467033
03/15/18 07:31 PM
03/15/18 07:31 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Here is a picture of a 1966 hemi 727 that is still attached to a very unmolested 66 hemi engine. The engine appears to still have the original fan belt and a M embossed mopar oil filter on it. It was supposed to have been pulled and shelved in 1969, so I have no reason not to believe it is factory original like the rest of the engine.
Matt
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2467065
03/15/18 08:41 PM
03/15/18 08:41 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: mattsmopars] #2467074
03/15/18 09:08 PM
03/15/18 09:08 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Ok here are a few of some personal transmissions that I have. 2 are from 68 cars. Both are stamped PK with the part number and dates that look to be the correct 10,000 day calendar. One being a 68 hemi 727 that has a partial vin stamp, and the other a 68 904 unit.
A couple others are from 1967 year cars both stamped with H and part number. One of those is for a 67 hemi auto H2801544. I bought the trans from a guy who said he pulled the engine and trans from a running car 35-40 years ago, and he only sold the engine and stuff a coupe years ago.
the other is a 67 440 HP trans a H2801541. The trans with the H plant stamping has the strange dates that would not be correct for the normal thinking of the 10,000 day calendar, but it is the same as the 66 hemi trans pictures that I posted earlier. Maybe we can figure this out.
Matt
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: mattsmopars] #2467075
03/15/18 09:09 PM
03/15/18 09:09 PM
SC
V194 Offline OP
V194  Offline OP
SC
Originally Posted By mattsmopars
Interesting. What I am looking at reads:J2801540 4245682
Which indicates:
j - ?
2801540 - 67-68 440 C body
4345 - Build date of March 12, 1973
683 - ?
Re: 70 Hemi 727. Is there any EXTERNAL difference. [Re: V194] #2467142
03/15/18 11:37 PM
03/15/18 11:37 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Maybe I’m wrong but I believe we are not interpreting the date correct. I don’t think they would be building and stamping a 67 trans in 1973.
Matt
