Vin, Tag, and Engine serial numbers #2466502
03/14/18 05:50 PM
03/14/18 05:50 PM
Pennsylvania, Chester County
RonLiv Offline OP
RonLiv  Offline OP
Probably this has been addressed before but I have been unable to find a thread. So I apologize if this is a duplication and has already been answered.
I have a 1969 Roadrunner. It is not a numbers matching drive train, but I believe it is at least to be date correct. The Serial Number of the Vin matches the Serial number on the Fender Tag, but not the Engine. Casting Codes and Date seem to verify in my unprofessional view that at least the engine is correct for the car, just not "the" engine.
Is there anyway to tell from the Serial Number on the Engine/Transmission where it came out of or from?
I realize that most of these cars were driven hard back in the day. I had one back in the early 70's, so I have some experience with that. But as these engines failed, were they just rebuilt and thrown into another car and flipped around, or are they replacement engines? Just curious.
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466503
03/14/18 05:55 PM
03/14/18 05:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Some plants only made certain models which also varied by model year.
Some people have also recorded known numbers for decades.
So what is the partial VIN on the passenger side of the block?
That would be the best place to start.
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466521
03/14/18 06:23 PM
03/14/18 06:23 PM
RonLiv Offline OP
RonLiv  Offline OP
So what is the partial VIN on the passenger side of the block? 106944
Casting Date: 6/10/69
Casting Code: 2468130
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466525
03/14/18 06:25 PM
03/14/18 06:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
There should be two more (a number & a letter) in front of it.
Re: Vin, Tag, and Engine serial numbers [Re: Alaskan_TA] #2466528
03/14/18 06:27 PM
03/14/18 06:27 PM
RonLiv Offline OP
RonLiv  Offline OP
There is: CA106944
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466529
03/14/18 06:27 PM
03/14/18 06:27 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Also, what letter is right in front of the engine size on the id pad?
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466545
03/14/18 06:52 PM
03/14/18 06:52 PM
RonLiv Offline OP
RonLiv  Offline OP
I don't know the answer to that one 71birdJ68. I'll try to find where you are referring. It may take a few days.
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466548
03/14/18 06:55 PM
03/14/18 06:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If the C is a poorly stamped 0, then 0A would be a 1970 model from the Lynch Road plant.
Lynch Road was B-body only for '70.
Is the letter on the pad that 71birdJ68 mentioned an F ?
Clear photos of both pads would help if you can get some?
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466551
03/14/18 06:56 PM
03/14/18 06:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 2nd pad mentioned is up on top by the front of the intake manifold mounting surface.
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466556
03/14/18 07:04 PM
03/14/18 07:04 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
383, or 440? 383, it will be on the machine part kind of behind the distributor, 400 just like he said big pad in front of the intake.
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466557
03/14/18 07:06 PM
03/14/18 07:06 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
0A106944 = partial VIN from a '70 Plymouth B-body
Casting Date: 6*10*69
Casting Code: 2468130 = 383 cu.in.
the top pad on a 383 is located under the distributor scope
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2466632
03/14/18 10:22 PM
03/14/18 10:22 PM
RonLiv Offline OP
RonLiv  Offline OP
You guys are good. Give me a couple days to get this information. Really appreciate all the input.
Thanks!
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2467115
03/15/18 10:32 PM
03/15/18 10:32 PM
RonLiv Offline OP
RonLiv  Offline OP
OK I'm having difficulty attaching an image so I'll just provide the numbers on the pad
F 383
8 21
HP
Re: Vin, Tag, and Engine serial numbers [Re: RonLiv] #2467121
03/15/18 10:46 PM
03/15/18 10:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
F is the Series (model year) 1970
383 & HP are what you think.
8 21 is the final assembly date for the engine.
TSB page with related information can e found at http://www.hamtramck-historical.com/images/TSBs/1970/70-25-1%20page7.jpg
Re: Vin, Tag, and Engine serial numbers [Re: Alaskan_TA] #2467141
03/15/18 11:36 PM
03/15/18 11:36 PM
RonLiv Offline OP
RonLiv  Offline OP
Thanks!
