STOCK HEAD W/BIGGER VALVES #2466583
03/14/18 08:24 PM
03/14/18 08:24 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I came across a MP 308 bare head with 2.05 intake and 1.62 exh. All the ports are stock less the bowl cut port. Will this head make more HP with just the larger valves? Special cam specs? Since this is only 1 head, if its not going to make more HP then I won't have a used spare head modified to match. Thanks.
Re: STOCK HEAD W/BIGGER VALVES [Re: A/MP] #2466655
03/14/18 11:06 PM
03/14/18 11:06 PM
Author Dulcich has some informative SB porting articles & I've seen some 308 info there. You might Google it.
Re: STOCK HEAD W/BIGGER VALVES [Re: A/MP] #2466676
03/14/18 11:43 PM
03/14/18 11:43 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Nice article. Wish they had posted some pics. If a 2.02 valve is good, then 2.05 better?
Re: STOCK HEAD W/BIGGER VALVES [Re: A/MP] #2466687
03/14/18 11:55 PM
03/14/18 11:55 PM
I would think, if the chambers were unshrouded (which would obviously add CC's/affect your SCR) (& do bowl work).
Re: STOCK HEAD W/BIGGER VALVES [Re: RapidRobert] #2466699
03/15/18 12:09 AM
03/15/18 12:09 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I wish it was always that simple. But it isn’t
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: STOCK HEAD W/BIGGER VALVES [Re: pittsburghracer] #2466718
03/15/18 01:00 AM
03/15/18 01:00 AM
^^^ agreed, it'd need to be compatible with the cam etc.
Re: STOCK HEAD W/BIGGER VALVES [Re: A/MP] #2466773
03/15/18 06:19 AM
03/15/18 06:19 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
So are talking a stock lift, say .430-.464 lift, with a longer duration than stock like a cheater cam?
Re: STOCK HEAD W/BIGGER VALVES [Re: A/MP] #2466849
03/15/18 12:07 PM
03/15/18 12:07 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had some X heads that were lightly ported changed from 2.02 to 2.05 and it picked up .2 in the 1/2. This was on a 340 that was running mid 12s at the time.
68 Barracuda Formula S 340
