Thermo Quad accelerator pump spring and clusters (squirters) #2467066
03/15/18 08:42 PM
03/15/18 08:42 PM
NE
moparpoolman Offline OP
NE
From research I found out that (3)Three different accelerator pump clusters (squirters) were available for Thermo Quads. Anyone know how to identify them? are there numbers on them? (added)also is there a way to increase the pump shot? are there different spings for the accelerator pump? Thanks
Re: Thermo Quad accelerator pump clusters (squirters) [Re: moparpoolman] #2467102
03/15/18 10:01 PM
03/15/18 10:01 PM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
There is very small numbers stamped in the top 369,370,374. They measure .030,.035,.040 respectively. The 1000 competition series 4847sa squirter is interchangable. Although it looks different without the brass tubes. The one I have has a C and R on top and measures .026
Woodruff Carburetor Specialties
330-799-9479
Re: Thermo Quad accelerator pump clusters (squirters) [Re: moparpoolman] #2470165
03/22/18 12:54 AM
03/22/18 12:54 AM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
Working on a later model aftermarket Super-quad today,and took off a squirter stamper 393. My .0292 bit fit perfectly in it. Super-quad is the electric choke version.
330-799-9479
Re: Thermo Quad accelerator pump clusters (squirters) [Re: Vincenzo] #2470774
03/23/18 12:45 AM
03/23/18 12:45 AM
NE
NE
It looks like I have 365 on my squirter, any idea on the size of a 365?
Re: Thermo Quad accelerator pump clusters (squirters) [Re: moparpoolman] #2471861
03/25/18 04:17 PM
03/25/18 04:17 PM
Earth
Rob C Offline
Rob C  Offline
Earth
IIRC, .065
Re: Thermo Quad accelerator pump clusters (squirters) [Re: Rob C] #2471886
03/25/18 04:59 PM
03/25/18 04:59 PM
NE
NE
That's not how they work, is more like a .024 but was wondering what the book spec would of said.
Re: Thermo Quad accelerator pump clusters (squirters) [Re: moparpoolman] #2471957
03/25/18 08:25 PM
03/25/18 08:25 PM
NE
NE
What's the best way (tricks) to increase the pump shot/squirt? Can stretching the spring help? Is there a stronger spring that would increase the shot? Making the squirters larger? how large? Thanks
Re: Thermo Quad accelerator pump clusters (squirters) [Re: moparpoolman] #2473196
03/28/18 09:33 AM
03/28/18 09:33 AM
Locomotion Offline
Locomotion  Offline
You can use letter size drill bits and what they call a "pin vise" to carefully hand drill out the nozzles. As for overall volume, I believe the only way to increase it is to have the linkage in the proper hole (closest to the pump) and have it bent so the plunger is topped out. As with any carb, remember that as you go bigger with the squirter size, the duration of the squirt will be reduced because the overall volume is dumped faster. But I don't believe you have to go too big on the primary squirters because the bores are so small. Lot's of other adjustments can be done with the secondary air door and linkages to minimize flat spots or bogging. (I'm still learning.)
Re: Thermo Quad accelerator pump clusters (squirters) [Re: Locomotion] #2473293
03/28/18 01:15 PM
03/28/18 01:15 PM
moparx Offline
moparx  Offline
took me a long while to learn tuning technics for TQ's, including writing programs for jets and metering rods [unfortunately, the machine used has been out of production for 25yrs or so]. this also included using a pin vise on the squirters. it was a lot of work, but i really like those carbs now ! i buy them frequently at the swaps for $25 or so, when possible.
beer
